Question about GPS
I have tried to update to home2.3but now cannot get anything on screen to device plus it will not turn off.
    Problem Solver:
  • 18 Answers
What device do you have?
Posted on May 09, 2008
Os transferring error
The standalone version of the OS for the TI84Plus/TI84Plus SE are not for TI-Nspire with TI84 keyboard. The 94 Plus part of the TI-Nspire is updated when you update the OS of the TI-Nspire. The version numbers are different.
To update you TI84 portion of the TI-Nspire, update the OS for the TI-Nspire. Thy are now at Version 3.2.3.1233
Sep 26, 2013 | Texas Instruments TI-84 Plus Silver...
Barmin ETrex Hc won't turn on
I had the same problem as you with the unit switching off.
I found this link http://www.fixya.com/support/t2084694-gps_stay
I held down the joystick button to perform a "Bootlock"
I don't know if it will work for you.
I got Garmins WebUpdater here http://www8.garmin.com/support/download_details.jsp?id=931
Feb 01, 2010 | Garmin eTrex Venture HC GPS Receiver
I have a TI 84 plus silver edition. Won't turn
The problem may be due a screen that is too light to see anything on it. Adjust the screen darkness.
  1. Press [2nd] key and release it.
  2. Press and HOLD the [UpArrow] to draken screen.
  3. Release the [UpArrow] when screen is dark enough.
You can also connect it to the computer to see if TI Connect finds it. If it does, update the OS to version 2.53MP.
You change the backup battery if the calculator tells you RAM CLEARED each time you turn it ON.
Dec 16, 2009 | Texas Instruments TI-84 Plus Silver...
TI-83 Calculator RAM cleared
To clear the message press [CLEAR]
If calculator shows message after you turn it [ON], it may be due to drained backup battery. If you have to change it make sure you have main batteries in and in good state, and installed.
If calculator appears frozen, press [2nd] [QUIT] to interrupt what it is doing.
I see you do not have the latest ROM (OS). You should download the latest ROM (1.19) and install it.
Use the education.ti.com link to download the TIConnect software. Install it on your computer. Run the TIConnect software. Connect the calculator to a computer (USB cable or TISilverLink cable or TI Graphlink black cable). Press the ON button, do not worry if you do not see anything on screen (contrast may be too light).
In TIConnect main window, click the TI Device info button. The software will try to detect the calculator. If the answer is NOT FOUND on any of the ports, click the communication settings at the bottom of the window.
Select Device: enter you calculator model
Select Cable: SilverLink, USB,
Select port : USB1 or COMx
and click OK. The TI connect software will give you some messages if communications with calculator cannot be established.
If you establish communications with the calculator, press the Update button in TIConnect main window. Install OS directly to the calculator. You may update other installed applications.
If you cannot communicate with calculator with the computer try to update by cal-to-calc connection with a working calculator/
Hope it helps.
Sep 27, 2009 | Texas Instruments TI-83 Plus Calculator
Canon MV890 not being detected
It probably isn't anything your friend did. There is a conflict somewhere between your driver for your camera, your software and possibly an update somewhere along the way.
Try these two things to see if the computer is detecting the device and let me know what the results.
1. With your camera turned off plug it into the camera.
2. Make sure that your USB port is a 2.0 if not you may need to by an adapter to give it a little extra "boost"
3. Make sure that the camera is not in capture mode that it is in transfer mode.
4.Now go to "My Computer" pay attention to what is there then turn the camera on.
Has the camera shown up?
(be sure to turn the camera off, right click, safely remove, then unplug)
If that does not work try this -
1.Go to Start- Accessories- Device Manager
Im not sure how it will show up here it just depend on where it was installed originally. So we are going to expand 2 diffrent places.
2.Look for
+Disk Drives, click the plus to expand it
+Imaging Devices
3. Plug in the camera wait a second to let the computer recgonize the device then turn it on.
Has anything changed on your screen?
Feb 01, 2009 | Photography
Sandisk sansa fuze mps player plays but the screen is blank, why?
is it still covered by warranty? do you see anything on the screen for example if you place it under a lamp, do you see anything on the screen? that would mean the backlight is faulty.
you may have a faulty backlight or loose connector. If you got warranty that will cover the fix.
warranty and user guides
http://www.sandisk.com/Retail/Default.aspx?CatID=1679
you can also try updateing the firmware of the device. sandisk website go over here
http://www.sandisk.com/DriverDownload/index.asp
select your sansa fuse from the list, click find driver
on the new page select sansa firmware updater click continue
click skip registeration
download the firmware updater
install the updater
plug in the device when asked and follow on screen instructions.
Aug 19, 2008 | Audio Players & Recorders
TomTomOne 1st Edition
Do you have an account at TomTom?
If not, make one here:
http://www.tomtom.com/myTomTom/myProfile/index.php
Do you have TomTom Home installed?
Find it here:
http://www.tomtom.com/plus/service.php?ID=17
Connect and update after completed previous steps...
Apr 09, 2008 | Tomtom One Europe v2 GPS Receiver
The buttons on the front don't work.
Have you tried updating the firmware of your Zen V Plus? I've had mine for almost an year and haven't had these issues -- I updated the firmware as soon as I unpacked it.
try downloading the
MP3 player recovery tool from Creative's website (the tool contains the latest firmware update available -- 1.15.03). Plug your ZV+ into your PC, run the program and let it update the firmware. Then format, reload your music and try it.
By the way, before updating the firmware, let the battery have a full charge, ok?
Sep 19, 2007 | Creative Labs Zen Touch MP3 Player
Zen V Plus problems with brightness
try downloading the
Jun 03, 2007 | Creative Labs ZEN V Plus MP3 Player
GPS Logo
29 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
