WD420 my washing machine won't spin all the way round when it is washing and it is struggling to spin fast. could it be a blockage. my drier hasn't worked for 3 years but i don't need it. how do i check that no baby sicks are blocking it. manyt hansk angela fleming
    President:
  • 1,294 Answers
Check your exit hose spigot, it may be clogged. This is if your filter (refer manual) is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
And pl rate me if helped.................
Posted on May 09, 2008
Whay my Hotpoint -Ariston Aquarius WD420 Front Load All-in-One Washer / Dryer stpos have way the circle
You say it stops half way through cycle (if I have read it right), especially when fast spin starts. Does it stop anywhere else (in wash cycle or rinse cycle)?
I would check the main filter in the sump (pipe from drum to drain pump) and ensure pump itself is not blocked which could cause the pump out time to be exceeded and thus stop the program. A faulty pressure switch could also be responsible.
I would also check the tacho on the motor and connections to main board at bottom of machine near to motor.
Disconnect machine by pulling out plug and wait 10 minutes for capacitors to discharge before doing anything, to protect yourself against residual voltages.
From a retired engineer who owns one of these machines.
Jul 28, 2012 | Hotpoint Ariston Aquarius WD420 Front Load...
Fast spin not working. drum going round and draining but not spinning. Help!!!!
Possible there is no drive voltage to the motor at this point of cycle, could be due to fault in the controller unit.
Need to check the voltage on the unit to confirm this case as the drain gets connected..
Jul 27, 2012 | Hoover Washing Machines
Hotpoint WD420 - Washes OK but when it moves to rinse and spin machine stops with error code F05 (lights 2 & 4). Have removed some debris from waste hose but this hasn't fixed it - what else do I...
Indesit (Hotpoint, Ariston) 'F05' decodes as 'pump blockage'.
I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to spin or release the door lock if there is any water still left inside.
Here are my complete and generic guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!). These panels are either held on by (plasic) screws or will just pull off. Most filters are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT.
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Jun 20, 2011 | Hotpoint Ariston Aquarius WD420 Front Load...
Leaking water if rinse and spin
Check your pump is ok and filter not any blockage as this is common cause/ Fiter located within sump hose...bottom of drum take clip off to remove.
Apr 13, 2010 | Hotpoint Ariston Aquarius WD420 Front Load...
Hotpoint aquarius wd420 cannot stretch drive belt on there is no slide bar on motor which is fixed solid even after bolts are lossened its a washer drier no obvious way of attaching belt
There is no adjustment provided for tensioning belt as it is a stretch belt.
Best way to do it is to remove the rear panel, tilt the weaher forwards, get someone to hold it for you.
Put belt round motor pulley first, then slowiy feed it round the drum pulley, turning the drum pulley at the same time, it will be very tight, so watch your fingers, just keep going until belt is on, if it comes off, just start over
You can line it up properly in the motor pulley grooves once you have got the belt on.
Please rate my solution.
Thankyou.
Feb 25, 2010 | Hotpoint Ariston Aquarius WD420 Front Load...
No fast spin
Could be blockage in pump or filter, if there is a blockage then the m/c will not spin with a lot of water in it.
Dec 13, 2008 | Hotpoint Aquarius WD63 Front Load...
Hotpoint wd420
if the drum is tight to turn ,then the main bearings have probably seized, or their could be something fast in the drum. Remove belt, and try to turn the drum by hand , it shuold be free with no resitance.
If it is noisy or feels rough, then the bearings have gone.
Sep 01, 2008 | Hotpoint Aquarius WD63 Front Load...
Washing Machines Logo
Top Washing Machines Experts
