Question about Frigidaire 14 cu. ft. / 396 liter Upright Freezer FFU14FC4A
We bought a new upright freezer today, and had to lay it down in order to get it home. It was lying down for about 20 minutes. How long does it have to be upright before we can plug it in?
    President:
  • 3,773 Answers
About the same amount of time that it was laying down
But the trick is to not shake the compressor and that when you
lay it down the freon lines coming out of the refrigerator should be on top or pointing up
The front should be scotched up 6 inches or so too, to help.
Good Luck
If this was helpful please rate me.
IMUFO2
Leo Ponder Appliance-Tyler,Texas
imufo2@sbcglobal.net
Posted on Aug 31, 2010
Can I lay down an Imperial Heavy Duty Upright Freezer for transport in a van or must it be upright in a pick up?
It should be upright, but if you must, after standing it up again - don't plug it in for couple of days. When it's down, oil in the pump moves quickly, but when it's upright again it takes it's time. If you plug it in too early, pump will overheats and you will need a new pump. Hope it helps.
Apr 30, 2014 | Freezers
FREEZER IS NOT FREEZING IT IS 18 MONTHS OLD. WE DEFROSTED IT AND IT FROZE AN ICE CUBE TRAY SO WE MOVED IT DOWN STAIRS PLUGGED IT N AND IT NOT FREEZING AGAIN????
It is possible to cause an air lock when moving an appliance by tilting it and then not allowing the refrigerent to settle before switching on. Try unplugging it and laying it on its side for a couple of minutes, then put it upright and leave it for 6 hours to settle, then plug it in again.
Nov 28, 2010 | Whirlpool 20 cu. ft. / 566 liter Upright...
Layed down freezer to transport in car for long journey left 4 hrs before start up working fine freezing but side edge behind door seal feels quite hot since
this is normal until all the freon has had a chance to get recirculated throgh the system.
make sure the evaporator fan is also working in order to properly cool the freezer.
Oct 09, 2010 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
My freezer was delivered in a lying down position how long before i can use?
puts the freezer in correct position and the your freezer life is 10-20 years,depends of freezer quality and freezers engine *can increase the freezer life with BEST QUALITY USING
Jul 28, 2010 | Frigidaire 14 cu. ft. / 396 liter Upright...
I just set up my Frigidaire upright Freezer, only
Rule of thumb, if you lay a frig/freezer on side let sit upright at new location for 24 hours before plugging it in.
Mar 07, 2010 | Freezers
Can we lay a freezer on its side temporarily?
You can do it but be sure to let it stand upright for 24 hours before plugging it in and using it. The oil in the compressor will run out into the lines and block it. It needs time to drain back to the compressor.
Jan 01, 2010 | Freezers
Hot exerior walls in a brand new Kenmore 28042 upright freezer
There should not be a fire hazard but you should be concerned that the freezer could break down if it is not allowed to vent the heat it produces. The freezer is not intended nor designed to be enclosed The manual must indicate specifications for minimum clearances for rear, top and sides, and may even be indicated on the big yellow sticker on the inside of the door. The clearances must be respected or again, the unit will fail, and the warranty may be voided in such cases.
Jun 27, 2009 | Frigidaire 13.7 cu. ft. / 388 liter...
I just bought a frigidaire upright freezer a week ago. I can't get a repair person to come look at it until monday. The freezer is cold on the bottom and warm at the top. I put water on the center tray and...
Since this is a new freezer it should be serviced by the people who sold it to you in order to avoid any warranty conflict. The fan blades of these units are of a slip fit onto the motor shaft. It is possible that the fan blade has come off the motor shaft.
Nov 28, 2008 | Frigidaire 20 cu. ft. / 566 liter Upright...
Moving a Kenmore upright freezer
there would be a problem if you lay it down. it should be moved up right or max 45 degrees tilt only. oil in the compressor could go to the evaporator and clog it.
front handles could be remove only from the inside. you have to remove the plastic rack of the door and remove the insulation in order to see the bolt holding the handle.
tnx 4 using fixya,
drcool
Oct 08, 2008 | Kenmore Freezers
Frigidaire 14 cu. ft. / 396 liter Upright Freezer FFU14FC4A Logo
231 people viewed this question
Top Frigidaire Freezers Experts
Charles T Nevin
Charles T Nevin
AJMAL KHAN
Dan Webster
Dan Webster
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
