Question about Mtd 22" Yard Machine Push Mower
My 22" MTD Yardman push mower runs too slow to cut much grass. How can I adjust it to run faster? It has no speed selection that I know of, only the handle bar that must be held tight to keep it running. Air filter is clean. Oil level is full.
  • Skully Alley jr. Jun 07, 2013
    not very helpful if he has the same problem I have
  • 885 Answers
These inexpensive mowers are not made for large scale mowing. They're set to run as fast as they do and have low compression (read that as low power also) to make them easy to start and operate. About the only thing you can do to make it work better is keep the air cleaner clean, use fresh gas and keep the blade sharp so it cuts the grass easier. Mowing more often also means less cuttings under the deck so it works more efficently.
Posted on Aug 31, 2010
Yard man riding mower
By crossing the terminals on the solinoid you have taken this component out of the picture, so the problems has to be in the engine or the starter, if the auto deco valve in the engine is not working the engine will be sluggish to crank over.
Sep 28, 2013 | Mtd Garden
I have a mtd yard man 22inch / mulcher . My question is how do I get the mower to start mulching ?
For mowers like yours, there are straight cut discharge blades (for bagging the grass) and there are more expensive upswept mulching blades. Any holes in the sides of the deck must be covered to mulch as the blade keeps the grass up in the air under the deck, repeatedly cutting it...over and over..till it falls on the ground.So use a solid deck with the upswept type blade.
Aug 31, 2010 | Mtd 22" Yard Machine Push Mower
I have got a MTD push mower Model no, 11A41MB029 SerialNo. 1i158K70951 It starts just fine and Idles fine too. The problem is that is does not speed up when cutting grass. This model has a choke if...
There are 2 things and whitch carb,one has a diafram ,I dont think that is yours, your has a bowel on the the carb take 7/16 wrench remove your bowel on the carb clean it out,and some the bottom bolt is your jet you will have to clean it out,
Aug 13, 2010 | Mtd 22" Yard Machine Push Mower
Why do grass get stuck in lawnmower than it starts to turn off
This can be happening from a couple of reasons, first if your grass is too damp this will happen with almost any mower, wait till the lawn dries out before cutting, you may be cutting the lawn when it is too high, try cutting it twice a week maybe this will help, you may try to raise the cut setting eliminating the amount of grass clippings that you have accumulated, if you are mulching or using the bag be sure the chute is clear, and lastly be sure you are running at a higher speed to push through the terrain.
Happy Mowing!!
Jul 14, 2010 | Mtd 22" Yard Machine Push Mower
I have a yardman 46 in cut riding mower, it is leaving grass in the middle. I have put new blades, change the belts, put on a new tention spring, so what is my problem?
Well one of the spindle assemblies, could be running a little slower on one side then the other. But I would take a guess that you are trying to cut grass, way too fast for the mower. Try running a ground speed a liitle slower and see what happens.
Good Day.
Oct 07, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Briggs & stratton 4hp push mower
why dose my motor cycle up & down in rpms
Jun 01, 2009 | Mtd 22" Yard Machine Push Mower
MTD Yardman push mower runs fine for awhile then cuts off.
Try buying a new plug first but if it continues then I would say that there is debris in the carb.
Apr 04, 2009 | Mtd 22" Yard Machine Push Mower
Mtd 22" Yard Machine Push Mower Logo
686 people viewed this question
Top Mtd Garden Experts
Roland W VanLue
Roland W VanLue
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
