Question about Sony Playstation 3 (PS3) Console
Unable to down load latest update ,to be able to get on line .....version3.41.... runs really slowly an gets to 8% an then comes up fault has occured ...tried conection test and both ip address an conection have succeeded
    President:
  • 1,139 Answers
If I were you I would download the update on your PC or laptop and place the file on a USB memory stick. Create a directory on the memory stick call PS3 and then inside that directory create a new directory called UPDATE. Place the PS3UPDAT.PUP file in that new directory called UPDATE. Now go back to your PS3 and go to settings, scroll all the way up the top and select system update. The next screen asks you to either update via internet or removal storage. Select removable storage and the PS3 will then update off of your memory stick.
Hope this helps and thank you for using FixYa
Posted on Aug 31, 2010
My laptop is moving really slowly and google won't load. I have chrome Wrong computer above should be Toshiba Satellite PC
To fix this multi problem laptop i would suggest to perform complete optimization. Here are few tips:
- Reinstall chrome
- Remove temporary internet files
- Stop unwanted services
- Repair corrupt registry entries
- Update the drivers that control your PC
For an instant fix use Intel Software Partner Reginout.
To download and install the latest drivers use ddriver scanning tool that will search for updated drivers online. You can get driver scanning tool here:
www.DriverScanner2013.net
Dec 04, 2012 | Toshiba Satellite L305D-S5934 Notebook
Volvo V-70 drivetrain & electronics faults
I suspect you have some loose connections or shorts in the wiring harness. I've had similar strange things happen with an Olds Bravada. Various transmission shifting problems, faults, etc. that all seemed to come from the engine's computer system getting incorrect voltages and readings due to wiring faults/shorts.
Dec 16, 2011 | Cars & Trucks
The dashborad says suspension fault
Problems with the air suspension seem to be less frequent with the Sport than in previous Range Rover models, but they still do occur. One owner reports "Whenever my RRS is lowered to "access" level a suspension system fault message apprears.". Another reports " Had the RRS back less than 2 hours and another "suspension fault." Also kept receiving messages that the vehicle is raising slowly and vehicle will raise when system cools. Couldn't even drive because it wouldn't raise out of access mode. Anyway, back to the dealer. Picked the RRS up again today-dealer said the EAS compressor was faulty and replaced it. So far everything is ok." Overall, most of the problems seem to be related to bad suspension height sensors or bad compressors. Angus Wade of the Czech Republic had his suspension light come on when in Germany; it started yellow and then red, then disappeared when he stopped and restarted the engine -- and has not happened since. His dealer said they have seen this a bit.
Weak Compressor: An official Technical Service Bulletin (TSB) LS-204-004 addresses "ELECTRONIC AIR SUSPENSION (EAS) WARNING MESSAGE AND LAMP ILLUMINATION". This deals with the warning message "Suspension Fault - Normal Height Only" message appearing with the Air Suspension Warning Lamp on. Computer diagnosis shows pressure increasing too slowly or unable to pressurize, with no air leaks. The usual problem is the compressor exhaust valve sticking, causing an internal air leak when the compressor is active. The bulletin recommends renewing the air compressor (RQG500090 is the latest specification air compressor with a stronger exhaust valve return spring)and installing and updating the air suspension control module software using WDS disc 13 or later.
Suspension Fault Message (random): One owner reported getting random suspension fault messages on his brand new RR Sport purchased in June 2006, well after the fix was in for the weak compressor. His suspension Fault message and Suspension Warning Light (Amber) came on after 5 days of ownership. He stopped and restarted the car, which caused the light and message to disappear, but they came on again after 5 minutes. Later the same day, the warnings disappeared again.
I have heard that on 2006 models, EAS fault messages can be caused by an internal leak in the Air Suspension compressor exhaust valve. The fix is said to be replacing the compressor updating the software.
Hope helps.
Sep 09, 2011 | Land Rover LR3 Cars & Trucks
The dashboard says suspension fault
Hope helps.
Sep 09, 2011 | 2006 Land Rover LR3
What programs conflict with this Z5600 system? put basic programs eg. office 2007, Firefox 3.6 browser, Google Chrome, AVG security, Google Earth + plug in. Screen locking up need to turn off/on to...
Have you got the latest Microsoft updates loaded? That can cause that especially with Google. I have not heard of any conflicts with FireFox. Office is suspect also if the Office updates are missing. Have you enough RAM to run all programmes at once? Check the specifications maybe.
Good luck.
Nov 09, 2010 | Acer Aspire Z5600 PC Desktop
Unable to load library
looks like the error happens when you use a corrupted or bad specific transition in you production. I recommend you update your direct x drivers to the latest, also update your flash to the latest. Then if the problem persists, take the transitions out of your production, and troubleshoot by trying each transition until you find the one that causes the "unable to load library" error. (if the updates dont do it) check your direct x version and tests by running DXDIAG at the start run menu hope that helps you!
Aug 29, 2010 | Corel Video Studio Pro X2 for PC
Computer slows down after ten minutes of watching video
Try downloading latest video drivers and Inmatrix Zoom player. It comes with an auto downloader for video codecs. Also try VLC Media Player and Media Player Classic. If all else fails, try Analog-X cache booster.
http://analogx.com/contents/download/System/cb/Freeware.htm
Mar 12, 2010 | Computers & Internet
Won't install without error message
Excerpt from: http://blogs.msdn.com/ie/archive/2009/01/26/upgrading-to-internet-explorer-8-release-candidate-1.aspx
There is 1 update required when running IE8 RC1 on multi-core XPSP2 x86 computers:
KB932823 or KB946501.
This update resolves a problem in which an access violation occurs when an application exists on a Windows XP SP2-based multi-core computer. It will be installed automatically if you select “Install the latest updates” option in Setup Wizard. If this update fails to install successfully, IE8 installation will be blocked until you manually install this update from Microsoft Download Center.
So see if you can do a manual install of this update. There are a number of other suggestions in the above link that might also help.
Good Luck!
May 22, 2009 | Microsoft Internet Explorer 8
Washer stopping and flashing F 06 fault
F/06 ---- ERROR IS FOR ----------- Drive Motor Tachometer ErrorThe control is unable to properly detect motor speed and the machine will shut down. If a failure occurs during high-speed spin, the door will be unlocked after 3 minutes.----------
AND TO SOLVE THIS ---------Check wire harness connections between the Drive Motor/Tachometer and the Motor Control Unit (MCU), and between the MCU and the Central Control Unit (CCU) --
Check the Drive Motor
Check the MCU
Check the Wire Harness
Apr 02, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Sony Playstation 3 (PS3) Console Logo
59 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
