Question about Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System
WAS WORKINIG FINE NIGHT BEFORE WOKE TO IT NOT WORKING FRIDGE AND FREZER BOTH I DID HERE THE FREZER FAN RUNNING STILL. THE COMPRESSOR TRIES TO GO ON BUT SHUTS OFF RIGHT AWAY.
  • Whirlpool Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Posted on Sep 01, 2010
I recently brought this fridge out of storage, it was working perfectly fine before i put it into storage. I plugged it in and the lights are on, i let it run for a few hours but it did not get cold or...
The cooling fans do not run unless the right temperature is reached. The important thing is to find if the compressor is running. If you do not hear a whirring sound when the fridge is powered on, then the compressor has a problem. Generally when you put in storage the refrigent can leak out and needs to be refilled.
If the compressor is running then check the thermostat settings. Might also help if you provide the make and model number of your fridge.
Oct 10, 2011 | Refrigerators
Frezzer not Keeping things Forzen. I turned up the adjustment, and left it over night to adjust to new Temperature setting. I woke this morning to find everything almost completely Thawed. Fridge seems to...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Mar 18, 2011 | Refrigerators
Fridg is not cooling.frezer working real good.
Open the freezer compartment and listen for the fan motor if you don't hear it but you can hear the compressor running. youll need to first make sure that the door switch is working( If the lights go off when you press the button it should be okay). You'll need to remove the back panel and inspect the coils if frosted over evenly and the fan still is not working give the fan a little push. if it will not go, you need to see if it has voltage if so, replace the fan. If no check the defrost terminator which only on amanas will keep the fan off. In this case replace the defrost terminator(it look about like 5 quarters, with 2 wires clipped through the evaprator coils in back of freezer.
Jul 15, 2010 | Amana ABB1927DE Bottom Freezer...
NDR 1292
Make sure the condenser fan underneath the unit is running when the compressor is. I don't know what else it could be unless the door gaskets are in bad shape.
Aug 20, 2009 | Dometic NDR 1292 Refrigerator
Frezer ok, fridge warm
clean coils on back or underneath the fridge and make sure the 2 controls are set right, also check that fan in freezer is blowing. If there is a fan by the compressor see that it is working
Aug 05, 2009 | Refrigerators
Compressor not working warm fan inside frezer run
Heat exchanger was iced over, took a hair dryer and melted ice. I think defrost heater element is bad will check it this week end. I put a new computer in the frige about 3 mounths ago and will check if it has gone bad. The compressor is working fine.
Jun 03, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Frezer not freezin fridge not cooling
try to change the clickson and relay on the compressor and if it still doing that there are two problems to look for or a blokage in the system or the compressor are broken
May 13, 2009 | Maytag Appliances Magic Chef 18 cu. ft....
Amana side-by-side fridge freezer only cold at the bottom
yes the evap fan in the frezer should be running when the compressor is running[it may not for a minute or so as it starts up.Amana's are good for the connectors at the evap fan motor comming apart.the connectors are white and will look like its together but when you pull it will come apart.i would always cut the connector out and use a wire nut so wont happen again.if any other questions please email thru FixYa and i will be glad to help. God bless ,tom
Jan 30, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Fridghefreezer not working
Make sur compressor is running.
Unplug for 20-25 min., plug it back in and listen for compressor to start. You will need to be behind the Ref so you can tell if you hear the compressor or the condenser fan running.
Ice/frost build up in freezer.
This is a failure of the defrost system. Evaporator fan, heater, timer, one or more could be bad.
Jan 23, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Refrigerator will not get cold, but freezer works
Do you know if the compressor in the back is running? If you can check that out get back to me and we can go from there. Most times if the fan in the freezer is running the defrost timer is ok.
Jul 09, 2007 | Amana ARSE66MB Side by Side Refrigerator
Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System Logo
42 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
