Question about Zyxel Prestige 660R Router (91004397002)
How to bridge Zyxel 660-R router to firewall fortigate 60
Hai vijay,
we have recently taken broadband connection from airtel. earlier we have leased line conection. we have connected through cisco router and fortigate60 firewall. now we need not to distrub the leased line connection.it was connected as wan1.now we need to connect this broadband ADSL2 router to firewall to wan2 port. how to do that? how to make bridge connection between firewall and ADSL2 router.? please help me.
SOURCE: zyxel p660hw and g202 problem
I had an almost identical problem and contacted Tech support at Zyxel. They were excellent and the guy talked me through to a solution. The main issue related to 'Bandwith management' which defaults to active on the router configuration. Unset all three (Wan, Lan, Wlan) and see if it sorts out problem. Because of some other issues I did have to reset the router to start with and on the wireless client I unset 'Obtain IP address automatically' and used an IP address with the default gateway set to the router address. If this does not help, I would recommend talking to Zyxel Tech Support, the consultant I spoke to was brilliant.
Posted on Jan 11, 2008
tpvijay
  • 34 Answers
SOURCE: Bridging of a Zyxel prestige 600 router
Here are the information to configure Zyxel as bridge
http://www.zyxel.com/web/support_knowledgebase_detail.php?KnowledgeBaseID=3104&pid=20040812093058
With Regards,
TPV
Posted on Jan 27, 2008
SOURCE: WAN 2 dissconnects
Try check with your subnets, if your subnet on your SBS is the same as your Xincom configuration and both your SBS and XIncom is acting as a DHCP server, it might cause a conflict.
Posted on Mar 07, 2008
SOURCE: Zyxel Modem Router P660hw wont work on LAN
If a LAN connected PC will not work while a wireless laptop is connected you need to go into advanced router setup, bandwidth management, and untick the three boxes labeled "active" to disable the band width management. Easy!
Posted on Apr 30, 2008
HAAi
  • 77 Answers
SOURCE: ZyXel P660HW-T1 ... Problem bridging 2 wirless adsl routers
What do you mean by "wireless bridging"? Does it mean wirelessly connecting both routers? (ex. Zyxel is at location A and Micronet ais at Location B and you'll wirelessly connect them). If this is what you mean, then it might not be possible since those are two different brands and possibility is that they will not work with each other when they're wirelessly connected unless one or both routers have the capability to do so.
Posted on May 09, 2008
I wanna open port for my DVR dvr is :- ip 192.168.1.88 cmd port 9201 video port 9202 and my router is fortigate60 i hope any one can give me full solution best regards
You will need the router login info, then using a browser go to:
https://192.168.1.99
That will bring you into the settings area of the router. Then do one of two things, find Port Forwarding, and forward the public 9201 & 9202 to the DVR at 192.168.1.88 port 9201 and 9202. Make sure to do this for both UDP and TCP.
Another and easier option, is to go to your DMZ setting. Just turn DMZ on and set it to 192.168.1.88.
Doing it with the DMZ will take care of any ports that need forwarding, they will point to the 88 machine (your DVR).
EJ
From the management computer browse to https://192.168.1.99. The FortiGate web-based manager appears.
From the management computer browse to https://192.168.1.99. The FortiGate web-based manager appears. From the management computer browse to https://192.168.1.99. The FortiGate web-based manager appears.
Jan 26, 2010 | Fortinet, Inc. FortiGate 60: FortiGate Pro...
Laptop does not detect wireless from Zyxel 660 router
Dear! You will have to enable wireless conection to access the router and internet. Check your adapter settings and enable wireless conection. Your problem will be solved.
Thanks
Jul 28, 2009 | Zyxel Prestige 660HW Wireless Router...
ZYXEL p-660 configuration for BSNL
in there you just give the dyanamic ip address automatically then you get it but you want to give it the go for the router mode in that you get it i just send a link you just download that think user giude then go througt it step by step ok
zyxel.com in that ftp server is there go througt it
May 05, 2009 | Zyxel Prestige 660R Router (P660R)
Have the same problem! My modem work fine, but the router (zyxel p-320w) can't connect to the internet, even though it said it finish the configuration.
In order for your router to work, you first need to set your modem to bridge mode. When you bridge your modem, it will serve as a "pass through" device.
Apr 25, 2009 | Zyxel Prestige 320W Wireless Firewall...
Zyxel modem and wrt54g modem
You need to put the zyxel p600 into bridged mode
Mar 26, 2009 | Linksys Wireless-G WRT54G Router
My zyxel 660 hw works fine for 10 minutes, then starts disconnect
If the same thing is happening with the USB WIFI on the PC. This sounds like a problem with your PC rather than your router. Is your antivirus / spyware scanner up to date? If not up date it and run a full system scan. Also you should check to see if your Firewall is up to date, and that the wireless network you are connecting to is included in the safe zone area of your firewall.
1 more thing if you are using a Thrid party firewall (i.e. Norton, Zone Alarm, McAfee, Etc.) Make sure Windows Firewall is deactivated (in Conntrol Panel) having 2 firewalls on can lead to random problems
Jan 17, 2009 | Zyxel Prestige 660HW Wireless Router...
Port forwarding
well to start, your connection would possibly be ADSL and your zyxel is set to provide DHCP address on your network, so its router capabilities could be turned on.
if this is true, you may need to rework the connection settings.
here's a recommendation:
1.set your modem to bridge mode (bridge only)
2.this will then be allowing your linksys to manage your DSL connection through PPPoE
3.after so, your linksys router should get a public IP address for an internet IP when you go to status tab (not an IP address starting with 192.168.1.xx)
after so, you may reconfigure your port-forwarding.
the reason why you will need to set your modem to "bridged" only is that if it is not, your zyxel's firewall is also turned on, provided that the linksys' firewall is always on. so even if you define which port will be opened on the router, it will still be blocked by the modem's firewall.
Jun 22, 2008 | Zyxel Prestige 660R Router (91004397002)
May 04, 2008 | Zyxel Prestige 660HW Wireless Router...
BEETEL 220BX ROUTER
First login to your Router using default username and password
2. Click on WAN on the left side menu
3. You'll have options to add or remove configurations.
4. Please select and remove the bridge config as BSNL does not support Bridge.
5. Please click edit on the existing PPPoE Airtel Configuration
6. Set the VPI=0 and VCI=35 (for Airtel it would be 1,32) and click next
7. Select PPP over Ethernet (PPPoE) and encapsulation type: LLC/Snap Bridging and click next
8. Enter the following details:
PPP Username: Your bsnl username (no need to add dataone.in)
PPP Password: Your bsnl password
PPPoE Service Name: DataOne
Authentication Method: Select CHAP
Click Next
9. Check the Enable IGMP Multicast Option
Check Enable WAN Service Option
Enter the Service Name as Dataone
10. Click Next and Save. You should also save and reboot your modem.
If doing the above does not works, check if you have anything set Under TR-069 Client and remove all entries in this section however it may not allow you to save so you may just put the ACS URL as ( it won't accept this field to be blank so just enter any thing, I entered http://bsnl). Save and reboot the router. Should be online now.
let me know if anyone benefited from the above information - abialexin@yahoo.com
Jan 14, 2008 | Computers & Internet
Zyxel Prestige 660R Router (91004397002) Logo
747 people viewed this question
Top Zyxel Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Zyxel Computer and Internet Expert? Answer questions, earn points and help others
