Question about Sony KP-57WS500 57" Rear Projection Television
Sony kp-57ws500 I had a sony kp-57ws500, it turn on but red and blue come on then the green for a few seconds then it turn it self off. Before it turn off the green come and go off first the a few seconds all went off. What do think? Can you help me with this? I'll really appreciate, Thank You.
  • 1 more comment
  • andy9999 May 12, 2008
    where can I get a new green crt and how much it will cost? Thanks!
    where can I find used CRT?
  • andy9999 May 13, 2008
    Oh! also how do I pull the red cable out from the splitter to the tube without getting shock? Thanks Again!
  • Sony Master
  • 8,617 Answers
You need a new green CRT, sony has had some problems with the green and blue crts developing shorts . Let me know if you need further assistance.
Posted on May 09, 2008
  • 1 more comment
  • Sonny Berry
    Sonny Berry May 12, 2008
    I would try partsstore.com but they are very exspensive. probably be better off trying to find a used CRT.
  • Sonny Berry
    I will check with some of my sources at work tomorrow and see if i can locate one for you.
  • Sonny Berry
    Sonny Berry May 13, 2008
    You have to use some insulated pliers then slide the rubber boot back then grab the wire and turn it 90 degrees and pull it out of the splitter. As soon as you remove the wire ground it to the metal chassis to discharge any stored voltages from the CRT. Do not remove the wire from the CRT itself as any replacement CRT has the wire already attached. I may have found a used green CRT for you I will know this afternoon for sure.
Sony kp-57ws500 flashes blue, green, red then turns off
Re-insering the flyback wire is usually very easy. Push in and give a slght turn and check to see if grabbed. It sounds as if there is more issues than flyback wire. TV should turn on without one crt connected
Dec 14, 2009 | Sony KP-57WS500 57" Rear Projection...
KP-57WS500 turning green or red and then off
Green and Red guns seems defective and requires replacement.
Both guns (CRTs) are no longer available so TV has no worth to repair.
Apr 19, 2009 | Sony KP-57WS500 57" Rear Projection...
Sony kp-57ws500
You have a bad green picture tube. If you have warranty coverage good, if not then forget about it. Get a new TV.
C-Dog
Jan 29, 2008 | Sony KP-57WS500 57" Rear Projection...
KP-57WS500 TV FADES TO SOLID RED W/ LINES A FEW SECONDS AFTER I TURN IT ON
Red CRT is doing short circuit in the neck. You can try to open the front panel and to hit easy the neck with wood or something and to decrease the red screen a bit. If doesn't work then replace the CRT.
Jan 04, 2008 | Sony KP-57WS500 57" Rear Projection...
Sony KP-57WS500 57 inch TV
Probable convergence IC failure = replace both for reliability..T.
Nov 24, 2007 | Sony KP-57WS500 57" Rear Projection...
Sony kp-57ws500
Probable bad blue CRT and if blue goes bad guess what might
happen to the red and green.........T.
Nov 07, 2007 | Sony KP-46WT500 46" Rear Projection...
SONY GREEN CONV OUT BLUE/GREEN OK,SONY KP-65WV600
Red,blue and green each have an amplifier IC--Stk392-560 x 2
Replace both IC's for reliable repair.Also,check  fuses,location sometimes ps5003-5008. fuse value 3.15 amp. ......T.
Oct 22, 2007 | Sony KP-57WS500 57" Rear Projection...
KP-57WS500
Sounds like a conergence circuit failure, probably a couple of AMPs and a few discreet components. Probably 250-300 repair
Apr 20, 2007 | Sony KP-57WS500 57" Rear Projection...
Sony KP-57WS500 57" Rear Projection Television Logo
108 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
