AVOL tv: hooked up DVD player, cannot get tv to go in any mode other than TV How do i get it to go to DVD mode?
SOURCE: hooking up the dvd player
how do i hook up dvd where do i put the wires in what input
Posted on Nov 10, 2008
SOURCE: How do I hook up the DVD player to the TV?
Hi, basically you need to put them into their respective slots in the back of the tv. I know this can be frustrating because the slots are all faced downwards, tucked behind this piece. Look at this image, which should be what you are seeing if you're using a Toshiba 26'' 26AV502U, a model similar to yours.
http://www.bestbuy.com/site/olspage.jsp?id=cat13506&type=page&h=387&skuId=9034733&productId=1218010846690&&viewtype=backView&count=0
Look at the four plugs with labeled "Video 1 In." "L Audio" is your white plug, "R" is your red plug(R actually stands for Right [Audio Input]), and Video is your yellow plug. It would be wise to remember this for every Audio/Video cable accepting unit. It makes sense you are putting the cables IN to the tv, hence "Video 1 In."
Now, to tell the tv to read the video input, find and hit the "Input" button on the remote, and it should be one of those options..(there are only a couple to choose from).
Hope these directions worked for you, and enlightened you!
Posted on Jan 13, 2009
CRTN
  • 716 Answers
SOURCE: DVD Hook up-Olevia 266-T11
From Cable Or Rca Out Of Your Dvd Player To Your T.v. Make Sure You Push The Tv/Video Button To View The Dvd If Its Hooked Into The Rca Jacks.
Posted on Jan 14, 2009
dsacco86
  • 1077 Answers
SOURCE: I hooked my dvd player up to my tv. There is no sound
You have a great night too.
Happy DVD movies. :)
Posted on May 25, 2009
SOURCE: DVD Hook up to Proscan TV
if using RCA connector cables, connect the left and right audio cables to D and D1, then connect the Video cable to the video connector right above the S Video port.
Posted on Aug 12, 2009
#dhb300b DVD player plays only black and white my TV is a JVC HD TV with HDMI cable from driver TV box hook up DVD to TV audivo to audivo video to video set TV to component program DVD to TV but plats
The yellow/red/white cables are COMPOSITE cables. COMPONENT cables are RED/BLUE/GREEN. You can buy those at any electronics store. Your best bet, though, is to stick with HDMI if you can.
Jan 21, 2015 | JVC Televison & Video
Avol TV remote
See this links
http://shopping.rediff.com/shop/productdisplay.jsp?Universal-Remote-Control-for-all-TV,-DVD,-VCR,-VCD,-AC,-CD-Player&prrfnbr=10203960&source=browse&frompg=Accessories
Aug 07, 2008 | Televison & Video
I can't find the booklet on this DVDplayer and I don't know how to hook it to the TV or what channel the TV has to be on. I put the red, white & yellow connections in the Output/Video on the back of...
The the RCA cable YELLOW,RED,WHITE should hook in those holes said "OUT" on the DVD player.The tv should get the other end RCA cable YELLOW,RED,WHITE said "IN" hook in those holes in the tv.Now ur tv should play dvd disc,on the tv mode or av modes like 1,2,3 modes.
Jun 09, 2010 | Pioneer DV-250
Im trying to set up my tv, it was given to me as a gift, my uncle was using it it works i can change the channels but when i try to work my dvd player with it, only the audio comes on the screen stays...
Please few things...
1- Make sure audio and video wires are hooked correctly in AV input of tv and you selected that AV input in tv with its remote.
2- Also check your dvd has not been set on progressive mode if you hook dvd player through yellow-red-white wires with tv.
3- if dvd player is set on progressive mode, then hook it with tv by component video input, red-green-blue for video and red-white for audio.
Hope this info will solve your problem.
Thanks.
Mar 17, 2010 | Toshiba TP55H60 55" Rear Projection...
Avol tv
Just unplugged a few hours.
Feb 24, 2010 | Samsung 50 in. Flat Panel Plasma HDTV
Hooked up dvd player to tv but no picture
Select Source button from your tv remote keep in AV mode than cheked if you have conected with yellow/red/white rca wire
Jan 21, 2010 | TruTech PM1919BXA1 19 in. LCD TV
I need to know how to hook up DVD player with Cable TV I have the cable with the white yellow and red. I hook one end into the TV and one into the DVD player. I don't get a pic or sound. I do not havethe...
The key is having at least a Universal Remote ($10.00 or less) that will operate your brand of TV. Your TV is only looking at "stations". You need to make it see Aux-1, Aux-2, or Line In mode. BUT, another trick is to run the DVD into your VCR (if capable). Select the VCR proper "input mode" (Aux-1, Aux-2, or Line In mode) then the DVD will play through the VCR and it will play through the TV on either channel 3 or 4. Problem solved!
Jun 27, 2009 | Sony DVP-NS501P Progressive-Scan DVD/CD...
AVOL 15" TV/DVD
I am not sure but maybe purchase a DVD cleaner kit for the player around $10. USD, and make sure the DVD itself is clean and without scratches. Also, try dvd player on another tv to see if it is OK. Other than that input settings. I do not know of any inherent design problems in the unit. Have you tired their web site?
Jul 29, 2008 | Hitachi 46W500 46 in. TV/DVD Combo
Avol TV remote
I own an AVOL 19in TV, I just got my comcast cable hooked up; I too was plagued by initially having to use my other remote to turn TV/volume on/off up/down. Being the code is not listed in the Comcast universal remote instructions, in the above answers someone mentioned APEX as a parent company with AVOL; I was able to use a code from the APEX codes listed in the Comcast universal remote instructions to get the controller to work with turning the TV power on/off and volume control. The code that worked for my particular TV was 10765. Try these codes for your TV to see if they work- 10748, 10879, 10767, 10890. Hope this helps.
Mar 17, 2008 | Televison & Video
Televison & Video Logo
193 people viewed this question
Top Televison & Video Experts
