Question about HP Pavilion dv9000z Notebook
The S-Video Cable
I have Windows Vista on the laptop..................
I checked to see if I might have the cables , but both sets I
have don't enclude the part that connects to my laptop
so I have to go and buy it today at bestbuy or radio shack......whichever one is cheaper lol..............
thank you for all of your help
  • dsingh3796 Aug 15, 2008
    I will as soon as I can afford to go out and buy a tv card for my laptop.........with only one income I have to be very wise with my money
    Thanks for all your help
    It is muchly appreciated !!
    Deb Singh
    Deb Singh
  • 1,031 Answers
If you buy it and fix it ,if any futher problem you let me know
Posted on May 13, 2008
  • 1 more comment
  • Starnley Johnwells
    Starnley Johnwells May 21, 2008
    any more problem with it
    Starnley Johnwells May 22, 2008
    Get a TV card (USB or PCMCIA); plug an AV cable from the back of the VCR to the TV card, then use the software supplied with the TV card to write the input to an AVI file... The playback has to be 1 to 1,
    Once you have an AVI file,write the AVI to a DVD using any DVD, or VCD creation software... If you want multiple copies copy the DVD, don't re-write it from the source material (it is quicker)... And then delete the source A
    If you don't have a TV card but have a digital camcorder see if it supports AV-IN. When you do this go to the VCR to the camera then to a firewire port on the PC. The camera acts as a bridge. Get very good results this way.
    Starnley Johnwells Aug 15, 2008
    have u tried that ?try it and get back to me
Screen on laptop is distorted halfway
A) Video Cable connections are loose:
Connection at the motherboard, and the connection at the back of the LCD screen, in the Display Assembly.
Both need to be checked.
[For Toshiba the Video Cable is termed LVDS Cable.
Low-Voltage Differential Signaling Cable. I will just keep referring to it as the Video Cable ]
B) Video Cable is damaged:
Observe the sheath at the motherboard side of the Video Cable?
Is there obvious signs of damage to the sheath of the cable?
If so, there may also be damage to the tiny, thin wires inside the sheath, of the Video Cable.
Due to the routing of the Video Cable under the left Hinge, the Video Cable may be pulled on. This can create a bad connection.
Due to the above also, the Video Cable's sheath may be damaged, and the wires inside.
A view of the Video Cable by itself,
http://www.batterystyle.com/toshiba-satellite-a205-s5880-cable-p-484063.html
If the Video Cable checks out to be OK, the next item is the screen Inverter.
To test a screen Inverter you need a sensitive multimeter. This usually means expensive. { Or use a known to be good, compatible screen Inverter } Just thought I would state that. Don't want you to completely disassemble your laptop, just to fix a Video Cable, or screen Inverter. {Or LCD screen)
Most consumers decide to just replace the screen Inverter because;
1) If the problem isn't the screen Inverter, it is the LCD screen.
(A LOT of people buy an LCD screen, when all they really needed was a screen Inverter)
An EXPENSIVE part.
(LCD screen? $150 to $400 approximately. Screen Inverter? Usually around $22 to $48 )
2) The ease of access to replace.
As stated, if the problem isn't the screen Inverter, then it is the LCD screen.
1) With ALL power removed, AC adapter (Charger), and Battery, remove the Keyboard Bezel, and the Keyboard.
This is the motherboard connection side.
Display Assembly removed with Video Cable.
Now remove the Display Bezel, and LCD screen assembly, to access the Video Cable connection to the back of the LCD screen.
{NOTE*
The screen Inverter is mounted at the bottom of the LCD screen, and behind the Display Bezel }
This shows the Video Cable, and it's connection at the motherboard side,
http://www.irisvista.com/tech/laptops/toshiba-satellite-a205/laptop-disassembly-2.htm
Scroll down, click on the photo in Step 9.
The Video Cable is the cable to the upper Left side. Has one Red arrow pointing to the left.
The photo in Step 10 shows the Video Cable disconnected from the motherboard.
(This is Page 2 of a disassembly guide. Pages 1 through 4 are available above, and below. Page1::Page2::Page3::Page4::Find another model,
in white.
Just thought I would state that. Don't want you to completely disassemble your laptop, just to fix a Video Cable, or screen Inverter, or LCD screen) )
2) LCD screen side:
http://www.irisvista.com/tech/laptops/toshiba-satellite-a215/disassemble-display-panel-4.htm
http://www.insidemylaptop.com/remove-lcd-screen-from-toshiba-laptop/
All three links above will help you with checking the connections, or removing the cable to perform a continuity check. (Test)
Also with accessing the screen Inverter, and LCD screen.
For additional questions please post in a Comment.
Regards,
joecoolvette
Jan 25, 2012 | Toshiba Satellite A205-S5880 Notebook
HDMI cable stops displaying an image after 15-20 minutes
The problem could either be with the HDMI cable or with the (either tv or laptop connection ports). There could be a few other factors to consider, but I would try a new cable if you happen to have one lying around.
Jun 28, 2017 | Insignia 37" LCD Flat-Panel HDTV
I have picture package 1.5 but when i want to convert the tape to cd, i can not select the source and target is there a patch for this ? This for DCR-HC32 E Also i have now bought a new laptop which has...
The supplied Picture Package software is not compatible with the Vista Operating System.
Option 1:
If you want to use the USB cable to connect the Camera to the Computer to transfer the video to the Computer then:
(Applicable for Vista Operating System Only.)
This Camcorder does not support USB streaming with the VISTA Operating System. Use an i.LINK cable to transfer the video to the Computer. The i.LINK port is also called IEEE 1394 or Firewire port. (An i.LINK is a black D shaped connector with 4 or 6 pins. The type of cable to be used will depend on the i.LINK port of your Computer. The Sony Camcorder will have the 4 pin i.LINK cable and if the computer has the 6 pin i.LINK port, then you may have to use the 4 pin to 6 pin i.LINK Cable).
You can use any video capturing software like Windows Movie Maker to transfer the video from the Camcorder to the Computer.
Refer this Link for the instruction to transfer the video to the Computer using i.LINK cable.
http://www.kb.sony.com/selfservice/documentLink.do?externalId=C111893
NOTE: As the Camcorder does not support USB streaming with Vista, it is not required to use any Sony Device Driver to transfer the video to the Computer. You do not require any Drivers or Software from Sony to transfer the video from the Camcorder to the Computer using the i.LINK/Firewire interface.
Option 2:
(Applicable for Windows XP Operating System only):
If you are using a Windows XP Operating System then you have to install the USB Streaming Driver in the Computer from the supplied Software disk with the Computer.
Check this Link for the instruction to transfer video to a Computer using USB Streaming.
http://www.kb.sony.com/selfservice/documentLink.do?externalId=C222820
If you do not have the supplied Software disk then I suggest that you use the i.LINK cable to transfer the video.
Good Luck!!!!!!!!!!!!!!!
Sep 18, 2009 | Sony DCR-HC32E DV Digital Camcorder
Can't upload to my laptop!
Option 1:
You can use any video capturing software like Windows Movie Maker to transfer the video from the Computer.
Option 2:
Your Camcorder does not supports a Wireless MIC. However, you can use a MIC with your Camcorder using the available Accessories Shoe port.
Sep 18, 2009 | Sony Handycam DCR-PC110 Mini DV Digital...
How to capture videos by DCR-HC30 in a laptop
This Camcorderdoes not support USB streaming with the VISTA Operating System. Use ani.LINK cable to transfer the video to the Computer. The i.LINK port isalso called IEEE 1394 or Firewire port. (An i.LINK is a black D shapedconnector with 4 or 6 pins. The type of cable to be used will depend onthe i.LINK port of your Computer. The Sony Camcorder will have the 4 pini.LINK cable and if the computer has the 6 pin i.LINK port, then you mayhave to use the 4 pin to 6 pin i.LINK Cable).
Refer this link for the instruction to transfer the video to the Computer using i.LINK cable.
NOTE:Asthe Camcorder does not support USB streaming with Vista, it isnot required to use any Sony Device Driver to transfer the video tothe Computer. You do not require any Drivers or Software from Sonyto transfer the video from the Camcorder to the Computer usingthe i.LINK/Firewire interface.
Applicable for Windows XP Operating System:
If youare using a Windows XP Operating System then you have to install the USBStreaming Driver in the Computer from the supplied Software disk withthe Computer.
Check this link for the instruction to transfer video to a Computer using USB Streaming.
Sep 09, 2009 | Sony Handycam DCR-HC30 Mini DV Digital...
I just connected my new Kworld PC/TV converter. My tv now displays large vertical color lines. I,ve connected the yellow video cable, s-video cable and the red/green/blue cable. I have a new Toshiba...
Hi and welcome to FixYa,
Initially, a couple of checks:
  • verify that the P/N switch is set to the color system of your country. N (NTSC) for US and P for most of Euroope and Australia;
  • depending on how "old" the TV, the Screen Resolution of the Toshiba may have to be brought down to the lowest possible setting;
  • additionally, the Screen Refresh Rate may likewise need to be lowered say 60 Hz;
  • all of the connections you mentioned are video connections. However, only 1 should be used. You may have to experiment (again depending on the TV) which setting & connection would give you the best picture;
  • offhand, the component connection (if applicable, the red/green/blue cable) would give the best connection followed by S-Video and last would be yellow (composite).
Please postback results of initial checks.
Good luck and thank you for asking FixYa.
Aug 07, 2009 | KWorld PC to TV (0872880887527) Video...
Problem with compatibilty between windows vista
since you're using vista you can connect camcorder to pc uding ilink or firewire cable. usb conection would not work. no dirvers or sofwtare needed, you can use windows movie maker to capture videos. check your computer for any ilink port. it is a different connection from usb. go to www.sonystyle.com and type this model number, vmcil4615, for you to have an idea what firewire cable looks like.
Mar 22, 2009 | Sony Handycam DCR-HC14E Mini DV Digital...
Digital camera not recognised by windows vista
It may be that the drivers for the Camera are not compatible with Vista. Did you update the Vista drivers.
Can you not detect via USB cable?
Mar 06, 2009 | Panasonic Lumix DMC-LS80 Digital Camera
DVD from laptop to computer
MaionP:
you need to connect your TV to your laptop with the audio cable as well. A simple S video cable will only gives you video. You can buy a simply audio video cable and use the audio output from your laptop to your TV and keep on using the S video for video.
Or you can use simple external laptop speakers to gives you sound with your TV output.
Hope that helped!
Dec 09, 2007 | Computers & Internet
HP Pavilion dv9000z Notebook Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
