Question about Sewing Machines
When I turn on my hp it shuts right back off. Any idea what may be the problem? Thanks
  • 4,102 Answers
Hi the usual cause of it switching strait off is due to the processor over heating, now it may be a case of just getting the heat sink paste replaced or it could be worse and you process could all ready be burned out if this is the case then the chances are a new computer would do you better.
let me know if you need further assistance ok
plz rate this solution as i have a whole page of unrated posts, thanks
Posted on Aug 31, 2010
How to fill the bobbin with thread
The bobbin is a little metal wheel that is usually housed under a plate where the upper needle darts down into. Slide the plate aside and fish the bobbin out. Put the bobbin up on the upper right hand side of the sewing machine and connect thread from the full spool of thread to the bobbin and then when you push the pedal down, (if you have arranged it right), your machine will automatically fill the bobbin with thread and automatically shut off when it is full. Then you have to leave a bit of thread hanging out when you put the full bobbin back down into its hiding space. Of course, you can always fill the bobbin by hand too. When you put it back in its housing, some thread has to be hanging out as the needle will drop down, grab it and the two threads (the top one from the needle, and the bottom one from the bobbin) work together.
Machines work differently but the is the main idea behind most of them. I hope that helps.
Feb 08, 2015 | Sewing Machines
Viking 990S turns on and then shuts down right away any ideas of what I might do?
the machine may have powersupply or other electrical/ electronic problems. Take it to an authorized Viking repair dealer to discuss repair/ replacement options.
May 04, 2014 | Husqvarna Sewing Machines
Buttonhole Husqvarna 6430. When it is supposed to sew the right side of the buttonhole it just goes back over the left side. The machine doesn't do the two buttonhole lines next to each other . An
the machine probably needs to be serviced to see why it's not making
a buttonhole and see if the gear or cam for the zig zag stitch is
worn or damaged.
Jan 30, 2013 | Husqvarna Sewing Machines
Brother pr-600 screen not responding
See if you can discover how to reset the machine. Typically it is a combination of buttons pressed either simultaneously or in order as the machine is starting.
Dec 10, 2012 | Sewing Machines
Singer 2662 won't stay on
I'm sure you've tried all the plugs, but just in case, try wiggling the plug on the right side of the machine. I had the same problem, and my plug was loose. Good luck!
Mar 14, 2009 | Singer 2662
White d'lite 1750c presser foot in down position not recognized
I occasionally have the same problem with my White d'Lite 1750c. I turn the power off, let it rest a minute, then turn it on again, and the problem goes away for a long time (weeks, sometimes months). Of course, the settings go back to the default, so note your settings before turning the power off.
Hope this helps. Good luck!
Fran CW
Nov 17, 2008 | Sew D'Lite Lightweight Portable Mechanical...
Where does the oil go?
To oil machine.....Remove the bobbin case.Snap the two retaining arms outwards.Remove the hook race cover (circular ring ) and the hook ( half semi circular) and clean with a soft cloth.Lubricate right hand side wall ( 1-2 drops of oil) turn hand wheel a few times until the hook race is in the left position...replace hook..replace hook race cover ( smooth end to the bottom) and snap back the two hook retaining arms and insert bobbin case and bobbin.
Jan 06, 2008 | Singer 1116 Mechanical Sewing Machine
Sewing Machines Logo
12 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Sewing Machine Expert? Answer questions, earn points and help others
