Question about Westinghouse 22" Widescreen LCD Flat Panel Monitor
Bought 2 monitors at the same time, one just simply wont turn on anymore, where should i take it to be repaired/looked at? Maybe the main bulb burnt out?
    Brigadier General:
  • 10,406 Answers
> where should I take it
Back to where you bought it, to get their recommendation for a TV/video repair shop in your area.
Or, if it still has a valid WARRANTY, then EXERCISE the warranty, to get it repaired/replaced.
Posted on Aug 31, 2010
My hp w1907 monitor wont stay on
The issue if your light bulb behind the LCD matrix is burnt out you need to replace them. This is common for these monitors. The bulbs simply snap off an on by a connector to the high voltage power supply. When you open the monitor up, you will see he board with HV supply on it Trace the two (red an white) wires to the backlight (bulbs) and verify by looking at their ends looking for black discolor at he ends of the bulb (This means the interior of the bulb is carbonizing = shorting out). Most times the monitor will shut down into orange light, but sometimes it will not ignite the fluorescent bulb)(s).
Apr 23, 2014 | HP w1907 LCD Monitor
Yellow Spot on Dell IN2020M monitor due to heavy exposure of 100w bulb how to remove that?
No you cannot replace an individual LED, it's simply too hard for yourself to do it. The led is a sheet of led diodes and to replace one is very difficult, requiring lots of soldering etc. You should get it to a repair shop where they have spare exchangeable panels which is easier to replace. Also the yellowish colour is probably due to the pixel itself being burnt, not the LED light.
Nov 07, 2012 | Computers & Internet
Model number ffhs2313lp3 light burnt out got a new one wont work
if you new light still didn't work . so what's the problem ? maybe the light was in good condition . did you check you circuit board ?
home light bulbs
May 31, 2012 | Frigidaire Refrigerators
I have a 96 Pontiac Grand Prix..., & The Left Turn signal isn't working... in the front or the back.., also sometimes it blinks slowly or doesn't blink at all on the right side, I already...
More than likely it's not all the bulbs that are burnt out. Your head lights work like a relay if one bulb is bad then none of them work. Try looking for the bad bulb (this will require you to pull the head light assembly a part to look at the bulbs) what you are looking for is blackening around the clear part of the bulb, also if you pull the bulb out of the socket and give it a bit of a shake does it make a rattling sound? If so then it's bad.
In regards to your left turn signal have you replaced the bulbs or check to see if they are burnt out as well? The also operate as a relay and will not work if one is burnt out.
You may be right about it being a switch. If you have the time, take the door panel off which can sometimes be a pain, **** worth it. Check to make sure the wires are still connected properly. If they are then i would look in and around the window tract to see if there is anything that could be impeding the window from going down. Other wise it could be a bad button system and just the drivers side button is shot. You may have to replace that. Hope this helps. Good luck.
Aug 31, 2011 | 1996 Pontiac Grand Prix
How can I get the screen to light back up. I'm forced to use a flashlight to see anything
You may have to replace the screen if you can see things on the screen but have to use a flashlight this would be something I would change out. If you want to go deeper into it plug the monitor into another working computer and see if it works fine if that is the case then you are dealing with a video card issue. Replace the video card and go from there it should work fine from that fix. Thanks for using FixYa! do not forget to vote for me. John
Mar 12, 2011 | E-Machines eMachines Monitor E15T4
Have a 2003 Chevrolet silverado, right rear tail light does not burn when lights are on, this light will burn when brake is applied or when turn signal is used. What is the problem and how can it be fixed?
There are 2 filiments in the light bulb. One is for running lights and the other is for brake and turn signal lights. Simply replace the bulb and you should be ok.
Jan 30, 2011 | 2003 Chevrolet Silverado 1500
My amp stopped working after 2 days from the day bought it. It stayed on standby for a while, about ten to fifteen minutes, but once I switched it on it started humming and making crack and pop noises.I...
Take it back for warranty replacement or repair since you only had it for 2 days. Since there is burnt smell this could be very serious problem. Probably a fuse blew due to any of several problems.
The pilot light runs off a rectified output of the power transformer but it is fused. There are three sopplies from the transformer and any of those could have a short and blow the main fuse or their individual fuses.
Take it in as I stated as this is NOT DIY repair. There are high voltages in this unit and if one is not adept at electronics you probably would not be able to repair it anyway.
Nov 29, 2010 | Peavey ValveKing VK112 50W Combo Amplifier
Im getting a black screen?
take a flashlight and look closely at it. Quite often the Backlight transformer burns out. then the light wont come on. if this is your problem, you will be able to see your windows screens very faintly by using a flashlight. just a thought. cheers
Aug 25, 2010 | Acer Computers & Internet
My dash light doesnt come on anymore, how do i fix
They probably took the bulb out or it is burnt out. I would check the bulb. The dash light is supposed to light every time the car is started. It is called a bulb check.
Apr 08, 2010 | 2000 Oldsmobile Alero
Monitor won't turn on
If there is no power indicator to the monitor, then maybe please verify the inside fuse, maybe got busted. else consult the nearest repair center.
melnavz
Dec 15, 2008 | Computers & Internet
Westinghouse 22" Widescreen LCD Flat Panel Monitor Logo
24 people viewed this question
Top Westinghouse Computers & Internet Experts
Jim Goldsmith
Jim Goldsmith
Alun Cox
Are you a Westinghouse Computer and Internet Expert? Answer questions, earn points and help others
