Question about Microsoft Xbox 360 Console
My xbox wont read xbox games but plays dvd`s,ive replaced disc drive and done the xclamp procedure.any ideas how i can fix this??
    Problem Solver:
  • 13 Answers
Since you've already replaced the drive and done the other procedure, you're best bet is to get in touch with xbox directly as it may be a software issue now. 1-800-4MY-XBOX
Posted on Aug 31, 2010
My xbox 360 wont play discs. I put the game disc in, it says its reading it, then it opens the tray and the disc comes out. Your help tip said look at the mfg tag to see if it was made after 2007. Mine...
I would say its 95% certain that your DVD drive has failed , considering its 5 years old, i would say you havent done bad , you will need to replace the laser to fix it, it is no good just getting another dvd drive as you will have to read the dvd key from the drive and flash it to the new one to enable you to play games, as each dvd drive is unique to its xbox 360. The easiest way is to replace the laser in it. It isnt that difficult to do either
Mar 18, 2011 | Video Game Consoles & Games
Xbox 360 - Please put disc into an xbox 360 console to play
Try getting a disc drive cleaner. (Maxwell).
www.walmart.com is and example retailer.
May 24, 2010 | Microsoft Xbox 360 Console
Game wont read says put disc in xbox 360 but i am using xbox 360 also it says its a dvd not game just wont let me play no more
If you have recently tried to mod your Xbox 360 then you did not get the drive key installed correctly. Otherwise the laser lens is either dirty/ starting to weaken. You can either replace the laser lens in the disc drive, try to clean it, try the POT tweak or replace the whole disc drive. Keep in mind if you replace the disc drive you will need to swap the PCBs or the drive keys. Hope this helps.
GATpro
May 21, 2010 | Microsoft Fable 2 for Xbox 360
Wont read games only reads dvds
This is going to be a bit long -- but very detailed, so please read it carefully. There are several reasons that an xbox 360 system will have problem reading discs. The error messages also vary from unreadable disk, no message at all but the game skips, "please insert disc in a 360 console" to "open tray." There are a few reasons this may happen:
1.Bad disc. Check the back of your disc for scratches. If it looks good (or plays fine in another console), then the disc is probably fine. Also-- try more than 1 game to be sure.
2. Bad laser. The XBox 360 has a DVD drive very similar to a PC's DVD drive inside. The drive contains a bunch of parts including a few motors and gears and a laser.The laser is the part that actually reads the disc. The reality is...with all the hours and hours of game play, lasers do eventually wear out. The laser isn't very easy to replace, but it is replaceable. You can find any and all XBox 360 lasers at the following website:
http://store.richspsxparts.com/xb360ac.html
3.Bad DVD Drive. Sometimes other components inside of the DVD drive can become bad such as the motor that spins the disk, the motors that open the tray, etc, etc. You can get a new DVD drive to just replace everything,including the laser, in one shot but there is a catch. The XBOX 360's DVD drive is tied to the motherboard using a software lock.The easiest way to overcome this lock is to buy the exact same manufacture DVD drive that is in your system now, remove the circuit board from the old DVD drive (which contains the software key) and transfer the circuit board into the new DVD drive that you purchase. If you do this simple procedure, there is no flashing involved. The following website carries DVD drives and also provides instructions on swapping the circuit board from the old drive into the new one.
XBox 360 parts: http://store.richspsxparts.com/xb360ac.html
DVD Drive Swap Info: http://store.richspsxparts.com/imnooninxb36.html
May 15, 2010 | Microsoft Xbox 360 Pro System Console
Xbox 360 wont play games
If your Xbox 360 will not read your games this is because of the sensors on the back of the drive taking too much heat.
You need to send it in to get it fixed or you can fix it yourself using a good guide
Feb 05, 2010 | Microsoft Xbox 360 Console
Xbox 360 wont load any disc and have tried 7 steps of repair on your websitse and it still wont work
This is going to be a bit long -- but very detailed, so please read it carefully. There are several reasons that an xbox 360 system will have problem reading discs. The error messages also vary from unreadable disk, no message at all but the game skips, "please insert disc in a 360 console" to "open tray." There are a few reasons this mayhappen:
Jan 15, 2010 | Microsoft Xbox 360 Console
Xbox 360 samsung m25 game fault
It's Not The dvd drive key otherwise you'd get the three red light lights. It's most probably a bad firmware flash try and reflash it to the original firmware with the same dvd drive key and see if that works.
Alex
Jul 10, 2008 | Microsoft Xbox 360 Console
Error Message
Be sure to wipe clean around inside hole on 360 game disk it has info laser scribed that tells the system what game it is.It might also need a laser adjustment.
Dec 26, 2007 | Microsoft Xbox 360 Console
Wont read the disc
Soryy to hear about it guys. no really at home solution but you can call the experts the number is 1-800-4myxbox they will try to fix your problem and if they cant they will repair it. Hopefully this helps and i hope you get to gaming soon :)
leave feedback please
Dec 25, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
56 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
