Question about Dishwashers
Hi, The dishwasher is not filling with water. Have checked all the obvious hose blocked, pump clear etc.... Please help Jayne
    President:
  • 1,430 Answers
The problem is likely with the water inlet valve or float switch. Both are inexpensive and easy to check/ replace. Here is a link that should help http://appliancehelponline.com/dishfloatwaterinletvideo.html
Posted on Aug 31, 2010
What is E1 error code
The E1 error code indicates a water inlet error. Do you still have your manual to test for this?
Jun 20, 2014 | Kenwood KDW243A Builtin Dishwasher
Motor sounds like something is keeping it from running
Tricky to analyse from this description. Dishwashers generally don't have motors, they may have a pump.
Before you do anything, check that you haven't got any error codes you can check with the manual (you don't say which model you have).
The most frequent problem is a blockage either on the water intake, the hoses. These generally have in-lie filters where the hoses join to the machine, if blocked, water supply is too low and a safety cut out operates. However if hoses are squashed or kinked the same can happen, so check these are clear.
There can also be a blocked filter on the waste side. Clear all the filters you can and try going through the filling/emptying stages of a wash.
Hope this helps
Oct 28, 2013 | Kenmore Dishwashers
The water is not draining from machine, although the pump is obviously trying. It doesn't sound quite right. Kind of a growling noise. It can pump water into tubs when experimenting with ideas, but can't...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems - Water will not drain out
heatman101
Sep 13, 2010 | Bosch 24 in. SMU40 Built-in Dishwasher
Dishes are not coming clean. I've tried reducing the size of the load, using all hot temps on every setting, etc.
Hi<br /> <br /> <br /> <font size="3" face="Calibri">If you are observing that the dishes are not clean, then you
Aug 21, 2010 | Frigidaire 24 in. FDB1050REC Stainless...
Dishwasher is not cleaning dishes. Food is left on the dishes at the end of the cycle. Also, when dishwasher is emptying it's water, it gets very loud.
Hi
If you are observing that the dishes are not clean, then you’ll need to follow certain steps to be sure where exactly the issue. First thing to check for is the detergent cup and spray arms. Check if the dishwasher’s spray arms are working fine and all the holes of the arms are clear. Now try using a different detergent like gel or liquid based detergent to see if it helps.
Dishes are left unclean when the dishwasher is not filling in properly or when the water pressure is low. Check for water pressure and water inlet valve. The water inlet valve if faulty will draw very little or no water. However, if you observe that water pressure is fine and there is no issue with the Fill valve then check whether the dishwasher is draining. If it’s not draining then see if the drain hose is plugged or clogged. If drain hose is fine and the dishwasher is still not draining then there is some issue with the drain pump or drain filter. To check this you’ll need to disassemble the dishwasher and trace back the drain hose to a pump, remove the drain hose from pump and clean the debris from the pump and filter. Make sure you have lots of towels as there would be a lot of water coming out from the pump.
Next thing to check if the dishwasher is draining and filling properly is water temperature. Water temperature should be between 120 and 140 F. If water is not hot enough then heating element has gone bad, to check the element you’ll need a multimeter. Use the multimeter and check if the Rx1 reading on the meter shows reading between 1200 (1.2K) ohms and 1500 (1.5K) ohms, if not the heating element has died. Please post back if more information is required.
Daniel
Aug 08, 2010 | Maytag MDB7100AWB Dishwasher
Hi, My dishwasher is about 6 years old and lately it is not properly washing the dishes. We've noticed that the glasses look foggy and the plates are sometimes not as clean as they used to be. Also usually...
Hi
Daniel
Aug 07, 2010 | Kenmore Dishwashers
Not cleaning dishes clearly
Hi
Thanks for using FixYa. First of all please check the Water temperature by using a thermometer inside the dishwasher to measure the water temp. It should be as close to 125 degree F to 140 degree F as possible. Now try using the temperature boost feature if your dishwasher is equipped with this cycle feature and check if this will help your wash ability issues.
Now check the Powder soap by making sure that you store your soap in a dry environment and it is not stale and clumping together. Possibly try a different detergent like a liquid or gel. Also, make sure the dishes are loaded properly, or dishwasher is not overloaded.
To check the proper filling dishwasher will fill with water up to and around the heating element. If water is more below the heating element, you may have low water pressure or a problem with the fill valve. Try & listen if it sounds like it is spraying the water around with enough pressure.
For low water pressure, try to clean the screen at the entrance of the fill valve, sometimes the fill valve can fail and not allow the proper water into the dishwasher and may need to be replaced. And, check the spray arm and pump cover for splits or leaks. Also make sure that the water is draining and is not accumulated in the dishwasher, if it is in dishwasher then check for clogged drain hoses and drain pump.
Low water fills are a very common trouble maker with today's dishwasher.
Please do rate this solution and revert for further assistance.
Thanks
Rylee
Nov 11, 2009 | Dishwashers
Hi our dishwasher goes through its cycle but does not dissolve the powder blocks and does not clean the dishes
Hi
Thanks
Rylee
Nov 09, 2009 | AEG 18 in. Favorit 54750Vi Slim-Line...
My dishwasher is not filling w water
check filter or drain hose it probably have a dirt,try to fill with water manually and turn on pump to dispossess water,if water not go out and pump work then you have dirt in hose or filter,if pump not work then pump is broken.
Jul 05, 2009 | Neff 24 in. S5443X2 Built-in Dishwasher
Error code LE and OE
The LG error code OE simply means “the pump is blocked”. Presumably the water isn’t being emptied properly. Check the exit hose, it may be clogged.
LE Code refers to a motor overload.Since the pump is blocked,the motor becomes inefficient in working.Once you get the pump cleared from blockages,I assure that you can get rid of these errors.Good luck with the machine.Please do post the results and comments.
Apr 12, 2009 | LG 24 in. LDF 7811 Stainless Steel...
Dishwashers Logo
Top Dishwashers Experts
