Question about GE Profile 26.6 cu. ft. Side-by-Side Refrigerator with Dispenser TFX27PRBWW
Hello I own a profile refrig. and the ice maker stop working three days ago. Since then food is not getting cold on the freezer side and refrig. side. Could it be a thermostat?
  • GE Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Posted on Sep 01, 2010
Fridge warm, freezer has frost on back panel & is defrosting, fans work, just changed defrost thermostat, no air is moving from freezer side to fridge side, drain pan under fridge is dry
this fan needs to run when the compressor runs,check fan blade for being jammed by ice if you have this much ice on back wall as ice will stall motor,if no fan there will be no cool air to refrige compartment also the defrost drain tray will fill with water then freeze over which in turn floods the freezer floor and refrige compartments cause it cannot drain to the pan in the bottom
May 11, 2012 | Kenmore Side by Side Refrigerator
I have a GE Profile side-by-side Refrig (model PSW26PSSB SS). The freezer does not stay cold. Often my food thaws. I?ve placed a cup of water in the freezer over night and it does not freeze. My ice maker...
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Refrigerator2_bing.gif Condenser Coil Cleaning Refrigerator2_bing.gif Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting2_bing.gif Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Jul 12, 2010 | GE Profile PSW26P Stainless Steel Side by...
I have a Jenn-Air side by side frig. The freezer side cools too cold, the frig side not enough. 2 weeks ago I took all the food out of freezer and noticed ice build up on back. I unplugged unit, let it...
If the freezer is staying cold it sounds like a defrost system problem. A bad timer, heater or thermostat can cause frost to build up on the coils and block air flow to the refrig side. Check out ACMEHowTo.com for troubleshooting the defroster problem.
There is a small duct between the freezer and refrigerator side if this is blocked the frig side won't cool.
Jan 09, 2010 | Jenn-Air JCD2389G Side by Side...
Freezer works, but fridge doesn't
try checking the fan in the freezer at the top which pushes the coldness over to the freezer
Jul 08, 2009 | GE Profile 21.7 cu. ft. Bottom Freezer...
Freezer not cooling/making ice.
At this moment I think that you need to unplug the refrigerator and remove the ice maker to stop the leaking. Any extra water inside the freezer will make it harder for the defrost to remove the moisture. While the ice maker is out I want you to look to see if water is still leaking out the fill tube that feeds the ice maker tray. If it is then we found the reason. If not then we need to check some of the parts on the ice maker. Let me know what you find, Thanks, Sea Breeze
May 20, 2009 | GE PSS26PSS Stainless Steel Side by Side...
Frost inside and ice on floor of freezer
The water can only come from 2 places, the drain is blocked or the ice maker is over filling.The temps are too good to have any other things going wrong. Let me know, Thanks, Sea Breeze
May 18, 2009 | GE Refrigerators
Fresh Food Compartment not cold enough
check freezer for frost build up and if fan blowing, check condenser make sure clean, and fan blowing, check vents in refrig. make sure no blockage, freezer control should be in the middle setting, you can try turning that to Warmer freezer allowing MORE air to refrigertor side.
Sep 08, 2007 | GE Profile PSS26NGS Side by Side...
Freezer works but refridgerator warm
you could find ice behind the back panel - worth a check. however the problem is probably ice in the return vent from fridge to freezer and the only way to cure is to switch off and leave for a day with doors open. if im right and you try this, if it re-occurs you may have a problem with the defrost system
Apr 06, 2007 | Kenmore 50522 / 50524 Side by Side...
Refrigerator, s/side, too cold, etc
unplug and let defrost. You should also clean the grills off in back and get all cob webs off from underneith. that might help
Apr 24, 2007 | Admiral 26 cu. ft. Side-By-Side...
Refrigerators Logo
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Gene Tuck
