Question about LG DLE2516 Electric Dryer
Not drying like it use to. The lint trap seal is torn. Could this cause it to stop drying well?
  • LG Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If your dryer is not drying like it once did or if you just have not taken the time to give yourself a clean dryer in a long time then you need to do that. At least once a year the dryer cleaning should take place. Lint build up in the dryer duct is one of the main causes for your dryer to fail.
Here is the rest of this tip about Dryer Maintenance
heatman101
Posted on Sep 12, 2010
When I dry clothes T shirt they seem to be getting pinched in the dryer and also ripped. Do the arms inside need to be tightened somehow?
YES COULD BE THAT THEY ARE CALLED BELLOWS AND CAN BE TIGHTENED FROM THE OUTSIDE BY REMOVING THE LID.
Dryer venting issues slow drying, fire flare ups, to hot, noise and clothes ripping etc
A lint filter that is full of lint will restrict airflow and lengthen dry times.
A blower wheel that is not firmly attached to the drive motor can slip and therefore not move air fast enough to properly dry clothes or even reduce airflow to the point where the high limit thermostat may trip and turn off the heat circuit.
In gas dryers, defective gas valve coils can create a symptom of taking too long to dry if they are intermittent. Check for proper flame ignition for the complete dry cycle to determine if this may be the cause.
The drum seals are used to prevent excess air from entering the dryer drum and act as a cushion between the drum and the front and rear bulkheads. The drum seals are made up of a felt like material. If the seal is torn or is worn then clothing can become stuck in the gap when the drum is turning. This can produce a scraping or thumping noise and the clothes can also be ripped and/or have black marks on them.
DOOR SEAL When the door is closed in gas and electric dryers the door seal helps to keep cooler air from entering the drum.
The vent tube or line itself. If it is kinked, smashed, to long, or filled, clogged with lint build up it can not only cause slow dry times but create a fire safety hazard. Try to stay away from using plastic or flimsy cellophane venting, aluminum is best!
To provide better air flow and heat dissipation try the following
Note the length of your dryer vent is a determining factor in how efficient your dryer will perform. If the total length of your pipe exceeds 25 feet then your dryer simply won't be able to perform as should, especially if your pipe runs vertically and through the roof. This is where a booster fan is sometimes needed. Booster Fans provide the extra push of air to exhaust the moisture and lint to the outside. These fans operate only when the dryer is activated, this is done by sensing the air flow through the pipe by a pressure switch mechanism or an electrical sensing relay which in turn activates the booster fan blower. I personally try to avoid adding booster fans simply because they are usually placed in a crawl space or attic and are therefore "Out of sight and out of mind." What I mean is... the unit could malfunction and you would never be aware of it. The result would be a restriction in the pipe which would cause a build up of lint at the fan. In addition, it's recommended that lint traps be placed before the fan itself which has to be cleaned out frequently. These can also easily be overlooked.
IF you do not have an OHM-METER, then you can check these issues by following the directions below:
To check the thermal fuse - You can bypass the thermal fuse (just connect the 2 wires together) for testing purposes only.
To check the thermal cut-out - You can bypass the thermal cut-out (just connect the 2 wires together) for testing purposes only.
To check the thermostats for continuity - - You can bypass the thermostat (just connect the 2 wires together) for testing purposes only.
To check the Element: Try removing element and physically looking at the element wire for a break in the wire.
Apr 19, 2016 | Dryers
Why does my Estate dryer squeal so loud?
Apr 06, 2016 | Estate Dryers
Hi my dryer works for abt 10-15 minutes then stops and beeps till i turn it off.also noticed moisture in side the drum
Moister in the dryer:
This means that the moist air is not escaping correctly and that is why it is taking so long to dry your clothes - if they dry at all.
a good start at cleaning out lint blocked areas, I suggest go to the back of the dryer and take off the vent pipe or hose and check things out with a flashlight. Clean out all the lint and dust you can, even use a vacuum cleaner on it. Make sure the vent pipe is completely clear of any obstructions.Non-rigid ventshas much worse air flow than smooth piping, so you might want to upgrade tosmooth piping.
Once you have all the lint and dust cleaned out of the dryer, go to where the dryer vents outside. Again, clean the area thoroughly. There is usually a trap door that opens when the dryer air is on and closes when it is not operating. It should be completely clear of lint and opening smoothly.
Also, look into the exhaust area on the dryer carefully to see if there is a hole or gap in the dryer's internal air ducting. Without the vent pipe connected and with no clothes in the dryer, start it and let if run for a few seconds and make sure there is strong air flow from the exhaust port. You should feel it strongly on your hand.
Re-connect the vent pipe and start the dryer again. Feel all around the bottom to see if any air is blowing out from under the bottom. This would indicate there is a break or gap in the dryer's internal ducting. If you do feel air, you will need to call a service technician to see if it can be repaired. If your dryer is very old, there could be a rust hole in the duct.
In conclusion Cause ·Poor venting is a common reason why water might leak into a clothes dryer. Since the dryer works to expel moisture, it is important that the dryer's vents are properly installed so that the humidity can escape.
Effect ·If the humidity in the dryer is trapped, it will eventually turn to water. This will lead to poor drying results or longer drying times, depending on the amount of leakage.
Prevention/Solution ·Faulty dryer venting can be prevented by making sure that the humidity is directed outdoors. Also, vents should be cleaned of lint and other debris before each load so that water can readily escape. Taking these precautions can ensure that the moisture will meet dry, open air.
Read more :http://www.ehow.com/facts_7167266_would-water-dryer_.html
May 21, 2015 | Fisher and Paykel Dryers
Fridgidaire Dryer not drying completely
Good Morning David, thank you for allowing me to assist you!
I understand your dryer is experiencing lack of heat. There are several factors that could cause this; some of which you can check prior to scheduling a professional.
Have you checked your lint filter recently? I ask because if a lint filter is full of lint it will restrict airflow and lengthen dry times. To keep your dryer working correctly, clean out the lint folder area after each and every use. Check the lint filter for any buildup of fabric softener that will also restrict airflow and wash with soapy water to clean. If the filter is damaged then it will need to be replaced.
Additionally to checking the lint trap area, please investigate the ventilation (duct work) system connecting to your dryer. Often we forget to clean this duct work therefore over time debris can restrict air flow. Check the air flow by disconnecting the accordion-like duct work from the dryer appliance. Run a drying cycle, with clothes inside the unit, but keeping the duct work disconnected. If you notice any improvement, then the ventilation duct work (often going through your floor or side wall) will need to be thoroughly cleaned. Also make sure you do not have multiple turns or kinks in the duct work. The more curves or turns this duct system has to take to exit the air outside, the more restricted it can get. The more restriction you experience the more time it will take the unit to dry.
Do you notice any unusual rumbling or rubbing noise when in use? This could indicate a faulty blower wheel. A blower wheel that is not firmly attached to the motor can slip and therefore not move air fast enough to properly dry clothes or even reduce airflow to the point where the high limit thermostat (a fuse like component) may trip and turn off the heat circuit. A loose blower wheel will usually make a rumbling noise that is easily noticed. Inspecting the blower wheel is usually a task for a professional considering you must take apart most of your appliance to make sure it is tight to the motor shaft.
If you have a gas dryer, gas valves could also cause you an issue. Defective gas valves can create a symptom of taking too long to dry if they are intermittent and require professional attention. A professional is needed to check for proper flame ignition for a complete drying cycle to determine if this may be your point of concern.
On many dryers you will find "drum seals" in between the unit's drum and the front door. The drum seals are used to prevent excess air from entering the dryer drum and act as a cushion between the drum and the front and rear access. The drum seals are made up of a felt like material. If the seal is torn, or is worn, then clothing can become stuck in the gap when the drum is turning. This can produce a scraping or thumping noise and the clothes can also be ripped and/or have black marks on them. This will also affect your drying time tremendously.
While you are checking the drum seals please check the door of your dryer as well. When the door is closed in gas and electric dryers the door seal helps to keep cooler air from entering the drum. Keeping the correct temperature at all times inside the dryer ensures that the clothes will dry efficiently. If clothes are not drying then inspect the door seal for signs that it may be worn or damaged.
If none of the above solutions prove to be successful, it would be advisable to contact an experiencing repair tech to assist further.
Best of luck!
Nov 23, 2013 | Frigidaire Affinity ATF7000E Front Load...
My dryer heats up but does not dry clothes. I check ventilation and lint trap, there is no buildup. what could cause it to take forever to dry clothes?
If the drum gets hot to a real degree it has to be a blockage between the drum to where the air exits the home.
They do make a brush designed to go into the area where the lint trap is and be long enough to come out the rear of the unit---A lot of places will come out and professionally clean from trap to vent outlet
A blockage can be dangerous as hundreds of fires happen each year from the lint catching fire in the dryer.
The tube to the outside may seem clear but if blockage anywhere from lint trap to it, that will cause this problem and present a possible fire hazard.
Its not unlike having your vac not pick things up very well...except there is rarely a fire with that.
Dec 16, 2012 | Kenmore Dryers
Hi, the dryer keeps stopping (the timer jumps), only runs for about 10 mins at a time AND the part that worries me the most is that I haven't had to empty the lint trap which I usually do after e
sounds like the vent tubing is not hooked up as it should be and that can cause a lot of lint buildup inside of the dryer parts. take it apart again and clean out all of the lint because this is a fire hazard. make sure that the vent is connected to the lint trap and try working it again. it sounds like maybe the buildup of lint is making the drying hard to do.
Aug 27, 2012 | Whirlpool 8579123A DUET DRYER DR REVERSAL...
Our GE Profile DPSB613ED2WW dryer has been losing drying efficiency for the past few months. It now takes three cycles to completely dry a load. The dryer is heating (although we assume not correctly) and...
How is the vent discharge air flow out the back of dryer? If not very strong check out lint trap cavity for blockage or obstuction causing lint to build up, blocking air flow from drum cavity. Once found a pocket comb that had got into lint trap housing and created a lint dam blocking air flow.
Feb 14, 2011 | GE Dryers
Lint is not going into pull out lint trap. The lint screen is torn and lint is collecting behind trap.
Poor air flow would be my guess. How long is the vent hose? Does it have more than one angle/turn before venting outside? Is the lint gathering around the outer edges of the door? Keeping the length of air travel shorter will improve the operation.
May 12, 2009 | Fisher and Paykel DEGX1 Electric Dryer
Plugged venting causing low heat and poor lint output?
you need to check the dryer vent hole on the back of the dryer,make sure it's not blocked,also check the wall vent for the same thing,most of the time if there is a clogg it holds the moisture in the dryer and it take forever to dry,you can use a shop vac to **** out any clogged lint in dryer and wall ,then if you have a leaf blower put it on the wall side and blow it it all out.let me know how you do-mike
Oct 30, 2008 | Dryers
Maytag neptune dryer lint problem
HI bob. thanks for your question. look at your lint filter. if its torn replace the screen. its the only way to stop lint . and clean the venting to the outside, thanks the appliance doc. please rate my answer. thanks
Sep 23, 2008 | Maytag Neptune MDE5500AY Electric Dryer
LG DLE2516 Electric Dryer Logo
136 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
