Question about Konica Minolta Dimage Scan Elite 5400 II Film Scanner
Minolta 5400 II doesn't initialize - Hello, I have read thru various forums, but haven't found similar problem yet. My KM stops responding during initialization phase (Vuescan)/throws Error 4 in DimageScan SW. I've tried Ctrl Shift I as well but to no avail. It looks like something's wrong with door or with mechanism - when I insert tray holder into the scanner and then turn KM on, it removes tray out, but motor never stops and door keeps open. I can close door manually, but scanner won't initialize then. Have someone met such problem? What could this be related to? PS - I have opened scanner and looked for anything obvious like loose cable or contact, but I'm no expert in this and everything seems ok to me. thanks, mahdi
3 Suggested Answers
SOURCE: KM DiMage Scan Elite 5400 II
If the door to the scanner is actually closed, or the film holder is stuck on it you may have to press the door and film holder in slightly, then let the film holder out while holding the door in. If the door is not actually stuck on the film slider then you should be able to convince the scanner to push the film holder out by turning off the slider and turning it back on again without the software on.
Posted on Feb 24, 2008
samaddar07
  • 639 Answers
SOURCE: The Negative Holder is stuck
In this case what you can do is : 1) Uninstall the Scanner Driver Software from your PC 2) Check All the cables of the scanner are properly connected.Check both DC terminal and USB. 3) Restart the PC 4) Restart the Scanner (Switch Off and the switch On after 1 Minute) 5) Install the Scanner Software Driver in PC and check.
If the problem persists then you can open the Negetive holder but for that take the help of the following link i have given below. Click on the link and a pdf document will open in which you can find detailed description of the scanner and procedure to open the Negetive Holder.
http://download2.konicaminoltaeurope.com/OpenMind/Technic/Document/manlibph.nsf/CBA6A8A8B8722900C125711E00468228/$file/DSE5400-2_OM_E_.PDF
If you feel that my answers/advise have helped you getting solution to your problems then please Accept the solution.
Thanks.
Posted on Aug 02, 2011
Hello and help. a have a new(ish) computer running 7 and have borrowed a minolta dimage scan dual III. i was able to install the software with the converter program, but it won't recognize the scanner....
; sonyscanners.inf -- Sony (Konica Minolta) Film Drivers
; Beta driver for Windows Vista and Windows 7 operating
; systems for all known Sony film scanners.
[Version]
Signature="$CHICAGO$"
Class=Image
ClassGUID={6bdd1fc6-810f-11d0-bec7-08002be2092f}
Provider=%Provider%
DriverVer=2/19/2011,3.0
[Manufacturer]
%Mfg%=Models,ntamd64
[Models]
; USB and SCSI scanners
"Minolta Scan Dual II" = USBScanner,USB\Vid_0638&Pid_026a
"Minolta Scan Dual III" = USBScanner,USB\Vid_0686&Pid_400d
"Minolta Scan Dual IV" = USBScanner,USB\Vid_132b&Pid_000a
"Minolta Scan Elite 5400 2" = USBScanner,USB\Vid_132b&Pid_0012
"Minolta Scan Elite 5400" = USBScanner,USB\Vid_0686&Pid_400e
"Minolta Scan Elite II" = USBScanner,USB\Vid_0686&Pid_4004
"Minolta SC-110" = USBScanner,USB\Vid_0638&Pid_0a15
"Minolta SC-215" = USBScanner,USB\Vid_0638&Pid_0a16
"Minolta QuickScan 35" = SCSIScanner,SCSI\ScannerMINOLTA_#2880___________
"Minolta Scan Dual" = SCSIScanner,SCSI\ScannerMINOLTA_#2882___________
"Minolta Scan Multi" = SCSIScanner,SCSI\ScannerMINOLTA_#2883___________
"Minolta Scan Speed" = SCSIScanner,SCSI\ScannerMINOLTA_#2884___________
"Minolta Scan Elite" = SCSIScanner,SCSI\ScannerMINOLTA_#2885___________
"Minolta Scan Elite 5400 Firewire" = SBP2Scanner,SBP2\MINOLTA&DS_Elite5400&CmdSetId104d8
[Models.ntamd64]
[USBScanner]
Include=sti.inf
Needs=STI.USBSection
SubClass=StillImage
DeviceType=1
DeviceSubType=1
Capabilities=0
[USBScanner.Services]
Include=sti.inf
Needs=STI.USBSection.Services
[SCSIScanner]
Include=sti.inf
Needs=STI.SCSISection
SubClass=StillImage
DeviceType=1
DeviceSubType=1
Capabilities=0
[SCSIScanner.Services]
Include=sti.inf
Needs=STI.SCSISection.Services
[SBP2Scanner]
Include=sti.inf
Needs=STI.SBP2Section
SubClass=StillImage
DeviceType=1
DeviceSubType=2
Capabilities=0
[SBP2Scanner.Services]
Include=sti.inf
Needs=STI.SBP2Section.Services
[Strings]
Provider="Sony (Konica Minolta)"
Mfg="Sony (Konica Minolta)"
Apr 04, 2011 | Konica Minolta Dimage Scan Dual IV Film...
The slide holder will not return after scanning. The little wheel that is supposed to move the slide holder just clicks but doesn't move the slide holder. I have to remove it by hand. By the way, this...
I have the 5400 II and have had similar problem. I found out, that it is essential, that the film/slide holder is clean and have a smooth surface. Specially on the edge where it touches the plain bearings. I have lubricated the whole holder with acid-free silicone, wich over time made the scanner work perfectly.
Brgds Per
Jan 01, 2011 | Konica Minolta Dimage Scan Elite 5400 II...
Minolta Elete Scanner 5400 - Is there a Driver for Widows 7 available
[Version]
Class=Image
Provider=%Provider%
[Manufacturer]
[Models]
[Models.ntamd64]
[USBScanner]
Include=sti.inf
SubClass=StillImage
DeviceType=1
DeviceSubType=1
Capabilities=0
Include=sti.inf
[SCSIScanner]
Include=sti.inf
SubClass=StillImage
DeviceType=1
DeviceSubType=1
Capabilities=0
Include=sti.inf
[SBP2Scanner]
Include=sti.inf
SubClass=StillImage
DeviceType=1
DeviceSubType=2
Capabilities=0
Include=sti.inf
[Strings]
Nov 03, 2010 | Minolta Dimage Scan Elite 5400 Film...
Will this scanner work on Vista or must I use in on a computer that has XP? How do I get it to work with Vista? Would it be easier if I got Windows 7?
You have to replace the original Konica Minolta driver with the custom one I have created below. Here are the detailed steps.
1) Install the Konica Minolta XP software in Vista/Win7.
2) Plug in your DImage Scanner into a USB port and turn it on with the door closed. It will detect and install the original Konica Minolta Driver.
3) Create an empty folder on you harddrive (for instance go to my computer, double click on the c: drive, then right click and create a new folder named newminolta).
4) Open windows notepad and copy the following into it:
[Version]
Class=Image
Provider=%Provider%
[Manufacturer]
[Models]
"Minolta Scan Dual II" = USBScanner,USBVid_0638&Pid_026a
"Minolta Scan Dual III" = USBScanner,USBVid_0686&Pid_400d
"Minolta Scan Dual IV" = USBScanner,USBVid_132b&Pid_000a
"Minolta Scan Elite 5400 2" = USBScanner,USBVid_132b&Pid_0012
"Minolta Scan Elite 5400" = USBScanner,USBVid_0686&Pid_400e
"Minolta Scan Elite II" = USBScanner,USBVid_0686&Pid_4004
"Minolta SC-110" = USBScanner,USBVid_0638&Pid_0a15
"Minolta SC-215" = USBScanner,USBVid_0638&Pid_0a16
"Minolta QuickScan 35" = SCSIScanner,SCSIScannerMINOLTA_#2880___________
"Minolta Scan Dual" = SCSIScanner,SCSIScannerMINOLTA_#2882___________
"Minolta Scan Multi" = SCSIScanner,SCSIScannerMINOLTA_#2883___________
"Minolta Scan Speed" = SCSIScanner,SCSIScannerMINOLTA_#2884___________
"Minolta Scan Elite" = SCSIScanner,SCSIScannerMINOLTA_#2885___________
"Minolta Scan Elite 5400 Firewire" = SBP2Scanner,SBP2MINOLTA&DS_Elite5400&CmdSetId104d8
[Models.ntamd64]
[USBScanner]
Include=sti.inf
SubClass=StillImage
DeviceType=1
DeviceSubType=1
Capabilities=0
Include=sti.inf
[SCSIScanner]
Include=sti.inf
SubClass=StillImage
DeviceType=1
DeviceSubType=1
Capabilities=0
Include=sti.inf
[SBP2Scanner]
Include=sti.inf
SubClass=StillImage
DeviceType=1
DeviceSubType=2
Capabilities=0
Include=sti.inf
[Strings]
5. Now save you new notepad file in the directory you created as sonyscanners.inf NOT as sonyscanners.inf.txt or sonyscanners.txt (i.e. c: ewminoltasonyscanners.inf)
6. Go to system control panel (may have to change control panel to classic view to see system).
7. Select Device Manager
8. Select Imaging Devices
9. Right click on Minolta XXXX (depending on model) and click on driver tab. Select Update Driver.
10. Select Browse my computer for driver software.
11. Select Let me pick from a list of device drivers on my computer.
12. Select Have Disk
13. Browse to c: ewminoltasonyscanners.inf and click OK
14. Click Next. Windows should now say it updated driver.
15. Run Dimage software with door closed. Wait for it to initialize and green light stops blinking.
16. Open door and insert film holder and start scanning.
17. If you are trying to use a Minolta 5400 with firewire in Windows 7, you have to change your 1394 driver to the legacy windows 1394 driver in order for the scanner to detect. Google for instructions as it's too detailed to add in here.
18. The above driver should relink virtually all known Minolta scanners (USB/SCSI/Firewire) to the Windows TWAIN driver so it will work with the legacy Minolta software.
Sep 20, 2010 | Minolta Dimage Scan Elite 5400 Film...
Looking for driver for Minolta Scan Elite 5400 (not II) in wndows7
[Version]
Class=Image
Provider=%Provider%
[Manufacturer]
[Models]
[Models.ntamd64]
[USBScanner]
Include=sti.inf
SubClass=StillImage
DeviceType=1
DeviceSubType=1
Capabilities=0
Include=sti.inf
[SCSIScanner]
Include=sti.inf
SubClass=StillImage
DeviceType=1
DeviceSubType=1
Capabilities=0
Include=sti.inf
[SBP2Scanner]
Include=sti.inf
SubClass=StillImage
DeviceType=1
DeviceSubType=2
Capabilities=0
Include=sti.inf
[Strings]
5. Now save you new notepad file in the directory you created as sonyscanners.inf NOT as sonyscanners.inf.txt or sonyscanners.txt (i.e. c:\newminolta\sonyscanners.inf)
13. Browse to c:\newminolta\sonyscanners.inf and click OK
Aug 14, 2010 | Minolta Dimage Scan Elite 5400 Film...
Need drivers for Minolta Dimage Scan Dual III to work with Windows 7 64-bits
I used this solution from KainAnderson
1) Install the Konica Minolta XP software in Win 7.
2) Plug in your DImage Scanner into a USB port and turn it on with the door closed. It may detect and install the original Konica Minolta Driver.
; scanners.inf -- Test Vista Minolta Film Drivers
; To remove this driver and install the original
; manufacturer's driver, go into Device Manager,
; open Imaging devices, then click on the scanner name
; with the right mouse button and choose Uninstall.
[Version]
Class=Image
Provider=%Provider%
DriverVer=3/12/2009,2.0
[Manufacturer]
[Models]
; USB scanners
;---------------- Duplicated from [Models]
[Models.ntamd64]
; USB scanners
;---------------- USBScanner -------------------------
[USBScanner]
Include=sti.inf
SubClass=StillImage
DeviceType=1
DeviceSubType=1
Capabilities=0
Include=sti.inf
[Strings]
Provider="Konica Minolta"
Mfg="Konica Minolta"
5. Now save you new notepad file in the directory you created as newminolta.inf NOT as newminolta.inf.txt or newminolta.txt (i.e. c:\newminolta\newminolta.inf)
6. Go to control panel (View Devices and Printers).
7. Right click on Minolta Scan Dual III and click on properties.8. Select Hardware tab, then select Properties
9. Select Driver tab, then select update driver
11. Browse to c:\newminolta\newminolta.inf (or wherever you stored file) and click Next
12. Click Next. After running driver file Win 7 should now say it updated driver.
13. Run Dimage software with door closed. Wait for it to initialize and green light stops blinking.
14 Open door and insert film holder and start scanning.
Hopefully I've copied and amended the solution correctly
Feb 10, 2010 | Minolta Dimage Scan Dual III Film Scanner
Need km 5400 scan elete driver for my windows vista computer
Bill,
I use VueScan from Hamrick Software (http://www.hamrick.com/) with excellent results. The learning curve is steep but it's so far the only solution, baring a dual boot machine with an XP option.
Nov 18, 2008 | Konica Minolta Dimage Scan Elite 5400 II...
DS_Dual4easy software for VISTA operating system?
1) Install the Konica Minolta XP software in Vista/Windows 7.
[Version]
Class=Image
Provider=%Provider%
[Manufacturer]
[Models]
; USB scanners
[Models.ntamd64]
; USB scanners
[USBScanner]
Include=sti.inf
SubClass=StillImage
DeviceType=1
DeviceSubType=1
Capabilities=0
Include=sti.inf
[Strings]
5. Now save you new notepad file in the directory you created as newminolta.inf NOT as newminolta.inf.txt or newminolta.txt (i.e. c: newminolta newminolta.inf)
9. Right click on Minolta Scan Dual IV and click on driver tab. Select Update Driver.
13. Browse to c: newminolta newminolta.inf and click OK
14. Click Next. Vista should now say it updated driver.
Feb 10, 2008 | Konica Minolta Dimage Scan Dual IV Film...
MINOLTA SCANNER DiMAGE SCAN ELITE 5400 II
My 5400 2 scanner worked well with windows XP but will not start with my new computer WINDOWS VISTA.
ERROR message Can not find scanner, check connection
ERROR message 1 unknown error
The scanner was purchased new 1-2006
my installation dick is for Win. XP Version 1.0.1.
Dec 25, 2007 | Konica Minolta Dimage Scan Elite 5400 II...
Konica Minolta Dimage Scan Elite 5400 II Film Scanner Logo
105 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
