Question about Hotpoint 30" Self-Cleaning Freestanding Gas Range - Black
Hotpoint gas range self clean turned oven on to pre heat and after a short time heard a pop and oven was off
  • 11,896 Answers
That noise is likely the thermal fuse in the back. It can be replaced. If you are not getting any power to the control panel or the rest of the oven, this is likely the cause.
Posted on Aug 31, 2010
My oven will self clean and the top will come on when in Broil but oven will not preheat in bake mode.
self clean and broil will make same heat for self clean
if this is a gas range then change bake glow ignition
more info can be yours send us full model # of range for more exact info of your range.
electric range will be element bake or broken burned wire
Dec 06, 2014 | Hotpoint Kitchen Ranges
Oven does not heat up
That pop could have been the element. Check all around the element for a bubble or a large pit/hole. If you don't find anything then check for a burned wire in the back (please unplug the range). Does your range have fuses? If so then check the 30A fuses, but if one is blown you'll have to find the short that caused it, usually a burned wire fused to the chassis or a burned out element. There are many things that could have caused this but these are the most common. Cheers
Nov 09, 2013 | Frigidaire 30" Self-Cleaning Freestanding...
How to self clean hotpoint gas range model number rgb740beh3ct
To self clean that oven REMOVE THE RACKS, slide the door latch from the right to the left,push the self clean button,push the up/down arrows to set the clean time (usual clean time is 4 hours 30 minutes) push start
After the clean is over it may take a additional hour before the door will open if the latch doesn't move back easily to the the right once self clean clean is done do not force it just wait more time
GENE
Oct 10, 2011 | Hotpoint RGB745 Gas Kitchen Range
My range is actually the RGB746 self cleaning gas
oven don't stay on and it takes a long time to heat up
Nov 21, 2009 | Hotpoint RGB745 Gas Kitchen Range
Self Clean cycle on Hotpoint Gas range doesn't work
We see a symptom like this due to a failure in the control board. Although it usually also affects bake mode. Another cause could be a problem with the door lock as it must be engaged (by the controller) to initiate self-clean.
If this doesn't help, you can either post the full model number or email me at bruce@fixyourboard.com and we can dig deeper.
Oct 09, 2009 | Ovens
Oven won't work
sounds like electronic ignition is worn out
May 26, 2009 | Hotpoint 30" Self-Cleaning Freestanding...
Hotpoint Gas oven doesn't light
Is the gas valve easy to replace on a gas oven?
Nov 14, 2008 | Hotpoint RGB745 Gas Kitchen Range
Hotpoint gas oven
This is an indication of low gas pressure to the oven. This condition may improve when other gas equipment is turned off and worsen when demands increase such as during cold periods where heating plants are running. Contact your local gas company to check pressures at the burners and adjust the incoming pressure to the oven accordingly.
If you found this helpful, please Vote!
Mar 03, 2008 | Hotpoint RGB745 Gas Kitchen Range
Hotpoint 30" Self-Cleaning Freestanding Gas Range - Black Logo
67 people viewed this question
Top Hotpoint Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Sal DeAngelo
Are you a Hotpoint Kitchen Range Expert? Answer questions, earn points and help others
