Question about D-Link Xtreme N DIR-655 Wireless Router
How do I change mtu settings for dir-555...I have gone to the default ip router page and can not find it
kakee
  • 1269 Answers
SOURCE: 360 mtu test keeps failing
Using the main computer, open your Internet Explorer and on the Address Bar type http://192.168.1.1
It will prompt your for username and password. By default leave it blank on username and type admin on the password
Under SETUP tab, you can see there MTU, set it to Manual and set the size to 1400 then click on SAVE SETTINGS at the bottom.
Now powercycle your devices. Turn off router first and then modem. Wait for 30sec. Turn on modem first, wait for lights to stop blinking then turn onrouter.
That's it..
Posted on Aug 08, 2008
SOURCE: XBox 360 MTU Failed with Router
ive got ur solution right here guys...
go to start - run - type in "regedit" (without parenthises)
press CTRL+F
paste this in and search
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\Tcpip\Parameters\Interfaces
if it searches and wont find it then youll have to go folder to folder manually its not hard.
then inside of the interfaces ,
youll see a bunch of giberish numbers and letters. theres are your routers/modems/etc.
just click on each of them until you see in the right colum theres a MTU value, under the Name tab
(note some people have more then 1 MTU value so youll try to have to mess with stuff to find out which one is ur router)
K!
So we finally found our MTU.
right click it and click the decimal button.
then type what u need it to be ^_^ hope this helps..
OH btw
this was all on a Windows XP idk if it works with all comps.
and once u change the value.
restart ur comp to make the effects take place
Posted on Sep 29, 2008
XopenX
  • 108 Answers
SOURCE: RE: My posted. Connecting DSL/Router to DIR-628 internet router
Installing a router to work as the second one on a home networkrequires special configuration. Do the following on the second routerto ensure it (and the devices attached) function properly:1. Connect as local device or bridge - If connecting the second router via Ethernet cable, plug it into one of the LAN ports on the first router. If connecting the second router wirelessly, ensure the second router is set for client mode.Note that some home wireless routers do not support client mode; thesemust be connected by cable. Check your router documentation for detailson its client mode configuration support.
2. Check / change IP address - Most home network routers use a default IP addresssetting. Often, these default IP addresses will not work in a tworouter environment. Check the second router's IP address value andreset it if necessary to work within the valid address range of thefirst router (and to not conflict with any other device on the network).
3. Disable DHCP- To avoid IP address conflicts between all of the devices on the homenetwork, only one of your two routers should assign addresses via DHCP. All mainstream routers provide an option to disable DHCP as part of the router's configuration screens.
(My netgear router supports client mode. The 2wire supports bridged and router mode. My 2wire is the main router. I set up my netgear using my laptop. Once you change the address on the router.. You will only be able to directly access through the main router to the 2701.)
Configure your 2701 IP address to a static address in the 192.168.2.1 range and diable DHCP. Only 1 router can run the DHCP service. To disable Dhcp on the 2701.... log on to 2701> click on home network>advanced settings>uncheck enable DHCP>Next section is Public routed subinterface...Check enable and Aout Firewall Open>Input your main router address and mask>save config..
This worked with the Netgear router.. May not with your router. Good Luck! Hope this helps!
Posted on Jan 16, 2009
Lord_Necron
  • 15 Answers
SOURCE: i changed my dlink dir-300 router's ip address
Yes, resetting it will revert it back to factory settings (and therefore original IP address). Sometimes it is best to start over when something like this happens. ;)
Remember though, if you are configuring your router with a wireless connection you need to disconnect/reconnect to you wireless network (because you just changed it's address).
Posted on Aug 18, 2009
Geekman
  • 32281 Answers
SOURCE: I forgot my password to
To reset the D-Link back to the default settings, Press and hold the RESET button and then power up the D-Link. Hold the RESET button for 5 secs until the LEDs flash.
Now you can enter the default login & password.
Posted on Oct 31, 2010
How do i change my mtu settinggs
To change the MTU rate on your router follow the steps below:
Open your browser, enter the IP address of your router (192.168.0.1) and click OK.
Enter your username (admin) and password (blank by default).
Click OK to enter the web configuration page for the device.
Click on Setup and then click Manual Configure.
To change the MTU enter the number in the MTU field and click Save Settings.
If changing the MTU does not resolve the problem, continue changing the MTU in increments of ten.
1500 is the default MTU for Dynamic (DHCP) Cable (p. 20 in user manual).
1492 is the default MTU for PPPoE (Point to Point Protocol over Ethernet) DSL (p. 22 in user manual).
Other MTU settings are listed in the manual, simply do a search for "MTU".
Note: AOL DSL+ users must use MTU of 1400.
To find the proper MTU Size, you'll have to do a special ping of the destination you're trying to go to. A destination could
be another computer, or a URL (p. 86 in user manual).
Here is the PDF link to the User Manual:
http://www.dlink.com/-/media/Consumer_Products/DGL/DGL%204500/Manual/DGL%204500_Manual_EN_US.pdf
Sep 20, 2011 | D-Link DGL-4500 Wireless Router
How do i change my MTU settings
To change MTU settings you have to login to the router's web interface and make the required changes under WAN settings:
1.Open your web browser and type in the IP address of the router (192.168.0.1 by default).
2. Enter the username (admin) and password (blank by default), and then click Ok or Log In .
USERGUIDE D-LINK DGL-4500
Official Support Page
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
How do i increase my mtu on my d link dir 655 router?
• Open your browser, enter the IP address of your router (192.168.0.1) and click OK.
• Enter your username (admin) and password (blank by default). Click OK to enter the web configuration
• Click on Setup and then click Manual.Configure.
• To change the MTU enter the number in the MTU field and click Save.Settings to save your settings.
• Do a test. If changing the MTU does not resolve the problem, continue changing the MTU in increments of ten.
1500 is default
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
May 13, 2011 | D-Link Xtreme N DIR-655 Wireless Router
My D-link dir-825 router has been giving me poor signal
Hi Friend,
Firstly,u need to do following settings to u'rs belkin router: Default ip address of D-link dir-825 is 192.168.0.1
,so you can login to router setup page by http://192.168.0.1
1> You need to reduce MTU<Max.Transmission Unit> to 1400
2> Change wireless channel to 9/11
3> Wireless MAC ADDRESS CONTROL should be disabled for u're xbox
4> Reduce beacon interval to 50/75
5> Fragmentation Threshold:2306, RTS Threshold:2307
6> Disable the security/firewall of u're router
7> Do the port forwarding/trigerring;port numbers for xbox are:53,80,88,543,3478-3479,3658,5223,10070-10080
it will be good if u change wireless network name(SSID) as well as upgrade the firmware of u'rs router;so that it will reflect the effect & power down u're x-box while doing the changes in router.
If u need technical help in order to do the above changes in router have a words with belkin technical suppoprt.
Mar 19, 2010 | Computers & Internet
I need help changing my mtu setting for my 6212-13-200 Zhone router
For that Connect your router to computer with ethernet cable then you can access it with following default link.
http://192.168.0.1
or
http://192.168.1.1
If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it.
Then it ask for user name and password.
Type user as "admin" and password as "admin" or "password" or blank.
Then you can see configuration page of router.
Then click on WAN settings and change MTU settings then save settings and restart router.
Let me know if you need further assistance.
Thanks for using FixYa.
Mar 12, 2010 | Zhone (6218-I2-200) Router
When I type 192.168.0.1 into a browser I am taken to the www not the router. Default gateway has not been changed. I am attempting to access a D-Link DIR-655 Wireless Router.
this address is correct for ur router now u go to network connection u change ur ip address to ip automatic i think u can access to page configure dlink, if have problem email to me billy_nguyen57@yahoo.com
Jan 15, 2010 | D-Link DIR-655 Wireless Router
Need to change the MTU for my router
your router got a default IP address... find it...
Jun 16, 2009 | NetGear WGR614 Wireless Router
How do i change the mtu setting on my belkin n wireless router
You can adjust MTU from within the Belkin Router administrative console. You really should not be changing it unless your current ISP gives you a specific MTU setting, otherwise you could disrupt internet connectivity.
Default IP address: http://192.168.2.1
Default admin username: Administrator
Default admin password: <blank>
Be sure to set a password for your router!
This is the address where you change MTU
192.168.2.1/wan_pppoe.html
Belkin Wireless G User Manual:
http://www.belkin.com/support/article/?lid=en&pid=F5D7230-4&aid=5999&scid=221
Windows Tools to adjust MTU:
DrTCP tool:
http://www.dslreports.com/drtcp
TCP Optimizer
http://www.speedguide.net/downloads.php
Jun 09, 2009 | Belkin (F5D7633UK4A) Wireless Router
Can´t connect to certain sites
Step 1 Open your browser, enter the IP address of your router (192.168.0.1) and click OK. Step 2 Enter your username (admin) and password (blank by default). Click OK to enter the web configuration page for the device. Step 3 Click on the Home tab and go to the WAN tab. Step 4 The default MTU is 1500, to change this enter the number in the MTU field and click the Apply button to save your settings. Step 5 Test your email. If changing the MTU does not resolve the problem, continue changing the MTU in increments of ten.
Feb 16, 2006 | D-Link Express EtherNetwork DI-604 Router
D-Link Xtreme N  DIR-655 Wireless Router Logo
471 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
