Question about HP ScanJet 7650 Flatbed Scanner
Feeder not catching on HP scanjet 7650
Hi, I had a paper jam, removed paper, and now the feeder will not catch and come down and feed. Can you advise me on what to do? thanks
  • sgwaddell Jun 30, 2008
    I took the roller assembly out & put it back in. Now paper won't catch. It looks like the mechanism that drops down on the gears on the right side is not connecting. Does anyone have a diagram of the inside of the ADF system?
  • Anonymous Mar 18, 2014
    PAPER DOES NOT PULL IN FEEDER
I had a similar problem where I had a jam, cleared it and it was not working again. It was a new machine within the store's warranty where I can return things no questions asked, so I returned it and got a new one. The new feeder won't catch at all and I never had any jams with the new unit - I put a stack of paper in to convert to PDF and it will do one at a time, or if it does do more than one, it misses stuff.
I never had a problem on the old machine until the jam. I don't know why the new one is not working.
Posted on Aug 05, 2008
Paper out
Could be caused by a few things. Recent paper jam could have caused this issue so should use a can of air for electronics and blow out the wheels and around the paper feeder that grabs and feeds the paper. If printer is small enough can turn it upside down and shake it out could have something dropped into paper feeder. Some HP printers have trap doors in bottom that catch things caught in printer. If it is none of these could be a bad sensor.
Feb 22, 2013 | Tally 6312 Matrix Printer
The belt inside my scanjet 4200c has come off. How do I reattach it? I have opened the scanner. It looks to be relatively easy but I don't know how to attach the belt to the motor etc
Instructions
1 Lift the hatch on the feed tray and pull up the large green tab to the left of the roller. Remove any jammed or torn paper from under the roller and around the feed tray.
2 Pull the input feed tray out of the automatic document feeder. Grasp the feed tray with both hands and pull it straight out.
3 Check the interior of the automatic document feeder for jammed paper. Remove any jammed paper, then reinsert the feed tray into the automatic document feeder. Push down the feeder cover until you hear a click.
Mar 08, 2011 | HP Scanjet 4200c Flatbed Scanner
Constant jams and paper tears in adf
Problem is in mechanical parts in ADF especially in rubber rollers so best solution is to change them. In this link below you can find (Hewlett-Packard Roller replacement kit for automatic document feeder (ADF) - C9937-68001).
http://www.impactcomputers.com/c9937-68001.html
Jan 06, 2011 | HP ScanJet 7650 Flatbed Scanner
My printer won't catch the paper to print. It make all the noise, but won't pull the paper through.
You can try the following. Remove all paper from the printer and turn printer off. Try opening the printer as if you were to remove the ink cartridges and check for any paper jammed in the printer. If there is a paper jammed try to remove it. if there is no paper jammed in the printer then try the following remove all paper from the feeder and flip the printer upside down and shake it a little. Sometimes things will fell inside of the paper feeder and will block the paper path thus causing the printer not to be able to pull the paper.
Feb 17, 2010 | Lexmark X2500 All-In-One Printer
DOCUMENT FEEDER IS JAMMING
Try and clean the rubber rollers with Isopropyl alcohol. Do not use any solvents.
S. Mohan, Chennai, India
Dec 30, 2008 | HP Scanjet 5590 Flatbed Scanner
Envelopes keep jamming
hello! try cleaning the paper feed roller where you feed the envelope in with denatured alcahol good luck
Dec 29, 2008 | Brother MFC-8460N All-In-One Printer
Hp scanjet 7650 document feeder is not working
did u buy cheaper paper that will do it tease the sensor in it sumties try to dl latest driver form hp.com ok remove old 1st
Oct 09, 2008 | HP ScanJet 7650 Flatbed Scanner
Hp scanjet 7650 urgent issue...
just reinstall scanner driver and software
Mar 20, 2008 | HP ScanJet 7650 Flatbed Scanner
ADF document feed
Hi, The problem seems to be a piece of debris , paper stuck in the ADF roller assy. You can check this by opening up the adf cover and inspecting the paper path. I have seen where a very small peice can cause paper path problems to where something is blocking the paper> Good Luck!
Dec 03, 2007 | HP 5590 ScanJet Flatbed Scanner
Document feeder works for printing but not for scanning
Hi, When you had the doucment feed jam were you able to clean or remove any paper that might be blocking the paper to be scanned? It sounds like there is paper still in the document feeder , I would open the DF and check very closely to make sure no paper is in the way!Good Luck!
Dec 02, 2007 | HP OfficeJet 7310 All-In-One InkJet...
HP ScanJet 7650 Flatbed Scanner Logo
549 people viewed this question
Ben Johnson
