Question about Microwave Ovens
My ewave microwave throughs the breaker off in the house when I open the door.. What do I do? How do I fix it?
  • 185 Answers
You have a defective door switch or the switch bracket itself. check if both hooks on door are o.k. too.
Posted on Aug 31, 2010
Turn table won't turn on ewave microwave oven
Almost certain if microwave still heats a bad motor or gear issue inside the unit--if unit will not heat the safety switch in the side that the door engages is the cause of the wheel or platter not turning--prevents unit from use if door open.
Nov 06, 2012 | Microwave Ovens
I want to buy the handle for my EWAVE microwave
You can order Ewave parts here.
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the screws you need to remove.
Or you can watch a YouTube video (not a video I made) here that demonstrates how it's done.
Jul 02, 2010 | Kenmore Microwave Ovens
Replace handle on Ewave microwave
you'll have to remove the molding and the handle clips in to place and also has to screws that hold it in place, after that reassemble the door outside trim.
Jan 19, 2010 | Microwave Ovens
Change handle on ewave microwave
Take a look on amazon for replacements, here Amazon com microwave handle. I hope this was helpful. cheers
Jan 15, 2010 | Microwave Ovens
How to replace the door handle on an Ewave KOT 170SW Microwave
Ewave KOT 170SW Microwave, it starts runs for a few mins. then stops. Shorter then time set for.
Dec 10, 2009 | Microwave Ovens
Ewave over the stove microwave fuse blows when I
The light is the only thing that comes on when you open door. You either have a shorted door switch (Micro switch) or a shorted bulb. You have either a shorted bulb or bad socket. From my experience, it's the bulb. Just because it may seem to start to come on when you open the door, it's most likely bad. At least it not expensive.
Please rate solution
Aug 28, 2009 | Microwave Ovens
Replace OTR Microwave
Thanks for responding. It is a EWave KOT-152UW. I think EWave is part of Magic Chef. I think it is the door switch. When I opened the microwave, the circuit breaker tripped. I reset the circuit breaker, and it worked for several days, but the last time, the microwave went dead. The reason I want to use the same bracket is it has through the wall (horizontal) venting to the outside, and I am not keen on trying to cut more holes.
Nov 04, 2008 | Microwave Ovens
Emerson Microwave
i would presume you know hot to use a VOM too, check the resistance of the wire as you close the door, if it would be too small, then you can test the wiring.
it could have been that the door switches was wired incorrect and once you close the door, the two lines are shorting out.
another odd thing you said is that it turn on with the door open.
that should not be the case because of microwave energy leaking out thru the door.
this door has the safety switch where in it would not or stop running once you accidentally open the door.
if you can trace the diagram which is usually pasted at the inner wall of the cover.
tnx 4 using fixya,
drcool
Sep 01, 2008 | Microwave Ovens
Ewave kot-131UB pops breaker
Yes, this is caused by either a bad door switch or a loose door or loose door switch mount.
Even though a door switch clicks, it may still be bad inside. Its continuity must be checked.
Door switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
If you someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
We're happy to help and we appreciate your thoughtful rating of our answer.
Mar 13, 2008 | Kenmore 80412 Microwave Oven
Microwave Ovens Logo
121 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
