Question about Black & Decker 19" Electric Lawnhog Mulching Mower with Rear Bag
I have a black and decker t1 hover mower can you tell me which way you turn the plastic nut to remove the blade? thank you dave
5 Suggested Answers
SOURCE: Black and Decker Electric Lawn Mower MM850 wiring diagram
There is a solution for this problem at another website, the link is
http://www.ridgidforum.com/forum/showthread.php?t=8535
check it out and good luck
Posted on Mar 26, 2008
  • 313 Answers
SOURCE: black and decker mm675 lawn hog
after you install the fan the next step is to install blade then plastic spacer either orange or black spacer then the metal washer and the nut. nut will fit the 2 flat side of the shaft hold it while tightining the nut.
Posted on May 29, 2008
  • 313 Answers
SOURCE: WIRING DIAGRAM? FOR BLACK AND DECKER ELECTRIC LAWN MOWER
the pic says the connection are not right.all left side connection are for brake which is the red & white wire. all right side connection are two black wire.
Posted on May 31, 2008
  • 23 Answers
SOURCE: WIRING DIAGRAM? FOR BLACK AND DECKER ELECTRIC LAWN MOWER MM 850
looking down at the terminals, rotate push-button to the right. the wiring sequence is R, W at the top, then Black (in, from power source) , Black (out, to motor).
Posted on Sep 27, 2009
I cannot remove the blade from my B&D MM575 mulching mower. The manual says to block the blade, then loosen the nut. However, when I block the blade and turn the nut, the shaft continues to turn,...
You can use a pipe wrench on the shaft and a regular wrench on the nut. Disconnect your spark plug and tip the mower onto it's left side. You will have to use your left hand to go down through the mower shoot to hold the pipe wrench and your right hand to unbolt the the blade attaching bolt, it should come off immediately.
Remember you may have to purchase a new blade holder, since your problem shouldn't occur if your blade holder was OK. GOOD LUCK.
Jul 28, 2011 | Black & Decker Black and Decker Mm575 18"...
I have a black and decker lawn hog mower with a 19 inch cut that i am trying to change out the blade. My problem is i cant get the mounting nut off becausethe shaft keeps turning. I have tried everything,...
are you turning nut the right way ! on a lot of mowers, the nut turns off the opposite way the blade turns, to keep it tight. good-day ! Loosen the nut in the center of the blade with a wrench by turning the nut counterclockwise.
Jul 14, 2011 | Black & Decker 19" Electric Lawnhog...
Shaft turns while trying to remove blade on B&D MM875 elec. mower
Here's the scoop on the MM875: it has a plastic piece called a "blade insulator" (part # 241381-01) that "locks" the shaft to the blade, so that you can remove the nut by stopping or blocking the blade. If it has been damaged or stripped out, then stopping the blade won't do anything. However, the metal spacer directly under the nut IS still locked to the shaft (because of its shape), so you can use a pipe wrench or something to hold that in place and unscrew the nut. You might even be able to get someone in a home improvement store to do this for you. But you will still need to replace the insulator, which is only a few dollars.
Jul 22, 2010 | Black & Decker 19" Electric Lawnhog...
Elect mower blade replacement
mower, then blade, then plastic part, then metal square washer, then nut
Apr 23, 2010 | Black & Decker Garden
I have an electrical lown mower model LM 110 that as a broken plastic part under the blade but I don't have the manual to find the part number. Can you help me ?
IF is it a square plastic washer with 2 "wings\nocht" in the middle you can find at their servicenters because is a very common part and all the Black&Decker mowers use the same one. It holds the blade so you can thighten the nut.
Sep 18, 2009 | Black & Decker Lawn Hog 18-Inch 12 Amp...
Where can I find a Manual for Black Decker 19\'' Mower
Is this the lawnhog model MM875?
http://www.blackanddecker.com/ProductGuide/Product-Details.aspx?ProductID=2508
Check here for the owners manual
Apr 18, 2009 | Black & Decker 19" Electric Lawnhog...
How to remove blades from black and decker lawn mower
all switch off for safety. hold the blade & turn nut to counter clockwise. i use impact gun. socket 3/4".
Jul 22, 2008 | Black & Decker 19" Electric Lawnhog...
Black and decker mm675 lawn hog
Wedge a short piece of 2x4 between the blade and the housing,
turn clockwise to tighten !
May 19, 2008 | Black & Decker 19" Electric Lawnhog...
Black & Decker 19" Electric Lawnhog Mulching Mower with Rear Bag Logo
347 people viewed this question
Top Black & Decker Garden Experts
Nick Olsen
Roland W VanLue
Roland W VanLue
Tim Whalen
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
