Question about Dacor DMT2420SS Microwave Oven
The touch screen control panel started flickering, came back for awhile then back to flickering. Now only showing pixels.
  • Dacor Master
  • 9,085 Answers
You can get that repaired for $39.95 in most cases (details here) or order a display here.
Posted on Nov 21, 2011
Microwave was beeping a single beep once in awhile now nothing happens but the clock still works
A lot of the time when that happens the touch pad is bad and may have a colappsed air pocket on a pad. ( it makes the unit think you are pushing a pad ) The only way to fix it is to replace it (the touch panel) . Did you see any numbers coming up in the display. Like if the 3 pad was bad and making it beep it may have been showing a 3 in the display,. Always possible it could be a bad main board. But most commonly I have found it to be the touch panel. Try to unplug it and then plug it back in and try to set the clock. when you do, try each number pad and see if they all work. See if any feel different.
Oct 17, 2017 | In Microwave Ovens
Shows "demo" and will not work
Pull the plug for a few seconds . Plug back in . With door closed try reseting clock . ( not recomended unless your a pro isid3 the main control typically behind pcb there is a chematick that will let you do a test on touch panel , pcb, and reseting the display etc.
Apr 30, 2016 | Panasonic Microwave Ovens
How do I reset the lg microwave. It's asking reset date but my touch screen
If the microwave buttons don't work the touchpad and control panel assembly are probably defective.
Jan 07, 2015 | LG LMV1630ST Microwave Oven
Touch Screen Not Working. Have cleaned the ribbon cable contacts and still the screen lights up showing the buttons but nothing on the touch pad works. If not the ribbon cable being dirty, I guess i
Most of the time the panel buttons stop working because grease gets between the outer panel and the contacts underneath. Disassemble the door and if you need to carefully peel back the outer panel, use some paper towels to remove the heavy grease, then using a Q-tip and some rubbing alcohol clean the back of the panel and the surface contacts on the board, then re-assemble.
Dec 26, 2014 | In Microwave Ovens
What's your problemPvm2070sm1ss ? touch screen control panel intermittently stops working
The touch screen has built in semiconductors that sometimes become intermittent, the only solution is to replace the touch screen.
May 17, 2012 | GE Microwave Ovens
I have chefmate microwave and suddenly stopped working. it is showing 2:50 code on the screen only...it was working fine and dont know what happened to it and touch pad is not working..how do i make it...
HELLO.
The code on the screen indicate electric panel fault resulting from the touchpad malfunction.
The touch pad on your microwave oven acts as the brain of the appliance. It not only contains the buttons that you use to enter cooking settings and times, but also controls the function of the entire microwave. If the touch pad malfunctions or breaks completely, the microwave will cease to function. In this instance, the broken touch pad must be removed and a new touch pad must be installed, to restore functionality to the microwave.
1 Unplug the microwave from the wall outlet.
2 Remove the two screws, located on the front or top of the grill at the top of the microwave.
3 Pull the grill off of the microwave.
4 Remove the mounting screw from the top of the control panel.
5 Lift the control panel up and out to loosen. Look behind the control panel to ensure there are no metal tabs securing the control panel in place. If there are metal tabs, gently rotate the control panel to free the tabs.
6 Transfer the wires from the old control panel to the new control panel one at a time to ensure that the wires are properly installed.
7 Install the new control panel into the microwave and secure using the mounting screw that was removed.
8 Replace the grill from the top of the microwave and secure it using the screws that were removed.
9 Plug the microwave back into the wall outlet.
Thanks.
Sep 12, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Hello, I have a GE Spacemaker 2.0 (JVM2070SK) and with an electronic touch panel. The unit is 3 years old, the panel lights up with all the options however, when you touch the screen nothing happens. Then...
This is a common problem, and they're often intermittent.
You'll need a new touch screen.
You can get complete details on all these 2070-series microwaves on my page here:
http://www.microwavecontrol.com/jvm2070.htm
- William E. Miller, AS-EET
pupista@gmail.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
May 01, 2017 | GE Profile Spacemaker Over-the-Range...
Dacor Touch Screen is flickering and doesn't respond to touch
You can get that repaired for $39.95 in most cases (details here) or order a control / display unit here.
Mar 31, 2009 | Dacor DMT2420SS Microwave Oven
LG Microwave Oven LMV2053SW
That's common - it's a problem on your control panel. We regularly repair these control panels for only $32.50 nationwide. For critical safety info & detailed disassembly info, see our link in our FixYa listing here: http://tinyurl.com/yzjozk Let me know if you need further help. I appreciate your kind rating!
Jan 27, 2007 | LG LMV2053 Microwave Oven
Control Panel Touch Screen Goes Blank
This is a problem with the control panel assembly, which we commonly repair for $32.50. Feel free to e-mail me at _ for more information or visit _ for full details.
Aug 01, 2006 | Sharp R-340 Microwave Oven
Dacor DMT2420SS Microwave Oven Logo
102 people viewed this question
Top Dacor Microwave Ovens Experts
William Miller
William Miller
Jerry Greenberg
Jerry Greenberg
Steven Clarke
Steven Clarke
Are you a Dacor Microwave Oven Expert? Answer questions, earn points and help others
