Motherboard replacement vs. New Computer
I have HP Pavilion a405n that I have figured out the motherboard has gone bad. Does anyone know how much a new motherboard will cost? Or would it be cheaper to purchase a new computer? I don't need anything fancy just something to get to the internet and to check emails.
    Genius:
  • 2,785 Answers
Depends upon the mother board chip specification the price will vary, you have to explore the market for the price
Posted on May 09, 2008
Replaced motherboard &hard drive in hp pavilion, now it will not recognize reovery cd
Replacing major hardware in a computer makes it a whole new computer. The motherboard is the operative part here that is causing your problem. When you replace a motherboard it becomes a new machine entirely. It won't recognize the recovery CD because it doesn't recognize your computer as the same machine it was loaded on. You will have to buy a new copy of windows to put on your computer.
Feb 13, 2013 | HP Pavilion Slimline S3020N PC Desktop
HP Pavilion Slimline s3120n. turn the computer on and is sounds like it is starting normally but No Video. I have tried disconnecting all extra components from the motherboard, resetting the Cmos with...
Try the display on a different PC. The on board video may be defective, if so you will need to buy a new video card. Check to see what type you need. Good luck. I hope this helps...Have a good day.
Apr 26, 2011 | HP Pavilion Slimline s3120n Desktop PC
Took our HP Pavilion DV6500 to the local service center and because the screen does not illuminate when the system is on, they are telling me the motherboard is bad. Have you heard of this problem...
Yes the service center is correct and this type of problem is common with HP motherboards.
If you do have extended warranty this is still valid the of course HP will repair or replace the motherboard for you at no cost. All you have to do is contact HP.
Click on the link below for HP's contact details >>>>>
http://h71036.www7.hp.com/hho/cache/309717-0-0-225-121.html
Regards.
Dec 24, 2010 | HP Pavilion dv6000 Motherboard
I updated my BIOS on an HP Pavilion a430n now it wont boot up, the computer starts with the fans running on high. There isn't a boot screen or anything just blank. Help!
Sorry for some bad news, but unless you know someone who would know how to unbrick your motherboard from a bad bios flash.. its gone. They recently came out with new boards that have protected firmware, if anything like this were to happen it would auto reflash the original bios to the board. Hope this helps :-S
Oct 19, 2010 | HP Pavilion a430n PC Desktop
I have an old computer (not this one)which uses
How do you "warm" the computer, so that it will start properly?
Take a close look at the motherboard.
Look for those round "towers" with "silver" coloured caps.
They are capacitors.
If any caps are _not_ flat, i.e., they are bulging,
or if any caps show brown "rust" on top of the caps,
then those capacitors on the motherboard have gone bad.
Before your motherboard _completely_ dies, backup "everything" to an external disk-drive, verify that the backup has worked, and then either "trash" the motherboard, and replace it. You'll have to reinstall Windows onto the new motherboard -- find the CD/DVD set that you used to install XP.
Feb 28, 2010 | HP and Compaq Pavilion Replacement 200w...
Need to replace my Asus A8N-LA motherboard. fan controlers gone
If I were you, I would replace the motherboard with the same model as Hp use´s...
When you try to find another compatible board you will have some problems due to exclusive computer case..sometimes you need to adapt things...too bad...it´s better to repair with original board....
Sep 09, 2009 | ASUS A8N-E Motherboard
I have a hp Parilon dv6000. The screem has gone
This is almost always an "inverter" or "backlight", which are both relatively inexpensive and easy to replace.An Inverter can run about $60 for the part itself, and a backlight about $5.00 .However to fix either problem ,you will have to take your screen apart. Almost anyone can replace an inverter with some common hand tools and a little care. I would not recommend trying to replace the backlight unless you are highly skilled at screen repair.
The bad news is that this can also be caused by a problem on your motherboard.
Aug 02, 2009 | HP Pavilion dv6000z Notebook
HP Pavilion dv6700 faulty video card.
The HP Pavilion DV6700 has nVidia GeForce Go 8400M GS on-board video, so if the video is truely faulty, then you will need to replace to whole board. This product is covered under a 1 year warranty also, so I would call up HP and try to get a replacement for the board. A cost of a new board is going to run between $120 to $150 dolloard depending on what site you order it from.
Jun 19, 2009 | Computers & Internet
HOW TO REPLACE HP DV4000 MOTHERBOARD
Check out the manual, located here:
http://h10032.www1.hp.com/ctg/Manual/c00530488.pdf
Check under the Removal and Replacement Procedures section.
Replacement for the Full Feature Motherboard can be found here:
http://www.getpartsonline.com/396696-001.html?source=googlebase&code=396696-001
Nov 25, 2008 | HP Pavilion dv4000 Notebook
Computers & Internet Logo
108 people viewed this question
David Payne
David Payne
