Question about Cooper Wiring Devices "ACE" COMBINATION SWITCH 15A/120-277V AC
I have a two single pole switch. when hooking it up with line voltage on the left side of switch and neutrals tied together and ground connected i still get 120 volts to bottom of switch when i flip the top switch.
  • 885 Answers
Just to make sure: Your white wires should NOT be attached to the switch in any way. If you have multiple lines coming into the box, both incoming and outgoing, strip about a 1/4" of insulation off all of the white wires, wire nut them all together and tuck them into the back of the box. Do the same with the ground wires and add a piece of wire to run to the switch if it has a ground (green) screw.
On a double switch the two screws on one side that are close together have a jumper on them so you only need one black wire from the circuit breaker to power the switch. If you need seperate circuits for the switched objects you can cut the jumper and run seperate wires to the top and bottom switches. The two screws on the opposite side are further apart are for the black wires that come from the switched objects.
Posted on Aug 31, 2010
T-103 Black, white and ground what thermals go where
You should be able to find a wiring here. Search you should have a white, red, black, wire there. hook the white to the neutral or common. then hook the black wire to term # 1 the red wire to term # 3 and then hook the load side to term 2 and 4. it should work doing this. don't forget to hook up the ground. hope this was helpful. contact me if u need more help
Feb 03, 2015 | Intermatic T103 Indoor 120-Volt 40-amp...
I have a 1755 3 rocker switch, http://communities.leviton.com/docs/DOC-1920, that I'm trying to install in place of an older switch. Here are the pictures for both, the new switch and old one:...
Ledio, I am unable to access specific photos on Picassa
https://plus.google.com/106982528064073343888/posts
I have downloaded instruction manual for 1755 rocker switch
This is ordinary triple-rocker-switch to control 3 different loads.
It is like having 3 single pole switches and each switch controls a separate light (Load)
This is single pole switch for 120Volt, and not suited necessarily for 240Volt loads.
Switch is not for 3-way application as typically found in hallway where 2 switches control same light.
1) You have 4 wires.
Electricians don't guess, they test.
There are 4 types of wires in 120Volt and 240V household wiring: Hot wire, Neutral wire, Load wire, and ground wire.
Load wire means the wire that connects to switch and goes to Light, fan, motor (load)
Hot wire always connects to one side of switch.
Neutral never connects to switch.
Load wires connect to side of switch opposite Hot wire.
Bare copper ground wire connects to any green ground screw.
2) One-and-only-one wire in each 120Volt electrical box is Hot. (assuming you are not replacing
3-way switch or working with 240V)
3) Separate all 4 wires for testing. Tape tester leads to wood sticks. Turn power ON.
Test each wire to bare ground wire. Tester will light up on Hot wire.
4) Hot is identified. Next, find the neutral wire if it is among the 4 wires.
Test Hot wire to all other wires in box, except bare ground wire.
Tester will light up on neutral wire.
Tester will not light up on Load wires.
5) NOT EVERY switch box has a neutral. Or the neutral wires can be twisted together and covered with wire nut and pushed to back of box.
The neutral may be up in the light fixture. Neutral located in ceiling box is typical with bathroom fan-light-heater combos.
If neutral is not one of the 4 wires, then don't worry about the neutral connection because it will already be wired together.
6) Image of 1755 switch shows 1 screw terminal on the Hot side, so connect Hot wire to this single screw.
Other side of switch has 3 screws for connecting each of 3 Load wires.
Note: Neutral wire is NEVER connected to a switch.
http://www.frostelectric.com/WOE-IMAGES/00381764.jpg
7) Since I cannot see wiring project or know what loads or how the testing comes out, I suggest connect the Hot wire to single screw terminal.
And then connect 1 of the other wires to other side of switch. Not a neutral.
Turn power ON, and try switch.
Process of elimination might yield result.
8) Add a comment with more question, and it sends e-mail. I will respond.
More resources:
http://waterheatertimer.org/See-inside-main-breaker-box.html
http://waterheatertimer.org/B220C.html
http://waterheatertimer.org/How-to-wire-Cooper-277-pilot-light-switch.html
http://waterheatertimer.org/images/How-to-wire-double-rocker-s.jpg
Sep 25, 2011 | Electrical Supplies
I have a Leviton single pole rocker switch grnd, pilot light back and side wired #5628-2W i am trying to hook it up so light is on when switch is on i have 2 black wires 2 white wires and 1 ground wire how...
easy one first: ground wire to green screw. We have to assume the two black wires are the hot(coming from power source) and switch leg(going to light). Switch will have two brass colored screws. Looking at the switch with the off/on markings right side up. Put hot wire on upper screw and switch leg on other brass screw, With nothing hooked up, the hot wire will be the only wire with voltage on it. You can buy a non-contact voltage tester at Lowes or any place that sells electrical supplies. Now we must assume the two white wires are neutrals(one coming from power source and one going to light. The pilot light part of the switch will either have a silver colored screw or a white pigtail on it. all whites hook together. The pilot light is wired internally to the switch leg. Your switch should work properly now.
Jan 28, 2011 | Leviton COMBINATION SINGLE POLE TOGGLE...
I have the unit wired and it does not wotk.I have black to black,red to red green to ground and white to white,any thoughts? Thank you
Electrician test wiring before connecting anything.
First of all, you don't mention what type of switch was replaced.
1) Leviton 6230 countdown timer is made to replace single-pole light switch only.
Single pole is where 1 switch controls the Load (light fan motor)
Your wiring sounds like 3-way switch.
3-way is where 2 switches control same Load.
For example a hallway usually has 3-way switches.
To confirm. If old switch has 1 dark screw, 2 brass screws, and 1 green screw, then that is 3-way switch. Use Leviton LTB15, LTB30, LTB60, LTB02, LTB12 countdown timer for 3-way.
Smarthome sells product and shows .pdf manual
http://www.smarthome.com/4255/Leviton-LTB60-1LZ-4-Button-10-20-30-60-Minute-Countdown-Timer-Switch/p.aspx
2) If old switch has 2 brass screws and 1 green screw then that is single-pole switch.
3) If you are replacing single-pole switch, here are testing & wiring instructions for Leviton timer.
Remove device and separate wires for testing.
Use ordinary two wire tester.
Tape tester leads to wood sticks so hands are away from power.
Do not untwist wires that were twisted together before you started.
Turn on power.
Tester lights up on Hot wire. This wire will connect to timer black wire.
Now you know Hot wire.
Test Hot wire to each of the other wires, excluding bare ground wire.
Tester lights up on neutral. Timer white wire connects to Neutral wire.
If box does not contain Neutral wire, then timer white wire connects to bare ground.
Timer green wire connects to bare ground wire.
Timer red wire connects to wire going to Load.
Dec 26, 2010 | Leviton 6230M Decora Four Preset...
I have a combination single pole switch. Light switch and receptacle. In have running in the old box 2 white, 2 black and a ground. How do I install the new switch to have power to the light switch and...
You are replacing old switch-receptacle device.
New device also has switch and receptacle.
You want switch to control light, but not receptacle.
You want receptacle 'hot' all the time.
You have 2 cables that enter box.
Each cable has white, black and ground wires.
Ground wires are twisted together and attached to green ground screws and not discussed more.
Screws on new device:
Side 1 of device: New device has dark screw(s) or brass screws on one side ... these screws are connected together by brass plate. This side is the Hot side of device.
Side 2 of device: Other side has 2 separate and unconnected screws. These screws are not connected in any way. Each of the 2 disconnected screws sits opposite the switch and opposite the plug.
Cables.
One cable comes from breaker box. This cable has a Hot and Neutral wire. The Hot is black. Neutral is white.
The other cable goes to Load (light). Black supplies power to Load (light), and white connects to Neutral.
If you are uncertain which is which, testing is shown below.
Connect the device:
Side 1 of device: Black Hot goes to dark colored screw(s) that are connected by brass plate. (This is only wire connected to this side of device)
Side 2 of device: Black that goes to Load (light) connects to screw that sits opposite the switch.
Side 2 of device: White Neutral connects to screw that sits opposite the plug
One wire is left .. the white from light. This white wire connects to white Neutral wire. Since white neutral is already connected to device, look on back of device to see if there is a quick-connect hole for you to shove wire into back of device. If device doesn't have quick-connect, then twist white wires together, and add a short jumper wire to device, and then all the whites are connected to neutral. Circuit is complete.
How to test for Hot and Neutral
Separate wires.
Turn on power.
Test each wire to bare ground.
Tester lights up on hot wire.
Now test hot wire to other wires.
Nov 17, 2010 | Leviton COMBINATION SINGLE POLE TOGGLE...
Can the Utilitech Mode # 0141224 be used as a 3 way or is it single pole only. No where on the package is that informatio given. Thank you
I believe it is a single pole only, and also requires a neutral to operate.I'm assuming it has black(line) red(load) white(neutral) green(ground) If you need a three-way or only have a switch leg in your box (no white wires) then I'd recommend one of intematic models that can be connected either as a single pole or 3way and requires no neutral.
Aug 13, 2010 | Intermatic Inc. ST01C Digital In-Wall...
3 single poll rocker switch alternative wiring
You never hood the neutral to the switch. The neutrals are always tied together and pushed back into the box. You only hook the line (power) & load (light) to the switch. Of course you also hook the ground to the switch.
Jan 09, 2010 | Leviton 003-1755-W Three Rocker Switches
How do you wire a Two Single Pole Switch for each switch to run seperate lights all off of one circuit. Example: Recess Lights on one switch and a Track light on the other switch. 6 black wires, 6 white...
so 6 grounds is connected together, and conneted to mains ground (direct connection), the white wires is (mains Neutral) and you connect all 6 white wires together (to doble pole safety switch) in one end pole switch, and you connect a wire from another pole the same end at common Two Single Pole Switch and connect (Black wires recess lights) to one free pole switch and (Black wires track lights) to another free pole.
The mains connect to safety switch live (Black or Brown) to another free safety switch pole, Neutral (White or blue) to free safety switch pole and earth to ground wires on mains connector.
Note: Allways use a mains 300mA diferencial safety switch, for better protection.
Jan 02, 2010 | Computers & Internet
Need to connect 3 wires from pole to 2 wires in unit
It sounds like a 120 volt line coming in from the pole. Red is the hot wire, white the common or neutral wire, and the green ground. Hook the red and white to the two main wire lugs in the unit and the green goes to the frame or ground lug that will tie to the frame.
Jul 12, 2009 | Heating & Cooling
Wiring to a 3 single pole combination switch
run 14-2 wire to power switches, then run one 14-3 wire and one 14-2 up to fixture..you will have an extra neutral but its okay... just tie all nuetrals together....this gives you the needed 3 hot wires!
Mar 03, 2009 | Pass & Seymour / Legrand 1595-2SWT...
Cooper Wiring Devices "ACE" COMBINATION SWITCH 15A/120-277V AC Logo
Top Cooper Wiring Devices Electrical Supplies Experts
ken skalski
Jim Y
Jim Y
Are you a Cooper Wiring Devices Electrical Supply Expert? Answer questions, earn points and help others
