Question about Samsung Digimax 800K Digital Camera
I have a samsung camera which suddenly will not light up when open and after three seconds beeps trhree times and then closes, any ideas?
SOURCE: the lens doesnt close, the camera beeps 3 times and shuts off.
Hi just had the same problem I freaked out and then read that about the lenses problem so I figured screw it if it is broke I have to go out and buy a new one anyway....BUT I yanked a LITTLE on the lens and poof fixed it....
Posted on Oct 17, 2007
SOURCE: Samsung camera power-on problem and beeping
Camera got dropped..had the same problem here, looked after reading this and the smallest part of the telescoping lense was just a little tilted. Gently moved it out and popped it back, works fine now. Another thank you for the tip!
Posted on Dec 24, 2007
  • 3 Answers
SOURCE: samsung s630 camera
Finallly sent it in for repair - two times! First time, it took several weeks before I got it back. When it arrived it still would not work, so it had to be sent in again. Then they tell me I broke the camera myself so if they are to send it back (unrepaired) I would have to pay them $50. At this time, paying shipping costs back and forth I figured it wouldnt be cost effective. All together it cost me a total of $200 for 15 pictures taken with the first battery set, which after it would do nothing but beep three times. Some people mention the cause being that they dropped it, but I never did, it was like that straight out of the box.
Posted on Jun 24, 2008
  • 125 Answers
SOURCE: samsung s860 camera lens will not close and is out of focus.
I hate to say it but your camera needs to be serviced. Might not be worth the repair. Try to take it to a local repair center that would offer you a free estimate....
Posted on May 30, 2009
  • 11967 Answers
SOURCE: lens opens,closes, beeps 3times, turns off
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Dec 09, 2009
Frigidaire refrigerator beeps every 20 seconds or so. three beeps.
try opening the door.leave it open.unplug the fridge for at least 5 minutes, no less,with the door still open.after that,plug it back in.wait for it to beep.then close the door.
this would reset the door alarm,which beepes when the door isn't properly closed.
also you should wait 24 hours between changing the temperature or it can mess up your fridge.!
Oct 13, 2016 | Frigidaire Refrigerators
Samsung S1065 digital camera. Won't witch on. Len won't extend, beeps three times, switches off. Any ideas gratefully accepted.
my samsung camera s1065 the lens wont extend when switching on the lens does not extend ,it bleeps 3 times but then closes down
Aug 28, 2010 | Gateway DC-M40 Digital Camera
My Samsung won't turn on :(
Try to move the lens a bit or straighten it out, that usually works when it makes the three beep sounds.
Jul 22, 2009 | Samsung L100 Digital Camera
My samsung L830 camera has jammed with the lens open and
Just had this happen to my L100. First, take out the battery and wait a couple hours for everything to cool down and discharge. Then place the battery back in. Then plug the USB cord into the camera and PC. Then turn the camera on and it should be okay. Just worked for mine.
Jul 15, 2009 | Samsung Digimax L830 Digital Camera
Camera Lens Stuck Closed
I am having the same problem. Were you ever able to resolve yours? Thanks!
May 02, 2009 | Samsung L200 Digital Camera
S85 camera will not turn on just beeps three times
I figured out the fix:
Take the batteries out, put them back in and close the battery cover. Next, turn on the camera and before it can finish the three beep sequence, open up the battery cover(disconnecting the battery power). Close the battery cover (reconnecting the batteries) and switch on the camera. It may take a couple of tries, but it seems to be a "poor man's reset"
Apr 21, 2008 | Samsung Cameras
Camera turns on for three seconds, beeps three times, then stops.
It's the optical zoom. The motor that pushes it in and out died.
Oct 10, 2007 | Samsung Digimax S700 Digital Camera
It dont turn on
I had the same problem. Try to turn it on, 3 beeps and then it would shut down. Screen would come on for that time. Also, the lens was stuck open. It wouldn't close.
I twisted the lens (gently) and it appeared stuck. A gentle screw motioned seemed to free it. I hit the power button and it come on, but this time no 3 beeps and shut down. I then turned it off and this time the lens retracted and closed.
So, it appears that if the lens gets stuck open, it has a shut down feature that doesn't allow the camera to go further into its operation modes. I believe this stuck open problem occured on our camera when the batteries went low.
Again, a second of gentle twisting seemed to unstick it and with fresh batteries in, it was able to operate and shut down properly.
As far as batteries, I use the rechargeable Ni-Cad 2500 mA. They last a while.
Blessings to you!
Jun 02, 2007 | Samsung Digimax S500 Digital Camera
The lens doesnt close and when i turn the camera on it bips three times and the screan shuts off. the lens wont close.
The batteries need to be changed. The digital batteries sold at the stores die out too fast. I had this same problem. In result, I purchased rechargeable battieries.
Nov 19, 2006 | Samsung Digimax S500 Digital Camera
Samsung Digimax 800K Digital Camera Logo
16 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Samsung Camera Expert? Answer questions, earn points and help others
