Question about SanDisk Sansa e260 MP3 Player
Bad Track All of a sudden, while playing a track, it just stopped and says "BAD TRACK" I can't turn it off, it's stuck. Any suggestions? Rebecca
    Problem Solver:
  • 18 Answers
Let the battery die so that it will power down. Next time you use it connect it to the computer and use the software to wipe/format the data on it and re-transfer the songs/videos. I would check the track that has the issue on the computer before transferring it again. If that doesn't work then it may be that your hard drive is corrupt on the player.
Posted on May 09, 2008
Kobelco 120 excavator sometimes one track will not drive.
Filter or pressure relief valve, or track feed valve. Otherwise you are in for a big bucks drive motor.
If it were the pump you would have bad everything.
May 11, 2015 | Cars & Trucks
95 Buick ParkAve Power Window Stops HalfWay
you have bad place in scew track replace it. Check to see if something has fell down in track line. roll window down use flashlite to check track.
Sep 10, 2017 | Buick Park Avenue Cars & Trucks
I have a Lionel ZW transformer older version 1955-1956, And lately my train loses power at one area of the track and then regains power again. This happens on both the outside and inside tracks.
This does not appear to be a problem with the ZW. The XFMR does not know anything about train location on the track. It appears to be a track connection problem on the center or outside tracks or both. One way to identify a bad connection is to take a parallel wire from the common and hot terminal of the ZW and connect directly to the area of track where the train stops and slows down. If this cures the problem then I recommend checking the tightness of the three track connections. For both FasTrack and Tubular, crimp slightly the pin receiving holes in the end of the track.
Note: For both tubular and Fasrtrack it is recommended that common track power for any one section be input to the track at more than one point. In this way one bad outter or center conductor won't cause the train to slow up or stop.
If FasTrack, you can solder directly to the tabs on the track underside for a permanent connection.
Aug 22, 2011 | Lionel Postwar Parts Zw-99 Transformer...
The CD will not advance to the next track. One track is played and then it stops and waits until I program it to play the next track.
try when u turn it on. check all your bottons 2 make sure they r not stuck and than put a cd n and check 2 c if it will read the hole disc. or push play with a cd in there an try 2 skip songs 2 play
May 10, 2011 | Audio Players & Recorders
Err format while recording - 1 hour lost!
I have almost the exact same problem.
I did not interrupt my recording. I stopped recording, turned off the recorder, unplugged all the mics, turned on the recorder, listened to the first 10 seconds of the recorded track, turned off the recorder, plugged it into my mac, turned it on in USB mode, attempted to transfer the track file, and the track size is "zero kb." I ejected the recorder, turned it off and back on, and now the track says "err format" and skips to the next track.
This seems like a unique problem, as any "data recovery" software will search for deleted files instead of corrupted files. And even if the file is corrupted I have software that can read the raw wav data. However, the filesize is incorrect and obviously doesn't contain any wav data. Shouldn't it be the actual file size? How can I fix this???
Sep 13, 2009 | Marantz PMD660
Bad Track reading
if you can still connect it to the computer
format it then put all the music in
this happen to mine exept that mine ccould still turn off
good luck
Oct 28, 2008 | SanDisk Sansa View 8GB MP3 Player - Black
Sharp CD-DP2400 3-disc mini component system stops playing in first track
the rails on the laser slead need cleaned..the grease gets hard/dirty and stops it from moving skip it to track 16 to move the dirt off the track..
Oct 26, 2008 | Audio Players & Recorders
BAD TRACK FOR EVERY SONG
The database has been corrupted, click HERE for how to properly format and reload firmware if need be...
Sep 30, 2008 | SanDisk Sansa e250 MP3 Player
Bad track
That means that somewhere in your music collection is a song with bad formatted ID3 tags. You can download an ID3 tag tool like MusicBrainz Picard to go through your songs and determine which tracks might be bad.
Aug 23, 2008 | SanDisk Sansa E280 MP3 Player
SanDisk Sansa e260 MP3 Player Logo
43 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
