Question about Raypak 130,000 BTU Propane Gas Pool H...
My raypak heater has error code LO. What does that mean
  • 990 Answers
This is in the limit string. This is the string of safty switches in the heater. (thermostat, highlimits, rollout switch and pressure switch) The pressure switch is the most common problem. If the water flow get's to be too little so the water inside the heater is going to overheat than this will shut the heater down. This can be caused if your heater by-pass is to far open and letting water go by the heater. The most common problem is clogged baskets or a dirty filter. Other than this you can follow the flow chart in your manuel to find the source of the problem but if it just started without obvious cause this would be my bet.
I hope this helped and good luck.
Posted on Aug 31, 2010
What does code 'ILO' mean and how do you fix iy
ignition failure tried 3 x didn't light lo high limits bad
Jun 22, 2014 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
What does this code mean? :LO
check pressure switch or copper tube to it
May 22, 2014 | Raypak RP2100 DIGITAL POOL HEATER R265
Have a raypak heater that displays code l Lo except the l has a break in the middle and looks more like to prongs pointing towards each other.
check filters if ok check pressure switch see if voltage both sides of plug if not bad pressure switch or clogged copper line
Aug 26, 2013 | Raypak Free Hydraulic Lift Gate Delivery -...
I am getting a ROL code on my raypak 406 gas pool heater. Does anyone know what this means?
roll out senor bad replace but check gas pressure if too low it will overheat once gas is ok then replace fusible link and clean outside of het exchange
May 11, 2012 | RAYPAK R406A DIGITAL MODEL 406 wCUPR0...
Ign error code on a raypak rp2100 pool heater
ignition failure check gas pressure if ok see if ignitor is ok or safety circuit
Apr 22, 2012 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
Raypak 2100 just get SPK then LO codes. won't ignite
if wired 120 volt check wiring and check gas pressure see if lines have cobwebs
Jan 02, 2012 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
I have a raypak 2100 heater and it display a PLT code what can i do to fix it it tray to start but shoot down rigth a way
The "PLT" error code means pilot failure. The lack of spark may or may not mean an ignitor problem.
The "PLT" code could come up because the main valve in the heater was in the "off" position. No gas = no pilot.Also check clogged pilot-burner orifices. The lack of spark can also have to do with water flow issues (dirty filter, clogged basket, etc.), or it may be a problem with the electronics of the heater.
After checking the above, a service call by an authorized tech may be necessary.
You can also call Raypak at (805) 278-5300 for Customer Service
Sep 07, 2010 | Raypak Free Hydraulic Lift Gate Delivery -...
Raypak pool heater RP2100 error message CLK
you are in fireman switch mode,which means pool timer is ready to shut down pump. clk shuts down heater approx 15 minutes before pump shuts down. this lets heater cool down before pump shuts off.
Jul 05, 2009 | Raypak 130,000 BTU Propane Gas Pool...
"LO" error code on new H400FDN heater
it is low water pressure sensed, unit will not start unless pump is working
Jun 07, 2009 | Hayward 250kbtu Ng Pool Heater - Inground
Raypak 130,000 BTU    Propane Gas Pool H... Logo
578 people viewed this question
Top Raypak Pool & Spa Experts
Bill Jordan
Paul Carew
Jim Goldsmith
Jim Goldsmith
Are you a Raypak Pool and Spa Expert? Answer questions, earn points and help others
