Question about Toshiba e-Studio 350 Copier
Toshiba estudio 35
My copier is printing light.  I have checked the setting, replaced toner cartridge and I am unable to fix the problem. Any suggestions?
  • 3 Answers
First, make sure the bias contact on the bottom of the developer is touching the bias contact on the frame of the machine. Second, look at is if the drum ground terminal (inside the drum), is it actually touching the drum shaft? If not the drum will overcharge and give light copies as well as pulling the developer which will fill into the waste bottle quickly. One last thing to check is the optics. Make sure they are spotless.
Posted on Oct 29, 2008
  • 62 Answers
What is the copy count on the machine?
Toshiba copiers have service intervals to replace the drum, cleanerblade, corona wires and developer material.
That could resolve your printing problem.
Posted on May 11, 2008
How do i reset toshiba estudio 181 printer if the replace toner light keeps staying lid even when i put a new toner
Is nothing to reset, you must verify if the toner sensor is not dirt with toner. Best regards,
Dec 06, 2014 | Toshiba OEM ESTUDIO181 18 CPM/PPM...
Toner cartridge is not recognized
some copiers will not recognise any toner cartridge other than genuine units It is a way of making you buy their products only. Check that out first .
Jun 22, 2013 | Toshiba Estudio 200L Copier
Copies not dark on copy machine
check your print quality settings, your settings may be in draft mode. if correct, I.e. document or picture, check and replace your toner, printer cartridge
Dec 18, 2012 | Toshiba Estudio 200L Copier
I have replace ma toner now indicator is showing toner not recognised please give me some solution
Did you get your toner from an authorized toshiba retailer? If not and you bought recycled toner cartridges, tough luck. You've probably just destroyed your machine.
Dec 13, 2012 | Toshiba estudio 255 Copier
Toshiba estudio 450 Used toner cartridge is empty and I have put it back in but machine keeps stating to dispose of used toner...replace the ic of toner cart. is till problem how will solv..?
Hello
You will have to remove the waste toner bottle, put some cleaning solvent in the bottle and wash the toner out of the bottle.
Please the bottle out to dry before you replace it in the machine.
Regards
Jul 24, 2011 | Toshiba E-STUDIO 450 Copier
Toshiba e studio 170f error message, toner not recognized
maybe the roner cartridge you inserted is not supported by Toshiba e-Studio 170f. This may be one of the reasons that the machine can't recognize the toner cartridge.
Reinstall the toner cartridge that you have. If that doesn't fix the issue try to replace the toner cartridge with new one.
If you continue experiencing this issue contact your technical support team.
Jun 19, 2011 | Toshiba EStudio 170f Fax 170f
How to clear toner message on estudio 200 toshiba copier
Did u mean toner low message?
If the message still occur after u replaced new toner, then try to pour out some powders from the developer unit.
Jun 24, 2010 | Toshiba Estudio 200L Copier
Refill toner cartridge
The toner cartridge is designed to dispose once finish... Not recommended to modified and refill...
Feb 17, 2010 | Toshiba E-Studio167 Copier
Toshiba e-Studio 350 Copier Logo
250 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
