Question about Acer eMachines 520-2890 Notebook
I see that i have no mic in this computer, so the only way for me to talk is to get an external mic
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 88 Answers
Yes
Posted on Aug 31, 2010
Cobra highgear hg75m mic squeals
get it away from the ext . speaker. They are cheap enough ,buy another one and see if it still squeals. If it does then you may have to jump the mic with resistors ,turn down your mic gain, check for talk back on rear where your pa. and external speaker hooks to inside the radio. If you see a resister connecting them then you have talk back . Mainly its a Keep the mic away from the speaker deal that makes them squeal. Try other cobra mics with the same pin out and see if it still happens . easy fix just have to be patient .
Feb 06, 2014 | Cobra 29 LTD CB Radio
How do I connect an external microphone to my Toshiba Salellite Laptop computer?
Right click over speaker icon (next to your clock right bottom corner), click recording devices. Clic on your external mic, clic on properties, at bottom on the new window select "use this device (enable)"
Aug 20, 2012 | Toshiba (P000257700) Microphone
Sony vaio vgn-NR120E has no mic specially when u r on skype i can hear the caller but my voice is not heard by him...tell me the solutionWhat's your problem?
You're on a laptop and it's talking about a sound card?
If you can hear audio or the voice from the caller then you don't need a sound card.
Yes you can purchase an external mic and it just plugs into the mic port on your system. I think that might be why the caller can't hear you. All computers do not come with a built in microphone. And if you are skyping and using a web cam, all web cams don't have a built in microphone.
Mar 26, 2012 | Sony VAIO VGN-NR120E/S Notebook
An external microphone will not cut out the background noises, no matter what settings we change...the built in mic is disabled, but the noise in the background is very loud unless we are talking, and evn...
Most microphones (especially those made for use in a computer) do not remove any background noise. This is usually done via software, but it might not be available on every app out there.
If you can't talk properly using your current mic, your best option might be getting a headset. Headsets have a less sensitive microphone, which will tend to pick up only your voice. If you have a bluetooth headset, you can use it on your computer by adding a bluetooth dongle.
Mar 22, 2011 | Computers & Internet
How do i switch off the internal mike?
When you connect the external mic to the laptop,automatically the internal mic will be disabled. If you are talking about just disabling, you can mute that through sound properties on the right side bottom.
May 20, 2010 | Advent Netbook
Squeals when keyed up. Detecting talk back.
ITS JUST NOT THE TURNER MIC IT HAPPENS WITH ALL BASE MICS HAVE HAD THE SAME PROBLEM WITH MY 2995DX WITH A ASTATIC D-104 & 1104-C AND ALSO ANY TURNER I HAVE USED BUT I CAN RUN A ASTATIC MOBILE D-104M6B OR RED DEVIL AND NO SQUEAL HAVE YOU TRIED GROUNDING THE CASE OF THE RADIO IT IS RF FEED BACK SQUEAL SO MY SUGGESTION TO YOU IS TO RUN A 48 COPPER GROUND ROD INTO THE GROUND AND RUN A NICE GROUND WIRE TO THE BACK OR THE CHASIS OF THE RADIO AND IF YOU ARE USING ANY EXTERNAL AMPLIFIERS ALSO GROUND THEM AND YOUR SQUEAL WILL BE ILLMINATED
Jan 17, 2009 | Ranger RCI-2995DX Base Scanner
External mic problem for acer aspire 5920
reboot the sound card trough the device manager.
Nov 11, 2008 | Acer Aspire 5600 Series 5630-6951 Laptop
Mic problem?
You will need an external MIC, this system has no built-in Microphone
May 13, 2008 | Dell Inspiron B130 Notebook
Push to talk problem
If indeed radio #1 has a mic problem, this may be confirmed by trying an external speaker/microphone plugged into the accessory jack. If still a no, then its not the mic but possibly the modulator circuitry. If there is transmit audio with the external mic and hence internal mic is defective, the unit would have to be pried open and the defective component replaced. The internal mic is normally an electrofet 2-3 terminal soldered to a shielded wire and physically attached to the front plate.
Alternately, another possibility is that radio #2 has its Interference Eliminator Code enabled/activated. This is indicated by the presence of small sized digits on the top right of display. If this is the case and no similar digits are displayed in radio #1, then radio #2 will not allow any received transmission to be heard. Along the same line of reasoning, if the code is activated on both radios signified by the presence of the 2 small digits, and radio #1 has a problem with its CTCSS (code) generator, then it would also prevent reception of radio #2. A way to verify this is by deactivating/disabling the Interference Eliminator Codes on both radios.
On certain occasion, it is also possible that radio #2 has a defective speaker. You should be able to verify this by plugging in an external speaker to the accessory jack of radio #2.
Hope this be of some help/idea. Pls post back how things turned out or should you need additional information.
Good luck and kind regards.
Nov 09, 2007 | Motorola Talkabout FRS 250 (14 Channels)...
Acer eMachines 520-2890 Notebook Logo
15 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
