Question about Brother MFC-5840CN All-In-One InkJet Printer
Need instructions on how to set up recieving faxs...and is toner the same as ink ?
  • 6,831 Answers
Hello
As far as the first question, i always find that the manual explain this situation the best, you will be able to download the manual HERE.
Secondly, toner is not exactly the same as ink. Click HERE to read.
Hope this can steer you in the right direction.
Kind regards
Andrea
Posted on Aug 31, 2010
Hi i really need to recieve a fax, but it says the toner life is done, is there anyway to squeez one more fax out of it?
dip the toner in a mild hot water for few minutes and replace it after wiping . you will find that you have some ink its the coagulated ink within the cartridge. it works i have tried.
May 10, 2011 | Brother IntelliFax-2820 Laser Fax
I have a Toshiba Dp85F Fax machine and need to replace the toner cartridge...I do not know what model number I need to replace it with. Please advise
Ink, Toner & Accessories for DP-85F Printers, Copiers & Faxes Select from the list below Compatible or Original ink and toner cartridges that work with your DP-85F.
TOSHIBA TK-18 Compatible Black Laser Cartridge, TK-18
  • - Condition: Compatible
  • - Page Yield: 6000
  • - Color: Black
  • - Printer Technology: Laser Cartridge
  • - Item Number: TK18-70
- OEM Part#: TK-18, TK18
Item #: TK18-70
MSRP: $114.99
Price: $38.99
Toshiba DK-18 DP-80/DP-85 Drum Unit
  • - Page Yield: 20000
  • - Color: Black item-color-black.gif
  • - Printer Technology: Drum Unit
  • - Item Number: DK18-70
- OEM Part#: DK18, DK-18
Item #: DK18-70
MSRP: $114.99
Price: $39.99
Toshiba DP85F Toner Cartridge, Black
Toshiba TK18 Toner Cartridge, Toshiba TK-18 Fax Toner
$73.59
Nov 29, 2010 | Toshiba DP-85F Fax
What does it mean when there is a big smug down the middle of the received fax? Does it mean there is something wrong with the printing belt? Or that it needs a new ink cartridge?
does this happen with every recieved fax from every number... ? if so then the either the drum or fuser is bad... open unit and take a soft cloth and clean drum... look at the fuser see if you can match smudge to fuser or drum...
I’m happy to assist further over the phone at https://www.6ya.com/expert/norman_d2fa496dce30c65d
Dec 09, 2009 | Panasonic Panafax UF-560 Plain Paper Laser...
My hp printer fax does print when recieving a fax but doew print normally when coming off computer. Fax machine sya low on ink should I check both cartridges and get new ones
Yes , if the fax machine says low ink or toner , then it needs it alos check the drum corona wire, It may need cleaning, and you can clean it using a #2 lead pencil eraser, Gently in the wire, then replace wire and try receiving a fax.
Jul 10, 2009 | HP 920 Plain Paper Fax
Light fax
This could be a couple of different things. The first is that you are running out of ink or toner. Or you could have your toner save turned on. You can conserve toner using this feature.
When you set Toner Save to On, print
appears lighter. The default setting is Off.
1 Press Menu/Set, 1, 6, 1.
2 Press ▲ or ▼ to select On (or Off).
Press Menu/Set.
3 Press Stop/Exit.
Jan 13, 2009 | Brother IntelliFAX 2800 Laser Fax
NOT RECIEVING FAXES
You need to use the [MENU], [< >] and [ENTER] keys to browse through the unit's menu. Find and enter the "System Setup" menu and then search for the "Ignore Toner" option. Press [ENTER] and change the setting to "ON". Press [ENTER to confirm, the, [STOP/CLEAR] to get out of the menu system. The unit should start printing all faxes in memory.
Be blessed.
Nov 05, 2008 | Samsung SF-5100 Plain Paper Laser Fax
1840C Brother fax machine
Do you have ink / toner / paper?
Unplug the power cord for 10 seconds.
Sep 08, 2008 | Brother IntelliFAX 1840C Plain Paper...
Not recieving only in memory
My good friend:
The only reason why your unit stops printin faxes is because the toner cartridge is nearly empty. Th e unit will then try to conserve the remaining toner for printing and copying. Follow this steps to program the unit to print all faxes, even with toner low:
When the toner cartridge is nearly empty, the machine shows
the “[Toner Empty]” message and continues printing except
incoming faxes. In this case, incoming faxes are saved in
memory.
However, you can set the machine to print incoming faxes, even
though print quality is not optimal.
1 Press Menu until “Machine Setup” appears on the display.
2 Press the scroll button ( or ) until “Ignore Toner”
appears on the bottom line and press Enter.
3 Press the Scroll button ( or ) to select “On” or “Off”.
Select “On” to ignore the [Toner Empty] message.
Select “Off” to stop printing incoming faxes when the
message appears. This is the default setting.
4 Press Enter to save the selection.
5 To return to Standby mode, press Stop/Clear.
Be blessed
Jun 15, 2008 | Samsung SCX 4521F All-In-One Laser Printer
Samsung scx 4216f all in one printer
Searching on Google on how to access the fuse I found a page that showed you how to reset the counter without replacing the fuse. It was simple, access the TECH menu and select NEW CARTRIDGE. Here are the instructions:
[menu] - [#] - 1934 - [menu]
Then select “NEW CARTRIDGE”
Restart Printer to get out of the TECH menu.
May 11, 2007 | Samsung SCX-4216F All-In-One Laser Printer
Brother MFC-5840CN All-In-One InkJet Printer Logo
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
