Question about Caterpillar American Construction Equipment 1:87 Scale
I have a cat gp25 forklift. Through the day it starts getting almost into the overheating red range on the temp gauge. Coolant level is fine and it was just serviced too days ago. Temp where we live is between 70-90 degrees f.
Temp gauge says cat is overheating, but it's not hot and doesn't smell like antifreeze
By cat I assume you realize this is a warning for an overheating catalytic converter not the engine, the Cat is locate in the exhaust system and can cause a fire.
Mar 28, 2017 | 2005 Hyundai Accent GLS
could be the engine temp switch , have the OBD codes read this should tell you what ,if any where the fault is
May 21, 2014 | 2005 Hyundai Accent GLS
I have a 2003 alero with the v-6 what happened was driving down the road the heater works fine. then all of a sudden it was blowing cold air and the temp gauge started climbing. it started blowing how air...
Sounds like the water pump is cavitating . Replace water pump. Check coolant level also. Open the bleeder valve usually located on thermostat housing to remove air from system. close valve when coolant is present while filling. close radiator cap and top off recovery bottle to correct level. These engines are prone to overheating, do not let temp gauge get in the red.
May 01, 2017 | 2003 Oldsmobile Alero
My 2003 yamaha yzf 600 seems to be overheating. I was riding the other day and fan was kicking on just before it got in the red on temp guage is this normal.
Hi, John and the usual suspects are:
1. Low coolant level.
2. Restricted radiator air flow.
3. Faulty thermostat.
4. Coolant pump or fans inoperative.
5. Vent hose crimped.
6. Air in the coolant and needs bleeding.
7. Engine idling too long or bike moving too slow.
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
YZF600R Forums View topic overheating
Help Please 03 YZF600R overheating issue
Yamaha YZF600 YZF600R 1994 2007 Service Repair Manual PDF Download Manuals...
OEM parts for Yamaha
Yamaha YZF600RP Owner Manual
Jun 10, 2012 | 2003 Yamaha YZF 600 R thunder cat
1998 subaru forester overheating heater blows cold air
Any chance of a head gasket leak? Is the coolant level still full? These were known for head gasket issues. Coolant is a closed system and level will not drop unless there is a leak. Make sure there is no air in the system. Replace the radiator cap to make sure that it is operating properly.
Mar 02, 2017 | 1998 Subaru Forester
I have a 1994 325i conv. the temp gauge cycles between normal operating temp and overheating as i'm driving.a few minutes in each range.could it be the radiator.blocked passages? is this common to older...
my 528i does, or did the same thing. Overheating is bad for those aluminum cylinder heads. 1st, replace the coolant. Then check to see if the electric cooling fans work, or cycle on, they most certainly would have to cycle on when the temp gauge is in the red zone.
1st thing most people do is replace the thermostat. However, if the temp goes from overheating to not overheating in less than a minute, the thermostat is working. The key thing to look for is why did it get to the red zone in the first place.
Nov 30, 2009 | 1994 BMW 3 Series
Temp light illuminates,temp gauge at half way,car not overheating
check your coolant level. half way on the guage is normal
Nov 08, 2009 | 1995 Volvo 850
97 saturn sl2 temp light flashing and low coolant light flashing what could be the problem ? coolant is full and the heat works.
If the temp gauge is reading normal, the lights are flashing, and the coolant level is full, the level sensor in the coolant bottle is the problem. I'm a service consultant for a Saturn dealer and I've run across this many times.
Apr 17, 2009 | 1997 Saturn SL
Overheating
Is the car actually overheating or are you just getting a red temp symbol on the dash? What does your temp gauge say? If it is indeed overheating and they did replace all the parts you say they did, they probably didn't bleed the cooling system properly. If any air is trapped in the system, it will cause a overheat condition. Take it back and tell them to bleed it right. Make sure they tightened up your radiator overflow/fill bottle cap as well...turn it until it "snaps". Now if the car is not physically overheating, and the temp gauge shows normal with the needle straight up (~190F), but you show a red temp symbol on the dash, your coolant level sensor in the overflow/fill bottle cap could be defective, the harness that plugs into it could be loose and/or your coolant level is too high. Lower the level until it is in the cross-hatch area printed on the bottle and reseat the connector. If it still has the red temp symbol, chances are very good the sensor in the bottle went bad. Mine went bad on my 04 Jetta 2.0 and I got a constant red symbol on the dash. Hope this helps you out.
Mar 17, 2009 | 2004 Volkswagen Jetta
Car overheating
You need to check the water pump and coolant level. If coolant level is low you might have the air pocket in system. Overheating of the car can cause the damadge of head gaskette and engine block itself.
Good Luck
Jan 20, 2009 | 1996 Pontiac Grand Prix
Caterpillar American Construction Equipment 1:87 Scale Logo
97 people viewed this question
Top Caterpillar Toys Experts
fordexpert
Are you a Caterpillar Toy Expert? Answer questions, earn points and help others
