Question about Husqvarna Lily 540 and 550
Switching from 110/60 to 220/50 power supply
Do i destroy my 110/60 mashine by supplying transformed 220/50.
does the electronic part stand the 50hz supplied?
  • Husqvarna Master
  • 1,388 Answers
Yes, you will need to get a transformer..try an electrical wholesaler and ask for a current converter.
Posted on May 09, 2008
I wish to take the Ellure Plus machine to India where the power supply is 240 volt. What shall I do? What is the power requirement in Watts for this machine. Your feedback is highly appreciated.
You will need to check with the instruction manual of your machine what the specifications are.
Today the 120 volt mains, I am told, is almost a thing of the past and 220 volt is much more common. The UK mains electricity used to be 250 volts but it has been lowered to 240 and eventually it will be lowered to 230 volts to bring us closer to the European specification.
Because most electrical equipment is imported and we are a minority market, electrical manafacturers didn't want to produce specail goods just for us and so for 20 years or so most of our electrical goods are suitable for use in a range of mains voltages from 220 to 240. Sometimes they are marked as such and sometimes marked as 230 volts but we are told 240 won't damage them and they will still work efficiently at 220. It is only very old electrical equipment made for 250 volts that seems slightly less efficient.
Some equipment is made for universal use and will accept 120 volt mains as well as the 220 to 240 range. In this case there is usually a provision to select a different voltage by means of a switch or by changing some simple internal wiring connections. Details of how to do this is invariably printed in the manual.
Equipment produced for 110/120 volts only would become dangerous and be soon destroyed if plugged directly into a 240 volt mains but a transformer can easily be obtained to allow 120 volt equipment to be used on 220/240 volt mains. A great many professional tools are still produced to use 120 volt electricity for reasons of safety and so auto-transformers of all sizes are commonly available and not too expensive.
I have a fairly limited experience of sewing machines but I think a domestic machine has only a very small appetite for power and a supply suitable for a reading lamp will be more than adequate. The exact wattage of your machine will be found in the instruction manual.
Apr 10, 2016 | Sewing Machines
Cs6000i. What caused it to pop and smoke?
You need to fix it. US machines are wired for 120VAC, 60Hz. Other countries are often 220V, 50Hz. Some machines have a switch that allows you to select. Some models have auto-switching power supplies that can handle either. Obviously yours did not. You most likely have damaged, at a minimum, the power supply. Once it is fixed, if it does not have a dual-voltage switch, you'll need to get a voltage adapter for it.
Nov 17, 2015 | Sewing Machines
India 220watts how I cAn use brother cs6000i sewing machine in India
The only way I know is a 110/220 volt transformer.
They are available in any electronics supply house.
As I remember the motors in these machines are only two lead, and they put the motor in for the country it will be sold in.
Dual voltage motors have three or four leads (wires).
Jul 28, 2015 | Brother CS6000i Computerized Sewing...
What is the wattage of Kenmore 385.15202 sewing
The wattge used should be listed on the machine or it's wiring. If not, you should go to ( sears.com ) and find support. I do not see a problem using an outlet there from a public power as long as you have set the unit to use the correct cycles which is normally 50Hz or 60Hz. Some electronic devices such as yours will operate on either, but you will normally have a switch to manually set which Hz setting you need. The power you recieve from the utility will be either 50Hz or 60 Hz and you will have to set the unit to match the utilities rating. Best Wishes.
Sep 01, 2014 | Sewing Machines
Change 220v to 110v
You will need a transformer. If the appliance is 220V to start with, you need a step-up tranformer, that is, 110V supply UP to 220V output. The other way round, a step-down transformer.
They are sold at hardware outlets and electronics suppliers like RadioShack.
Feb 13, 2014 | PfaFF Tiptronic 2040
SINGER Futura XL-400
220-240 volts, 50hz, 80-90w
Feb 12, 2014 | Singer Sewing Machines
I want to buy a brother pc-420 in australia, how do i achieve that?
I suggest to ,, on the internet look for sewing machine shops in your town in australia, & even look in the phone book in the yellow pages
do you have a hancock fabric in your area? they have sewing machines & sergers
Feb 11, 2012 | Brother PC-420
Bought a singer from the state but cannot be used in australia what should i do?
If it is an electronic or computerized machine, you are out of luck. USA has 110 volt 60Hz current, Australia has 220 volt 50Hz. A transformer can change 220 to 110 volts, but it cannot change 60Hz to 50Hz.
Sep 21, 2011 | Singer 4423 Sewing Machine
My machine's screen keeps turning off but the function buttons stay lit. The machine appears to reset itself randomly while im sewing and sometimes even when im not near it. Everything else seems to be...
Has your Designer 1 ever had the power supply replaced? Almost all Des 1's had a recall that was replacement of the power supply. Any Husqvarna Viking dealer will be able to check the power supply, or transformer, in your machine and make sure that it has been replaced. Sometimes this can be a loose connection inside the power supply.
Sep 17, 2011 | Husqvarna Designer I
Can I use my EuroPro 416 Sewing machine with 220V electricity?
A transformer will not change the frequency of the supply, only the voltage.
It may be possible to obtain a box of electronics to convert 50Hz to 60Hz, which would solve the problem.
A machine designed to run on 60Hz will run slower on 50Hz and may run hotter. If it burns out due to overheating, then a new motor designed to run at 50Hz should be fitted. You could have peace of mind if you fitted a new motor (which might be cheaper than an electronic frequency converter.
Jul 25, 2010 | Euro-Pro Sewing Machines
Sewing Machines Logo
258 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Wayne Fellows
Wayne Fellows
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
