Question about Delfield Freezer 6125XL-S
CAN'T GET EVAPORATOR FAN TO COME ON & TEMPERTURE TO DROP.
    Sergeant:
    Novelist:
  • 193 Answers
Several possibilities. The fan won't come on until the coil inside the box on top of the freezer gets down to about 0 degrees. It also will not come on if the door is open. It sometimes takes 10 to 15 minutes to come on. If you are low on refrigerant (freon) the coil will not get cold enough to come on at all. Feel the coil on the outside of the freezer on top and see if it is very warm to the touch. If not you are probably low on refrigerant. If you have the electronic control system, it may not be sending the signal to the fans after a defrost cycle. If possible, put gauges on the valves to check your freon charge. If this unit has not been operational in a while, you might try flipping the top cover off the coils and turn the fans by hand a couple of revolutions. I have had them to seize up from not being used. The fans should turn freely.
Posted on Sep 05, 2010
Where is the evaporator fan motor? My Freezer and fridge would quit cooling/freezing. I took the back panel off in the freezer a week ago and the evaporator coils were completely frozen over with ice. I...
I do not believe the problem is the fan. sounds like the frig. is low on Freon this is what will cause the ice build up. you need to find the leak, you can do this by spraying soapy water on coil tubes & watch for bubbles. repair leak & recharge.
May 25, 2015 | Samsung RS261MDBP Side by Side...
What is a clixon
Clixon is an overload device designed to shut off current when too much juice is flowing within circuit. When it cools it resets itself but if condition is still present it will go out again.
Apr 17, 2014 | True 72 cu. ft. / 2039 liter Commercial...
Commercial fan on evaporator cuts off after starting
There is an overheat klixon on the evaporator that stops the fan running until the coil gets below -11c This can take some time after startup. if the freezer runs more than an hour before the fan starting, check the klixon isn't faulty, and you have power to the fan. Also check the condenser grille is nice and clean as it will slow down the freezing process.
Apr 17, 2014 | True Freezers
On the ceiling in the walk-in freezer drops of water frozen around the area by the fans
That tells me that when the evaporator defrost the water condensate is not draining to the outside of your freezer. You will need to find the drain blockage, Thanks Sea Breeze
Feb 27, 2013 | Kolpak Commercial Freezer
Is the evaporator fan suspose to be pulling air from inside the freezer over the evaporator or pushing air from the evaporator?
The evaporator fan should be pulling air from the freezer over the evaporator and directing the air down into the frig and circulating through out the freezer.
Hope this helps.
Jan 05, 2010 | Continental Freezer Reach-In FreezersClick...
Freezer was fine. I unplugged it, stood it up in back of truck, got to house plugged it in and now it won't get cold. Compressor is working! Help!
that sounds very frustrating and makes little sense. The compressor works but what about the small fan the blows across the evaporator coil. Also, every refrigeration system has a metering device that is responsible for the pressure drop of the refrigerant just before it enters the evaporator coil. It may look like the orifice on a gas appliance with capilary tubles. it will be between the 2 coils on the line opposite the compressor. Look for kinks in the tubing
Nov 22, 2009 | Freezers
Freezer is not cold and evaporator fan (inside
ok well... those pipes coming from your compressor one of them should be hot. if not your compressor is not running.
Nov 10, 2009 | Amana Freezers
Fans inside freezer will not turn - no cooling - compressor fan underneath is turning
The fans are controlled with a clixon that has a cut in at 5 degrees, and cut out at 20 degrees. If the unit is running and the fans are not comng on then I would have to say you are out of freon. But your condensor fan could be running and the compressor NOT be running which could be a problem with your compressor. Find out if your compressor is running by taking an amp draw. If compressor IS running then you are low on freon. If the compressor is running and your evaporator coil is cold and your fans AREN'T coming on then your clixon is bad.
Sep 26, 2009 | True 72 cu. ft. / 2039 liter Commercial...
T-23F FEERZER
fan burnt or relay fauly or fuse blown
Mar 10, 2009 | True 23 cu. ft. / 651 liter Commercial...
Delfield Freezer 6125XL-S Logo
143 people viewed this question
Top Delfield Freezers Experts
Dennis Boxerman
Dan Webster
Dan Webster
Tom Donaldson
Level 1 Expert
Are you a Delfield Freezer Expert? Answer questions, earn points and help others
