Question about Toshiba 2060 Copier
I have a Toshiba 2060. Runs great except for one issue. The cartridge has the paper oriented landscape with the label LTR. When I copy using the eith the ADF or platen glass and the paper is also oriented landscape, it works just fine. However, if the paper is oriented portrait on the ADF or platen glass, it still prints landscape,but with an image that has not been rotated to match. Is the sensor bad? Does it need to be cleaned? Is it disconnected or shut off? Where do I find it, and is it accessible to a novice like me?? Keith
    Sniper:
  • 66 Answers
As far as I know the Toshiba 2060 does not have an auto rotate function. This means that whatever drawer you pick to copy from is what the scanner will scan. To change which way you copy your sheets you will have to change the physical size of the drawer to copy the other way.
Posted on Aug 31, 2010
  • nmrspc Aug 31, 2010
    Profactorate,
    Thanks. However, the previous owner indicated that it used to orient the copy print, whether the original was landscape or portrait, to the page as specified in the cassette. It stopped doing so roughly 1 month ago.
Canon imageRUNNER 2200 paper tray 1 shows empty when it is full. Using letter paper with portrait orientation. Dial is set correctly for letter (LTR). (tray 2 is letter in landscape orientation. Dial is...
Please check that there isn't any paper jam behind the tray in the machine, this will block the connection from the tray to machine and prevent the paper lift mechanism from raising up into proper position. Hope this helps.
Oct 14, 2011 | Canon imageRUNNER 2200
Toshiba 2060
i would buy new lazor toner 1st cartridge to see if yoru s bad or out
Jan 19, 2008 | Toshiba 2060 Copier
Tray 1 has defaulted to a landscape orientation--cannot find a way to redirect it to portrait. NOT an issue with placement of paper to be copied.
There's a dial on the front right corner on each paper tray that tells the copier which paper size is loaded in that tray. In the case of letter size paper it also indicates orientation. If the short edge is facing the front of the copier the dial should be on LTR, if the 11" edge is closest to the front the dial should be set on LTRR.
Aug 25, 2011 | Canon imageRUNNER 4570 Copier
My Cannon ImageRUNNER 2270 is not printing the entire page. It is cutting off the top quarter of the page. I have changed the margin settings and it is not doing anything different.
Check to make sure that the paper size dial on the paper cassette is the same as the paper size in the cassette. Portrait or landscape? I don't know whether you use American sized paper but the dial Must be LTR ( front to rear orientation of paper ) or LTR-R ( Left to right orientation ). I know of no other reason for the problem.
Jun 19, 2011 | Canon imageRUNNER 2270 Copier
Toshiba 2060 will not print 1/2" from top side with letter paper
Have you tried the manual feed tray? Which way is the letter size paper being feed in? LTR or LTR-R. You may have a reg. clutch that is slipping. I would also look to see if you have any paper jamed behind the paper tray and make sure the paper trat is displaying that ltter paper is in the papre tray the same way as displayed. Good Luck
Feb 02, 2009 | Toshiba 2060 Copier
Canon imageRunner 5055 copying in landscape instead of portrait
Double check paper orientation when you put paper into the feeder and how the paper is loaded.
The orientation of the page in the feeder and the page in the drawer should match.
Dec 16, 2008 | Canon imageRUNNER 5000 Copier
A4 R shows in the window
A4 is referring to a europpen size paper. You may have some paper jamed behind the paper tray. You will have to take the paper trays out and look in side for some paper jamed in the rear part of the copier, remove and you should be set..
Sep 10, 2008 | Toshiba 2060 Copier
Landscape copies get stuck
The roller may have something stuck in that area, something even as small as a peice of paper can continue to make it jam. if not, you may have to call the company to get a repair guy in... umm... or repairGirl?
May 17, 2008 | Toshiba 2060 Copier
Toshiba 2060 marks on papaer
There is no such paper for copiers that I know of in 18 years. What you can do is try to run some blank pages throw the copier. This can tell 2 things if the line gets lighter in may be in the fixing ***'y and the upper fusing roller is shoot, needs to be replaced and or if it dose not clear up you may need a cleaning blade for the drum(OPC) and or the drum and blade as a set. It depends on how old the parts are? You may need to replace all 3 items and a general cleaning. Here is a idea for you are you running LTR or LTR-R you may be able to switch the paper arould to avoid the line all togather. Good Luck.... You may need a service call on the copier. With the age of the copier I might just go with the cheap fix first.
Mar 12, 2008 | Toshiba 2060 Copier
Copier Orientation
clean the three paper selection sensors on the feeder.better you select the paper tray according to the paper orientation instead of using auto paper slect function
Nov 21, 2006 | Ricoh Aficio 2027 All-In-One Laser Printer
119 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
