Question about Hamilton Beach Microwave Ovens
Power goes off. you can then jar the microwave and power comes back on. then power goes off again
  • 3,600 Answers
The door safety switch may be defective. But need a model number to be sure, here is a web page that you can go to insert your model number and it will give you a parts break down once you have that get back to me for testing instructions.
http://www.appliancepartspros.com/
Posted on Aug 31, 2010
GE Spacemaker XL 1800 turns on for 1 second and then resets. The display shows PRESS CLOCK.
Sounds like your losing power, have you tried it on a completely Different circuit??? Either that or bad fuse or connections inside of microwave.
Sep 08, 2017 | GE Microwave Ovens
Light goes out and turntable stops, but still hums like power is still on.
You have a bad door switch that will need to be replaced.
May 13, 2012 | LG Microwave Ovens
Is the blades supposed to come off when I take the container off of the blender.. My blender is brand new sat for 3 or 4 years after I bought it. . The first time I used it , it was extremely hard to get...
You did not specify a brand or model number of your blender; however, most blender jars will lift off their power base without turning or with only very little turning motion to release them from the base. The blade assembly should NOT come off as you remove the blender jar from the power base.
Were you successful in removing the bottom ring which normally screws on to the bottom of the blender jar from the powerbase?
You should make sure you have properly attached the blade assembly for your brand/model.
The blender blade assembly should be held on to the bottom of the blender jar by the bottom ring which screws on clockwise; most will have a sealing gasket that fits between the blade assembly and the sealing surface of the blender jar to prevent any leakage while in use. It will take much more turning to unscrew the bottom ring to release the blade assembly than it should to release the bottom ring from the powerbase.
Assemble your blender jar and blade assembly and try a dry run by placing on the powerbase, giving a couple of bursts of power, and then seeing if you are able to remove without the blender ring unscrewing.
Make sure you are comfortable with the action required to remove the blender jar from the powerbase before you put in to use.
Jul 31, 2011 | Microwave Ovens
I have a GE JVM1190 Microwave Oven. It's sounds
It's cooking when it shouldn't, but the internal cooling fan is not running, so the magnetron is overheating, which can kill it.
Then when it gets hot enough, it trips the magnetron's thermostat, interrupting all power to the microwave. When it cools, it comes back on.
If and when an oven is coming on or doing anything by itself, this is very dangerous and can result in a fire.
So until it is repaired, please leave it unplugged or leave the door open when it's not in use, and of course one should never leave a microwave unattended while cooking.
The problem is almost certainly that the power relay on your control circuit board is shorted.
We regularly repair such control units for customers nationwide by mail for $39.95 postpaid with a one-year guarantee.
Feel free to contact me directly (and please remind me of your full model number from the tag on the unit) for more free information & help.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Microwave Oven Control Panel Repair Nationwide
Jun 15, 2010 | GE JVM1190 Microwave Oven
New maytag power shuts off and comes back in half hour
Depending on the model you may need a 15 or even up to a 20 amp circuit to operate the microwave. Check the installation instructions to be sure. What is most likely happening is the circuit in your home is not powerful enough to run the load of the microwave oven. If this is the case it could be dangerous. I would strongly recommend you have an expert examine the house wiring prior to starting the unit again.
Apr 20, 2010 | Maytag MMV4205 Microwave Oven
The microwave occasionally shuts itself off. The
You are tripping a high limit switch which means the cooling fan is busted or the microwave is installed to close to something. That or your door interlock switches are sticking.
Dec 19, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
OTR Amana microwave- No power, lights, clock or sounds.
Either your magnetron, cooling fan, or the magnetron thermostat is failing.
Since it's less than one year old, it would be fully covered under warranty. I'd suggest contacting the manufacturer to get it fixed free.
Amana / Whirlpool customer service is here.
Please contact them to find your nearest authorized service center.
Jun 06, 2009 | Amana Radarange Microwave Oven
Sharp 1874- Door seems to "jar open" and oven stops
if you have a warranty get a new one installed they have to honor your warranty or better yet if they want payment you want new unit sometimes they come deffective from the factory ad you may have gotten one of them
Feb 20, 2009 | Sharp R-1874 Convection/Microwave Oven
Microwave inoperative on rv generator power
Replaced with different microwave. Amanna microwave works fine on both circuits. Would not recommend Whirlpool for RV use.
Thanks
Dec 27, 2008 | Whirlpool 1.6 Cu. Ft. Over-the-Range...
Microwave Ovens Logo
52 people viewed this question
Top Hamilton Beach Microwave Ovens Experts
Are you a Hamilton Beach Microwave Oven Expert? Answer questions, earn points and help others
