Question about Garden
The clear bulb has dry rotted, need a new one
  • 885 Answers
Whether you're talking about the primer bulb or gas filter you will have to get with your local outdoor power equipment specialist to order the proper part for your particular mower and engine size.
Posted on Aug 31, 2010
6 years ago my brother bought 4 new tires from WalMart in Streetsboro, Ohio. A week ago the front left tire seemed low so I went to a Marathon station & the person in charge filled the tire but saidthis...
Sorry but even if you buy a tire and the car sits a long time in the sun that tire will dry rot. A lot of people do not know this and this is why you see camping trailers with covers over their tires in the summer because of the damage sun and weather can do.
Mar 10, 2017 | Computers & Internet
My Craftsman 17cc gas weed trimmer wouldn't start.
Hi There, Check the primer bulb for tare or pin holes. Replace it. Check and clean carb jet it maybe plugged with debree. Also check for spark which you didn't say. Replace with correct plug.
Note; Do not use strong cleaners on rubber seals (O rings and gaskets) They dry up and crack.
If needed use a dabble of grease on seals
Jun 13, 2011 | Craftsman Garden
I need to find someone who can tell me on how to replace a primer bulb on a Robi Till/caltavitor, the one that on it is dry rotted. Can someone please help me? Thank you
If you take a small screwdriver and go between the primer bulb and where it sits you will see a metal ring that holds it in, use the screwdriver to take it out. It sometimes takes a bit ou patience. Before you do any of that look around the outside that housing and look for small tabs that you push on to remove the primer bulb. New ones just snap back in. I think if you take a closer look you will see what I mean. Hope this helps. Best regards and good luck.
Jan 08, 2011 | Ryobi Cultivator
I have a Craftsman Gold 6.0 mulching mower with a B&S engine on it that has been idle for about 10 years. It was only lightly used before that and I ran the gas tank dry before putting it away. Today...
Sounds like the primer bulb dry rotted from sitting &/or the float is stuck in carb. If gas is indeed leaking from bulb. It will need to be replaced. While it is apart, clean carb inside & out with spray carb cleaner.
Sep 06, 2010 | Craftsman 675 Torque 190cc 21" RearBag...
Head lights stop working from the light switch my turn sig. button still work.
check your connection, bulbs, wires and fuses. its pretty easy just look to see if the philement in your bulbs are broken if so just get bulbs and put them in. and look at your fuse if the metal is borken get a new fuse to put in. you can also follow your wire and if there is any dry rotting of slice but a new wire and run it from your battery to your bulbs. hope this helps you
Jun 30, 2010 | John Deere Garden
TRYING TO REPLACE THE PRIMER BULB/SCOTTS PUSH MOWER
You didn't list a make or model however most of those are held in place with either two tabs or small screws and have one or two lines to them, most good hardware stores carry them such as ACE and can match it up to what you have.
Jun 07, 2010 | Garden
What will caus a primer bulb to leak gas directly from bulb on a craftsman snow blower ? I open the fule line at the tank and prime to start engin. Primer bulb leaks fule at center hole till i shut off...
Your primer bulb has a small hole in it, due to dry rot, you can take the bulb off and replace it with a new one very easy to replace, 4 screws, it is like a gasket.
Dec 07, 2009 | Audio Players & Recorders
Need digram to install fuel lines
First, you sould have one with a filter in the tank going to carb. Next run one from tank to primer bulb and from one from primer bulb to carb.
May 18, 2009 | Garden
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
john h
