Question about Samsung SyncMaster 720N Monitor
Samsung syncmaster 720 n
Hello!
First of all sorry for the bad English.
Every 5 seconds on my monitor appears "Auto adjustment", and i can't turn it off! What is the problem
  • 2 more comments
  • sashamk May 10, 2008
    no it is not, that's the nervous part :)
  • Anonymous Jan 03, 2009
    i have got the sam problem and its really annoying
  • edwinrajasin Jan 07, 2009
    I'm also suffering from the same problem for past 8 months & what is the solution
  • mohsen Apr 27, 2013
    hi-I want know 720n monitor whats abilitis?
    Guru:
  • 859 Answers
Is the auto adjust button stuck?
Posted on May 10, 2008
  • Glenn Rogers
    Glenn Rogers May 11, 2008
    Sounds like your monitor has a bad chip. Hope you can get it fixed under warranty.
Hello sounds the same problem to me! In my monitor has stucked the magic bright, and it goes from Costom to Text Internet and Entertain and just keeps replacing, but i cant control nothing i cant even turn of my monitor!! Plz help!
Posted on Jun 30, 2010
Mine is stuck saying "brightness" 24/7 is my button stuck, how can i fix it
Posted on Aug 30, 2008
I had the same problem. when i turn on the monitor, it appears "auto adjusting" and goes off. solution: replace the front panel buttons for on/off in my case.
Posted on Feb 08, 2009
I have a samsung syncmaster sa10. The monitor screen needs to be adjusted to the right. How do I make the adjustment?
I will admit, have never seen you monitor before. But looked up in Google and found this. Hope this helps.
1 Press and hold the power button for 5 seconds. Then a menu should appear...
2 Press and hold it until it is over AUTO. Then tap the button once.
Let us know if it helps. It would not break your monitor to do the above. But be patient and follow the above simple procedures. This could help others same as you.
Jul 01, 2014 | Dell E173FP 17" LCD Monitor
My brightness menu is locked on the screen and my monitor buttons aren't working .. I'm having a silver Samsung Syncmaster 720N.
OSD Lock & Unlock
When pressing the AUTO button after locking the OSD
When pressing the MENU button after locking the OSD
This is the function that locks the OSD in order to keep the current states of settings or prevent others
from adjusting the current settings.
Lock : Hold down the MENU button for more than five (5) seconds to activate the OSD adjustment
lock function.
Unlock : Hold down the MENU button for more than five (5) seconds to deactivate the OSD adjustment
lock function.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
May 10, 2011 | Samsung SyncMaster 720N Monitor
Auto Adjust is locked. how to unlock this.
hold down the menu button for 5 seconds and the menu will be unlocked
and also if u have installed the software for the samsung monitor through a cd or floppy disk than ... control panel> display>settings>>open the "advance " check the ptions, but be carefull not to adjust other settings...and hit ok
Feb 05, 2011 | Samsung SyncMaster 760vTFT Monitor
Cant get it off autolock feature
dear you press the menu button for 5 seconds then your auto adjust option will be released and you want to lock it again then press again menu button for 5 seconds then auto adjust option will again locked.
Jul 10, 2010 | Samsung SyncMaster 710m 17" LCD Monitor
AUTO ADJUSTMENT LOCKED BOX FLASHES ON THE SCREEN ALL THE TIME.
Depends of what seems to be a problem.
If you want to get rid of that message box, appearing by itself, then probably you need to take front panel PCB with buttons and replace "Auto" one, 'cause it's stuck.
If you want to unlock an Auto Adjustment and other functions in your monitor, then press and hold 'Enter' button for 5 seconds.
Sep 14, 2009 | Samsung SyncMaster 17" LCD Monitor
Problem with brightness of monitors SyncMaster 710n
HelIo! right after computer inclusions on the monitor screen have a tablet with the message which disturbs to work. The message: brightness of the monitor of 100 %! A problem: how to clean from the screen this tablet so she prevents to read the information. I have not found adjustment in the menu of the monitor brightness. And what should be brightness: 100 % or another? have not found adjustment in the menu of the monitor brightness. And what should be brightness: 100 % or another?Thanks and sorry about my bad english. Afzal.
Sep 06, 2008 | Samsung SyncMaster 710N 17 in. Flat Panel...
Auto Adjust box keeps appearing
check the section of command.check frontpanel switchs and components related with it. if it dont work then change memory ic.
Mar 21, 2008 | Samsung SyncMaster 174V 17" Flat Panel LCD...
Auto adjastment locked
Samsung implements protection into their monitors, which allows to block all settings except brightness and contrast. This "Locked" mode turns on by pressing and holding 'Menu' button for 5 seconds, and turns off by pressing and holding 'Enter' button for 5 sec.
Mar 02, 2008 | Samsung SyncMaster 193V 19" Flat Panel LCD...
Samsung SyncMaster 720N Monitor Logo
2,821 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
