Question about Craftsman Garden
Craftsman Incredi-Pull Weedwhacker Model 316.791860. Upon starting, I am unable to keep it running by use of the throttle. I have to let it run on idle which is very high, and trim without using the lever. Even after engine heats up it remains the same.
    President:
  • Craftsman Master
  • 1,545 Answers
Some will say you just need to clean the carburetor but if you put a rebuild kit in it or a diaghram kit (cheaper) you will be cleaning it anyway. This points to a fuel delivery problem and it seems that the mylar fuel pump diaghram inside has stiffened and is no longer functional. Ethanol in the gas and time cause this problem. This usually causes lack of acceleration. A plain diaghram kit may fix this ill if nothing else is wrong. Get your Carb type and model (on carb body) and reference them here for rebuild or diaghram kits!
http://www.m-and-d.com/zama_carburetor.html
Posted on Aug 31, 2010
2 Suggested Answers
SOURCE: How do you adjust carb for a Craftsman Incredi-Pull Weedwhacker?
Turn adjustment screw till it almost stops then turn it the other way till it speeds up and starts to stop then turn it half way back and it should work fine but check throttle cable and oil it if it is sticking.
Posted on Nov 24, 2009
210 2 stroke leaf blower it starts when choked and idles when choked but when i pull the throttle trigger it cuts off. I cleaned the air filter and replaced the plug.
hi mike. most likely problem is junk in the carburator. Get a can of starter fluid and an assistant. Remove the air filter. Start it up and before you pull the throttle have your assistant squirt the starter fluid into the air intake. Use more starter fluid as needed to keep it running for about 2 minutes to clear it. Joe
Apr 14, 2011 | Craftsman Garden
Manual for a craftsman weedwacker model 31679108
Trimmer Starts but stall out as soon as throttle is used and choke turns off. if I hold the throttle and pull the choke it runs but will stall as soon as choke is let go.
Jan 31, 2011 | Craftsman 27cc 2 Cycle Crank Straight...
My Craftsman Weedwacker, (Model # 358.791010 ) does not start. originally it took about 5 - 10 minutes to start and once it was running, I'd hit the switch from "START" to "RUN" and...
Sounds like a carb problem. You may need to rebuild it. Check to see if your fuel lines inside the tank have rotted. Common problem on Craftsman.
Nov 01, 2010 | Craftsman 25cc Gas Line Trimmer
Nov 24, 2009 | Craftsman Garden
Starter rope pulled out and wont retract on craftsman trimmer/edger 32cc convertible incredi-pull
remove the starter cover and try to wind the starter rope manuly. the rope may have to be replaced if worn or broke..
Oct 22, 2009 | Craftsman Garden
I have a crafstman weedwhacker that will start. Once started it will stop as I touch the gas lever. Any suggestion?
check choke for proper connection/check for proper fuel mix / then try to start without air filter-if runs replace w/new filter if problem still check fuel lines for partial blockage/if problem still carb needs service/cleaning
Oct 10, 2009 | Craftsman Garden
My craftsman 32 cc 2 cycle line trimmer doesn't
Check the line head and cable, there may be grass or something like twine twisted between the shaft and housing. If nothing is found there take the spark plug out and see if it will turn over, possibly liquid gasoline has gotten into the cylinder somehow.
Jul 05, 2009 | Craftsman 25cc Gas Line Trimmer
Gas to oil ratio
this mixture for this weedeater is 40:1 or 40 to 1
Hope this helps You
please rate me
Jul 19, 2008 | Electrical Supplies
Craftsman manual for a 4 cycle lawn trimmer
I have a craftsman incredi-pull 4 cycle, I changed 4 cycle oil, too much smoke coming from the machine, what I can do?
Nov 11, 2007 | Video Game Consoles & Games
Garden Logo
1,256 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
