Question about Frigidaire 20.3 Cu. Ft. Frost-Free Upright Freezer - White
0 degreesfrigidaire freezer ffu2064dw1 two days ago the freezer began to defrost.the tempture was at 15 degrees and was runing all the time i installed a minute value.the freezer began to get cold at between five and ten degrees below zero.set at #5 STAYS RUNNING..AT ZERO WHAT IS THE TEMPTURE WHEN IT TURNS OFF.CAN I RE INSTALL FOOD THANKS FOR YOUR HELP NIELS JENSEN THE FREEZER IS SIX YEARS OLD.
SOURCE: Freezer will Not Go Below 8 degrees and Alarm keeps sounding
Our manual says it can take our freezer up to 48 hours to get back to the correct temperature. I found that to be the case when we loaded it fully for the first time.
Posted on Jun 16, 2008
  • 161 Answers
SOURCE: UP RIGHT FRIGIDAIRE FREEZER AUTO DEFROST 11CF I THINK
This could be normal for the summer. This is the right temp to keep it at. Some units are meant to run 80 - 90 % of the time. Turn it all the way up and check the temp. Most units when working properly can get below 0. Check the condensor underneath for dirt and to see if the fan is running under there. (smaller units don't have anything underneath) Some have coils in the rear and the smallest units just use the sides of the cabinet to disperse the heat. Check the gasket see if its sealing properly or maybe the door is warped and not closing at the bottom.
Posted on Jun 30, 2008
  • 1314 Answers
SOURCE: My freezer's defrost systems runs constantly
i dont think so i would look at the compressor kicking out on thermal overload or a faulty thermostat thermostats have two settings cut in cut out your cut in could be bad and not turning the compressor on till the temp reaches melting temps now if your hearing a click buzz then you need to look at the compressor and make sure the compressor fan is running but its not a defrost promblem
Posted on Sep 11, 2008
tzweeb
  • 318 Answers
SOURCE: my freezer is not cold enough to keep food frozen...
the "e" usually means it has an error. it could be a bad temperature thermistor or a bad control board. the most likely is the board.
i hope you are less then 1 year old as the board can be quite pricey, about 150 bucks.
you could try to unplug the unit for a few minutes and then plug back in and see if the code goes away and returns to the cooling mode.
Posted on Dec 29, 2008
woodchuck789
  • 4066 Answers
SOURCE: New freezer not cooling - temp @ 25 degrees and food is defrosted
It is probably the control board and since it's new it's still under warranty so a certified Frigidaire repair man will fix it without charge. There should be a telephone number with the paperwork you received when you bought it.
Posted on Aug 29, 2009
It seems that the temp more often goes up to 20-30's and that food is not as frozen when I check it. When temp goes up I check it for next couple of minutes and usually within 10 min the temp is back down...
This is normal. All commercfial freezers must defrost 3 to 5 times a day, or they will freeze over at the coil and then stop freezing. A timer in your freezer turns off the compressor and turns a heating element on for 10 to 15 minutes. During that time the coil heats and melts frost from the coil. Usually within 30 minutes the temperature will briefly rise to 20 t0 25 degrees F and then quickly drop down to 0 degrees F. The food rarely defrosts in this short period of time..
Sep 01, 2010 | Turbo Air 23 cu. ft. / 651 liter...
Freeezer is only freezing around 26 degrees
Dirty condenser, condenser fan motor is not running, freezer overpacked, bad thermostat, evaporator ice build up and it blocks the air flow. evaporator fan motor is not running or sealed system problem.
Mar 14, 2010 | Freezers
Freezer defrost cycle
If the defrost timer sticks in the defrost mode,yes. Normal defrost time is 30 minutes or less depending upon which timer is installed.
If it happens again,locate the defrost timer and turn the dial manually to see if the compressor comes back on. If so,replace the timer.
It is probably on the rear near the compressor. Some are under the front behind the dust guard.
Feb 24, 2010 | Frigidaire 20 cu. ft. / 566 liter Upright...
Freezer temperature v
This sounds like your motherboard,computer or control board(they call it different things in different models) is bad. It is responsible for the fan speed and timing of the defrost cycle. To locate your timer, motherboard, control or adaptive defrost control , enter your model number and search for the part or post back on Fixya.
http://www.searspartsdirect.com/partsdirect/index.action?psid=26129238&sid=PSx20071217x00001a
Sep 20, 2009 | Freezers
Aug 29, 2009 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Errattic temperatures in Freezer
Check out "victory-refrig.com" for manuals, diagrams, etc.
Cap tube systems are "critical charge systems". Can be difficult to get right. You did not mention pressures that you had. The split on the evap vs.box temp is almost always 10 degrees for freezers. If you want a -10 box, your evap needs to be -20. As a general rule of thumb, you want the high side to be "ambient +30". This seems to work most every time. Your problem might be operations related. Them leaving the door open alot and so on. It could also be a problem with the evap fan or the control to it. It could also be that since there had been a problem with the unit, they are now constantly checking it. Could be checking during a defrost cycle. When your box is at 0 degrees, your pressure should be about a -10 and no less that a -15 degree for the evap. You may have to babysit this thing and see how far it will pull down. You may have a weak compressor. Also, I have had many Hobart freezers fail due to dirty condensers. This causes the oil in cap tube systems to gel and clog up the cap tubes. The only fix is replacing the cap tube. There are alot of variables here so be patient, it's not going to be a quick fix. One last thing, since R404A can fractionate, you really need to pull the charge out and weigh in the correct charge with virgin refrigerant. This will eliminate 2 things. 1, it will ensure the correct amount of refrigerant and, 2 no chance of having a poor mixture of refrigerant in the system causing inconsistant readings and performance.
Hope this helps. And remember, cap tube systems are performance measured by the amount of superheat just prior to the unit making temp and cutting off.
Jan 07, 2009 | Victory Commercial Freezer VSF-3
Freezer cycling on and off rapidly
If it still maintaining temperature but is short cycling your control for the temperature is wearing out causing the short cycling. This is a replaceable part that can be obtained through a dealer or appliance parts supplier. By lower setting do you mean lower number on the control, or lower temperature setting? Normally the higher the number the colder the temperature.
May 14, 2008 | Freezers
Frigidaire 20.3 Cu. Ft. Frost-Free Upright Freezer - White Logo
122 people viewed this question
Top Frigidaire Freezers Experts
Charles T Nevin
Charles T Nevin
AJMAL KHAN
Dan Webster
Dan Webster
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
