Question about Canon PowerShot S410 / IXUS 430 Digital Camera
When i turn it on the screen goes blank and in the bottom left side corner says E18. Also it makes a beebing noise.
  • 6,831 Answers
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair centre for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance. Also, please be so kind to let me know if you found this helpful.
Regards
Andrea.
Posted on Feb 10, 2011
How do I fix a Sony TV that starts then screen goes blank
Check and replace damaged component/s at its horizontal scan output section circuit. Check the LOT (Line Output Transformer) too for damage. Replace the horizontal scan output transistor. Check the input voltage to LOT. If the voltage is absent check the feeder resistor; if any. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Type in the brand name of your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
Mar 24, 2015 | Sony Televison & Video
The camera was dropped by my son, which happened before, when turned on the canon logo shows then the screen is black. An error message in the bottome left says E1b or E18. Help!! thanks
Here is some information on the E18 error: http://www.e18error.com
A repair guide (suggestions) http://www.e18error.com/repair.html
Forum for users with the same problem http://www.e18error.com/posts/index.php
May 21, 2009 | Canon Cameras
Camera won't function - "E18" (Canon PowerShot S230)
Try lightly tapping lens on a hard surface. This sometimes reseats the lens. If this does not work take to bits and reassemble.
Dec 13, 2008 | Canon PowerShot A75 Digital Camera
When I try to zoom, screen goes black and "E18" appears in bottom corner
I won't say this is a solution but to prevent the lens retraction E18 message which seems to be common with Canon zoom lenses, I put the extension tube on mine. Sometimes I put a polarizer lens on it but usually I just leave it on to protect the lens when it is on. I have dropped it (on the carpeting at home) and never had a problem. If you have a Canon with a zoom lens, get a lens hood for it ASAP!! My wife's A520 has one on hers too. No problems.
There are lots of other places on the web with suggested fixes. Keep looking and keep enjoying this camera. Merry Christmas all.
Oct 31, 2008 | Canon PowerShot S2 IS Digital Camera
E18
E18 is the canon fault number for lens error. Is the lens stuck out? does it click when the camera is switched on? Try lightly tapping the lens on a hard surface. This sometimes resets the lens. If all this fails take it to bits! (but watch the flash module as this can give a nasty shock.Big black capacitor) You will see the lens module take the it to bits carefully and re seat the components. I have done a few over the years. It takes about an hour. If you have any more issues contact me.
Sep 04, 2008 | Canon PowerShot A400 Digital Camera
My ? Nuvi 710 GPS froze. I restarted it , now all I can get is a blank screen with a black dot in the bottom left corner and a message saying press dot. Holding the off switch over to the left makes it...
My ? Nuvi 710 GPSicon1.png froze. I restarted it , now all I can get is a blank screen with a black dot in the bottom left corner and a message saying press dot. Holding the off switch over to the left makes it restart but still goes back to the same screen Is there any way I can fix this?
Apr 22, 2008 | Garmin GPS
Trouble with lens and blank screen
http://www.e18error.com/repair.htmls shows pictures of how to take apart a similar camera.
need an online translator from Bulgarian.
Canon Repair is out of the question.
Dec 09, 2007 | Canon PowerShot S30 Digital Camera
E 18 problem
the E18 means the lens system has a problem. I had it with my S2 and sometimes it worked, sometimes not. Eventually it stopped working. The only solution was sending it to repair, they changed the lens system.
Best Regards
Nov 19, 2007 | Canon PowerShot S2 IS Digital Camera
Screen is showing E18
The E18 error message relates to a problem with the zooming mechanism (lens would not retract or extended) Press the power button on and hold it down while extending and twisting the telescopic zoom lens. It might fix you problem. In any case it could not make it worse Good luck!
Aug 10, 2007 | Canon PowerShot A520 Digital Camera
SD200 E18 Error
E18 is the error that comes when when the lens is stuck, so if the lens is stuck out, turn off the camera, carefully turn the lens until you hear a small clicking noise, then turn it on. I had the exact same problem, and that fixed it for me
Jun 23, 2007 | Canon PowerShot S400 / IXUS 400 Digital...
Canon PowerShot S410 / IXUS 430 Digital Camera Logo
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
