Question about Hoover U6311-930 Power Drive Bagged Upright Vacuum
We understand that your problem is: I have a Hoover Power Drive Model U6311-930 self propelled vacuum (type with disposable bags). Series E7.8 amps. When turned on it works and vacuums properly but the motor noise is way louder than it should be. Almost sounds like a jet engine. It is very loud. It is not the kind of noiase it makes if it has a object trapped in the brush assembly. I have thoroughly cleaned the unit including changing the bag and cleaning all debris pathways. I have also checked both belts, removed the belts, brush and top housing cover over the motor and removed the clear plastic shroud that directs the dirt to the cleaner to inspect the area in the blower chamber. I have run the motor with the belts and brush removed and it is still just as loud. It is NOT the kind of noise that results from a loose item like a screw running inside the motor, just loud - really loud like something is definitely wrong. I am very mechanical and have a Masters in EE so I am not afraid of attempting a repair, but the only thing I can think of is to replace the motor, which is probably too expensive given the vacuum's age. Any suggestions?.
  • 7 Answers
SOURCE: I have 2 Hoover Wind
The Hoover WindTunnel self propelled is a machine that we see in our retail stores (Vacuums Unlimited) constantly. The benefit of having a supposed "self-propelled" machine wears of quickly after the numerous time you will need to take this machine in for repair.
It's unfortunate you've had to spend so much money already on repairing this machine. I know you've said you've already replace the belts and filters, but if you want you can check out a video we made on repairing the Hoover Windtunnel.
http://www.youtube.com/watch?v=meX8lgZo7DY
If you are looking for a reliable upright, at GoVacuum we'd recommend the Sebo X4 upright (http://www.govacuum.com/seauxseupvac.html). The machine is incredibly reliable and easy to maintain. Thus far, we haven't had one warranty repairs come through our doors. The machine itself has a lifelong warranty on the belt because the machine automatically shuts off the motor if an obstruction is detected, preventing any undue stress on the motor or belt.
Posted on Jun 07, 2008
galati2k
  • 281 Answers
SOURCE: The shield over the rollers needs to be replaced.
tti floorcare 1800-321-1134.need your mode number handy please leave fedback
Posted on May 05, 2009
  • 273 Answers
SOURCE: hoover windtunnel self-propelled vacuum is not
have you cleaned the filters?
Posted on Jun 09, 2009
VacuumRepair
  • 438 Answers
SOURCE: hoover self propelled bagged windtunnel upright
Greetings from GoVacuum,
Here's a great video repair tutorial that we've put together to try and help you with the repair on your Hoover WindTunnel. I hope that this helps you with your repair. If you found this solution helpful, please rate this repair video by clicking on the 4 Thumbs Up Icons in the top right hand corner of my repair solution. Feel free to email me at chris.jones@govacuum.com if you have any questions about the repair!
Video Repair of Hoover Windtunnel Belt Change;
Thank you very much,
Chris Jones
GoVacuum.com
Posted on Mar 19, 2010
VacuumRepair
  • 438 Answers
SOURCE: I have hoover WindTunnel Self Propelled Vacuum
Thank you very much!
Chris Jones
GoVacuum.com
The wheel that connects both belts broke
The drive pulley can be replaced, however I would only recommend being service by a vac shop professional who has experience with the Hoover Self Propelled models.
Oct 20, 2014 | Hoover Ultra U6430-900 WindTunnel Bagged...
Indentations left on carpet all about 3 inches apart
The indentations that the Hoover U6311-930 self propelled leaves are from the two large wheels of the self propelled system under the bottom of the vacuum. There are two main reasions for this the weight of the vacuum cleaner and that the carpet fiber has worn, do to age, and now shows the tracks. There is no sollution for this problem.
Apr 08, 2010 | Hoover U6311-930 Power Drive Bagged...
I just bought a Hoover Power Drive Concept Two Electronic vacuum from the thrift shop. It only needed two belts and seems powerful. But i don't understand what the small red button on the handle marked...
The U6311-903 is a self propelled vacuum. The the small red button will stop the handle from moving back and forth, which makes the machine go foward and backwards. The red button disengages the self propelled feature.
Feb 06, 2010 | Hoover U6311-930 Power Drive Bagged...
Hoover windtunnel self-propelled - will not turn on
You probably need the switch replaced. It's fairly simple to do youself, and it is a known problem with these vacuums.
You can order the switch from hoover for about $10
Oct 08, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
Change belts on a Hoover Power Drive Wind Tunnel Series 900 vacuum
Try calling Hoover directly toll free at
1-800-944-9200 M-F 8 AM - 7 PM EST.
Sep 08, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
Self Propelled does not work
if you look below the headlamp of your vac you will find a cable that attach's to a piece called the actuator arm. either this piece is likely broke or the cable itself. always work the power drive smoothly or things will break. also could be that the smooth belt is stretched and will cause the same problem. belts should be replaced every 4 months. good news is all parts above should be under $5. dont let anyone tell you that you need a power drive assy, that usually isnt the case. good luck!!!
Sep 24, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
Kenmore direct drive will no longer self-propell
There may also be a reset button. If the brushes get stuck the unit can shut off power to the brushes to keep a total melt down from occurring. The reset button should return power in these types of vacuums.
Aug 17, 2007 | Kenmore 31913 Progressive Direct Drive...
Hoover U6311-930 Power Drive Bagged Upright Vacuum Logo
47 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
