I have a lcd monitor problem, it wont turn on. the little light thats suppose to light up when you plug the monitor doesnt light up.. when i press the power button the green light appears for a sec and the monitor blinks for sec. it keeps doing that whenever i press the power button.. (its not connected to the cpu even if its connected either)
  • 629 Answers
Sounds like a power issue with the monitor. try to remove and reconnect its power cord. If same thing happens, try using a confirmed working power cord like the one you use with the computer and make sure you test it out using a confirmed working power outket. If it has the same issue, would mean you need to get a replacement monitor. Refer to the vendor if it is still in warranty.
Posted on Aug 31, 2010
It wont turn on.
If the power light does not come on and it makes a screeching noise, most likely its broken. I would contact the manufacturor, in case some warranty left.
Jan 11, 2014 | Acer AL2216W LCD Monitor
My monitor hp w1858 wont turn on
Your monitor may have developed a power supply problem since being refurbished
Jul 04, 2013 | HP Refurbished 18.5" Widescreen Monitor...
After you turn it on it goes to a black screen, then wont turn off.
first check the supply of the LCD monitor check the plug supply usually 110V or 220v use a voltmeter, if the voltage is present look for the indicator lights that is changing when power switch is press,the indicators tells you if the problem is in the power supply area of the LCD monitor or in the screen, usually the problem with the LCD monitors is in the screen check the bulb on top of the monitor check if it is not function well this bulb is responsible for the brightness of the screen if it is defective replace it or maybe the supply of the bulb is defective you can use the power supply of the cathode light as a replacement to its supply that is usually use in motorcycles signal lights.. hope this helps you..
Jul 25, 2011 | Coby 40 TFTV4028 LCD TV
I have a LG computer moniter and it just wont turn on i press the power button and the blue power light doesn't even stay on for a second
First Check your AC Plug if it is perfectly inserted. if inserted perfectly and still doesnt work, try using a working ac plug to check if your AC plug was the problem. If the monitor still doesnt work try checking you video card. Remove your video card and try cleaning the gold bars using a White Eraser. Insert the Video Card Back in and try running the computer. If it still doesnt work that means your monitor is the real problem.
Jun 28, 2011 | Computers & Internet
I cant get rid of osd lockout on screen and the monitor wont turn off
Press and hold the menu button for 10 seconds. If that doesnt work, it might be time to get a new monitor. This model of monitor was notorious for having a problem with the menu keypad and buttons sticking causing the lockout.
Jan 26, 2011 | HP L1706 17" LCD Monitor
When I turn my computer on the monitor stays off. I press the monitor's power button and the orange light above it goes off, obviously turning it off. I press it again and the light turns blue, the words...
the monitor is not getting any video information from your computer .. check the connection at the computer to make sure it is fully plugged in .. make sure the video card (if it has one) is securely in place ... make sure the monitor is actually plugged into the right connector .. you may have a bad video card or a damaged cable to your monitor .. you can plug the monitor into another computer to make sure its ok ..
Feb 28, 2010 | LG Flatron L1750S 17" LCD Monitor
Tv wont turn on all the time
u MAY hitted ur TV frm top side. Open your tv From front and remove vaccum over CRT
Oct 09, 2009 | Samsung SyncMaster 913V 19" Flat Panel LCD...
The sceen wont turn on the little light is flashing but the sceen doesnt turn on the computer is perfectly on but sceen doesnt see that >.>
First make sure that your VGA cable comming from the back of your monitor is still connected to your computer, check both sides on the back of your copmputer and your monitor if they are both in then maybe your cable is bad.
Sep 03, 2009 | Samsung SyncMaster 2233BW 22" LCD Monitor
Acer al1916w wont turn on
My living room monitor faced the same issue before.
I called up Acer, and they fixed the power LCD board in the monitor.
Do not buy a new one yet, unless the warranty is over.
Jan 01, 2009 | Acer AL1916W 19" LCD Monitor
Computers & Internet Logo
44 people viewed this question
David Payne
David Payne
