Question about Fahrenheat Heating & Cooling
Hi I have a model FFH-BB and the heater component doesn't work anymore
F2 ERROR
F2 04 Content Improper cartridge (Destination error, life cycle
error)
Detail The destination of the machine differs from that
of the CRUM.
The life cycle information is other than "Not
used (FFh)."
Cause CRUM chip defect
Improper developing unit
Check
and
remedy
Replace the CRUM chip.
Replace the developing unit.
Identificat
ion error
The trade mark code of the CRUM differs.
The company code of the CRUM differs.
Model
error
The boot program model code does not
coincide with the CRUM model code.
Type error When the CRUM type is other than genuine/
conversion/production rotation.
Destinatio
n error
The machine destination differs from the
CRUM destination.
Data
abnormali
ty
When an error value is included in the initial
check information. When the max. toner supply
time is 00.
When the print hard stop is 00.
Misc error When the Misc information is other than "Not
used (FFh)
Feb 10, 2014 | Sharp AR-5316 Advanced Digital Imager...
Solution for f2 error code
F2 - 04 : Improper cartridge (Destination error, life cycle error)
Detail : The destination of the machine differs from that of the CRUM.
The life cycle information is other than "Not used (FFh)."
Cause : CRUM chip defect - Improper developing unit
Check and remedy : Replace the CRUM chip - Replace the developing unit.
Identificat ion error : The trade mark code of the CRUM differs.
Model error : The boot program model code does not coincide with the CRUM model code.
Type error : When the CRUM type is other than genuine/conversion/production rotation .
Destination error : The machine destination differs from the CRUM destination.
Data abnormality : When an error value is included in the initial
check information. When the max. toner supply time is 00.
Misc error : When the Misc information is other than "Not used (FFh)."
Oct 20, 2012 | Sharp AR-M160 Laser Printer
My bb 8520 curve doesnt want to boot past that blackberry logo on start up , whn i try to load OS using application loader it gives mer an errror message that its cant read the device pls help
Hi there!
Try pulling the battery out while your BB 8520 is switched on. Hold the power button for 30 seconds before connecting the battery back. turn on your phone and reconnect it if it asks you to reconnect. If this doesn't work, I suggest bringing it to a qualified technician.
Hope this helps.
Apr 28, 2011 | Cell Phones
None of the keys on blackberry 8900 is working
The issue you describe appears to be either a software or hardware-related problem. Below you'll find 2 solutions to help determine what type of issue it is and how to resolve it.
A. Software: corruption of one or more system files within the BlackBerry OS. A forced update should restore your BB to working condition, but there is the risk that you may lose your data. If that is a problem, do not proceed.
If you wish to restore the BB, please continue below after verifying that you have the following:
A. Computer (Windows) B. BlackBerry Desktop Manager software (BlackBerry.com) C. Latest version of the BlackBerry OS for your make/model BB
To get the OS, simply logon to your carriers website and download the latest version of the OS for your BB. Once the file is saved to your computer, you need to install the setup files just like you would anyother program. When completed, proceed to step #1.
1. Open BB Desktop Manager 2. Remove the battery cover, battery and microSD card (if you have one) from your BlackBerry. 3. Connect the BB to your computer via USB cable (without the battery in place, just the phone's shell). 4. There should be a few drivers that will load automatically and the BB DesktopManager will recognize your BB. 5. Close the BB Desktop Manager once it has been detected. 6. Go to the following path. C:\Program Files\Common Files\Research In Motion\AppLoader 7. Double-click the "AppLoader.exe" application 8. Once it loads, the application will detect your BB and proceed to update your BlackBerry's OS. 9. If you are prompted to backup your BB data, please do so. If not, then proceed to step #10. 10. Select wipe (or secure wipe) to completely remove the existing OS and data.
A fresh, updated version of the BlackBerry OS will be installed on your BB. The process takes about 35-90 mins to complete. Once done, the BB will automatically reboot and if you had an existing backup or created one before wiping/installing, you can now reopen the BB Desktop Manager and restore your backup to the BB.
B. Hardware: The keyboard component has lost its tactile feedback and become faulty or the logic board (what stores the information and interconnect for the BB device) has become faulty and no longer responds to key presses).
In the event of a hardware malfunction, the solution would be to replace the failed component. A replacement keyboard costs $15-45 depending on make/model and can be replaced simply by removing the old keyboard and swapping it out for the new one. A logic board replacement is more expensive around $135-$200 because of the nature of the device. It is the central interconnect or "heart" of any mobile device/computer, as such, it is essentially viewed as buy a new device due to the cost incurred.
Aug 11, 2010 | Cell Phones
Need to replace part. Short-irratic off/on. Where can I get it?
theis is the safety swith that senses overheating. If the fanmotor cuts off and the heater elements don't, this switch will sense excessive heat and open the circuit for both the heater fan and the heater element(s). If it is "shorted" it is because it is cool and not needing to activate to interrupt the power. The problem I am having is that the switch opens prematurely after just a coule minutes of operation. the unit has to cool down befoe it wll cycle on again for just a few minutes.
Trying to find the part nubmer for the switch.
Apr 26, 2009 | Fahrenheat (FFH1614) Wall Mounted Panel...
Frost on back wall of freezer, side by side, wont freeze
It's most likely a defrost issue. One or more of your defrost components have failed. Defrost components are defrost thermostat, defrost heater, and defrost timer or board depending on model
Nov 21, 2017 | GE (PSS26MSRSS) Side by Side Refrigerator
FFh Series FFH1614
http://www.marleymeh.com/develop/prod_pdf/instructs/5200-2638-000.pdf
Jun 14, 2008 | Fahrenheat (FFH1614) Wall Mounted Panel...
No Service (after several minutes searching for carrier)
Sorry Diego...
Unlocking can be risky sometimes... just remember that "battery in and out" is the only way to properly reset the device.
Sorry I could not be more helpful. :)
Jan 11, 2008 | RIM BlackBerry 7290
Heating & Cooling Logo
32 people viewed this question
Top Fahrenheat Heating & Cooling Experts
Paul Carew
Are you a Fahrenheat Heating and Cooling Expert? Answer questions, earn points and help others
