Question about Dishwashers
Bosch dishwasher I have a model SHY66C, can I get a black panel for this unit?? I have a white one at this point
  • 117 Answers
That model only have white panel
Posted on May 10, 2008
Bosch SHY66C
maby kinked hose
Jan 31, 2008 | Dishwashers
Bosch Dishwasher using too much salt
This will be the regeneration valve sticking in the open position. It is located on the regeneration unit behind the left side panel (looking from the front). It is fairly easy and inexpensive to change....however, the cheapest fix (if you are not in an extremely hard water area) is to switch to an all in one tab and not put any salt in at all!!!
May 13, 2013 | Bosch 24 in. SGS43C12 Classixx...
Can I exchange the white door panel for a stainless steel panel on Bosch Dishwasher SHU5312UC/U11?
from my research all but 3 models have that option, I didn't see yours there, But if you contact sears or www.homeeverything.com I'm sure they can assist you
May 18, 2011 | Bosch 24 in. SHU53 Built-in Dishwasher
I have a bosch dishwasher model classxx maxx freedom performance sgs43co2gb/35. the machine when turned on doesnt stop,so i checked the control panel and there was a black ring of soot,before i purchase a...
i think your model was part of the recall and the repair is free to fix call bosch and they will take of ity. they need to know the model asnd serial number to know if it is one of the recall
Mar 08, 2010 | Bosch Dishwashers
Can i get a replacement switch for a bosch exxcel sgs45eogb56 also can you buy a new front panel .the panel that covers the control buttons , thanks
There is a wqebsite called www.appliacneart.com that makes many different options for your dishwasher replacement panels. I know they have black, white, and stainless, but they also have a ton of other options like fireplaces, and paintings. Check them out it would probably be your best bet.
Dec 02, 2009 | Bosch 24 in. SGS47E02 Exxcel Free-standing...
Spray arms not spraying and pump noise for Bosch SHY66C
Unless the motor and pump are an assembly permanently fastened as a unit, you probably need only replace the pump. Motors can be made really poor but will outlive the pump.
Since Bosch is a German brand, it may not be found on the Sears parts pages but it is worth a try. Just go to Sears.com and click onward for parts.
Jan 04, 2009 | Bosch 24 in. SHY66C02 / SHY66C06 Built-in...
Burnt wiring on Bosch SHX46A06 Dishwasher
Bill that is exactly what happened, the connection wasn't correct from the start. The Bosch dishwasher pulls 11 amps during the cycle while heating the water to temp. The cooler the water the longer the heat time. Your dishwasher came with a set of wire nuts that where suppose to be used. Be sure when you correct this to use 20 amp wire nuts with the unit. This will stop this from happening again.
Aug 02, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Is there a way to turn off the cycle completion signal. I have a Bosch SHY66C02UC/14
OK, I think I have figured this out. Let me first give this important piece of information. The control panel for my dishwasher was replaced recently. That's why I now have to deal with this issue. I have a Bosch SHY66C model. As I stated in a previous post, the user manual I found on the web has identical structions for changing the amount of rinse aid dispensed and for changing the volume on the cycle completion beeper (or for disabling it). Following the instructions fixed the former.
Here is what I did
1) With dishwasher off, I pressed and held the "Delay Start Hours" button
2) I pressed the on/off button. The beeper begin to sound.
3) I released both buttons (not sure this step is necessary)
4) I repeatedly pressed the "Delay Start Hours" button until the signal turned off
(LED display showed 0)
5) I pressed the on/off button (not sure this still is necessary)
That seems to have fixed the problem. So, I don't know if the user manual is wrong or my control panel was replaced with one from a different model (such as the SHU9950 where I found these instructions).
Jul 24, 2008 | Bosch SHU9915UC Dishwasher
Dishwashers Logo
79 people viewed this question
Top Dishwashers Experts
