Question about Gateway Belkin 54g Wireless DSL/Cable Router (DHF5D72304)
Belkin 54 encryption
I have a belkin 54 to which my PC is attached and a laptop which gains internet access through the wireless connection. My system is not encrypted and I need to do this. Would someone be able to tell me how I can apply encryption?
Paul
  • 3dd13 Nov 25, 2008
    What would be the cause if you have configuired your PC with the hex code and it still does not work?
    The PC can see the router but it just will not connect to the web.
  • Allen Gore
    Allen Gore May 11, 2010
    encryption as in a WEP?
    you should be able to go into your router to do this, simply use your web browser to connect to it by typing in http:// and then your routers IP address(if you do not know it, go to start -> run -> cmd, and then type in ipconfig and the IP is listed as default gateway). which should then ask for a user name and password for the router, (if you have never set one, it uses a default username and password which can usually be looked up on google) then there should be an option to set one in there.
  • Gateway Master
  • 6,487 Answers
1. Log into your Wireless Router or Access Point.
Open your web browser and type in the IP address of the Wireless
Router or Access Point. (The Router’s default is 192.168.2.1, the
Access Point’s default is 192.168.2.254.) Log into your Router by
clicking on the “Login” button in the top, right-hand corner of the
screen. You will be asked to enter your password. If you never set
a password, leave the password field blank and click “Submit”.
Click the “Wireless” tab on the left of your screen. Select
the “Encryption” or “Security” tab to get to the security
settings page.
2. Select “128-bit WEP” from the drop-down menu.
3. After selecting your WEP encryption mode, you can type in
your hex WEP key manually, or you can type in a passphrase
in the “Passphrase” field and click “Generate” to create a WEP
key from the passphrase. Click “Apply Changes” to finish. You
must now set all of your clients to match these settings. A hex
(hexadecimal) key is a combination of numbers and letters from
A—F and 0—9. For 128-bit WEP, you need to enter 26 hex keys.
For example:
C3 03 0F AF 4B B2 C3 D4 4B C3 D4 E7 E4 = 128-bit key
4. Click “Apply Changes” to finish. Encryption in the Wireless
Router is now set. Each of your computers on your wireless
network will now need to be configured with the same
security settings.
Posted on May 09, 2008
How to use router without using wifi in belkin n150
This model Belkin wireless router has 4 LAN ports so you can connect a LAN cable from this wireless router to your computer.
I suggest you disable the wireless in the router so no one can access your network and Internet. If you cannot disable the wireless then you can setup WPA2 encryption to secure your wireless network or just remove the aerial off the wireless router.
Mar 05, 2013 | NetGear WGR614 54 Mbps Wireless Router -...
I have a belkin.4bda router connected to my laptop from my pc which normally works very well, however from time to time my laptop will not allow me to connect to the internet saying that my security key...
The PC connects to the Internet because it uses a network cable that is attached to the router.
The laptop connects to the router with a wireless connection, you most likely have enabled encryption on the router's wireless settings and if the laptop's wireless card has not been configured with the router's encryption settings, then it cannot connect to the router via the wireless until you enter the encryption (security) key.
To secure your wireless network from unauthorized access,please click on this link and follow my instructions :-http://www.fixya.com/support/r3559128-wireless_router_security
Jan 01, 2011 | Belkin Basic Wireless Router
My router does not show wireless signal just wired
Your computer cannot detect the Belkin if the wireless card in the computer has not been configured with the Belkin wireless settings.
The WEP, WPA, WPA2 encryption key is in your router's wireless settings. Log into your router and got to the wireless settings, you will need to get the SSID and the encryption key. Then go to your computer/laptop's wireless card and configure it with the router's SSID and encryption key, so it will then connect to the wireless router and the Internet.
Dec 24, 2010 | Belkin N1 Wireless-N Wireless Router
Belkin router problems
Its not necessary to purchase a new router. Nintendo DS supports WEP encryption. You wont be able to connect if the encryption on the router is WPA. Your computer can connect on both WPA and WEP so what i suggest is for you to access the router page then check the wireless settings then change the encryption to WEP so that your Laptop and DS can connect at the same time. To access your router check the manual for the username and password
Thanks for using Fixya.
Aug 03, 2010 | Belkin (F5D5231-4) Router
Trying a add another desk top to an existing Belkin wireless G router at home. Right now there's a desk top and laptop working off this router.Try several times and still can't connect to internet.
Make sure the Belkin wireless is the only device directly connecting to your internet service provider's router/modem. Usually that port is labelled "WAN" or even "Internet". The Belkin should have extra ports/jacks for WIRED connections, right? You then connect the PC into the other remaining ports/jacks on the Belkin (if they're wired) or just use the wireless for the laptop if the laptop has wireless. After getting the wireless going, though, you should lock it down by using WPA encryption key if possible.
Feb 24, 2010 | Belkin (F5D7230-4) Router (587009)
Belkin 54 Wireless Internet Connection Problems
If wireless adapter on the laptop is fairly old, you may need to update the drivers for the wireless adapter. Some older wireless adapters are not capable of properly communicating with WPA devices. Typically a driver update of the laptop resolves the issue. If not, try another wifi adapter and verify it is not the OS or laptop itself.
Good Luck.
Jun 20, 2009 | Gateway Belkin 54g Wireless DSL/Cable...
Belkin (F5D7050) 802.11a/g/b Wireless Adapter, home networking. I am on AOl using Thomson speedtouch, I am trying to link up 2 pc's and one laptop to access the net. Main Pc is Vista - with wireless...
try to reset the wireless router to factory default.( with out encryption). connected the Xp first. then the other two.
try to use simple encryption (8 characters).
Oct 12, 2008 | Belkin Computers & Internet
How to set up my belkin adsl modem with built in wireless router (8o2.11g/54 mbps) with my broadband connection?
There may be a set up wizard disk with the router so you can put in your broadband account details etc to get you running.
The wireless side of things will almost certainly require you to use a cable to connect you PC to the router and log in using internet explorer
Post the model number of the router so I can assist you in more detail
Jul 19, 2008 | Belkin Computers & Internet
Belkin Wireless Router
1. you need to put the software belkin installation disc into the girls laptop not just the desktop.
2. you need to plug the modem back in
3. on the back of the router press the little button NOT THE RESET BUTTON MAKE SURE IT IS THE LOCK BUTTON it will ask you for a password on the laptop
May 24, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Gateway Belkin 54g Wireless DSL/Cable Router (DHF5D72304) Logo
477 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
