Question about Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System
Where does the water line hookup? - Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System
    President:
  • 670 Answers
The water inlet valve is on the back side near the bottom of the refrig.
Posted on Aug 31, 2010
I have hot water in all valves in rv but NO cold water
There is most likely a valve between each hot and cold water hookup that have been left open for winterization. You have to close the valves between the hot and cold water lines.
Feb 27, 2017 | Water Water Heaters
Which side is the flush value for the gray water on ,Right or Left"???
If you're talking about the drain valves, most RVs have them on the left side of the RV in the same compartment with the water and electric hookups. There should be 2 lines, one that is almost twice the diameter of the other. The larger line is for black water and the smaller one is gray water. You should always drain the black water tank first so that when you drain the gray water it flushes the really nasty stuff from your drain hose.
Apr 17, 2015 | Fleetwood 2008 Terra LX 31M
Help hooking the water line up to a RCA NO-FROST MSX22GR21.7 cu. ft. Refridgerator -Freezer
you must have water connection behind refrigerator. If you have water connection at wall, water hookups to refrigerators are 1/4 ,you can use copper w compression fittings to hookup. If not familiar with, might need to call plumber or ref tech
Apr 01, 2015 | Refrigerators
Water Supply ConfusionFRS26ZRFW1
you never mentioned you use teflon tape for tighter fit.
Feb 05, 2014 | Refrigerators
How do you increase the water pressure on the despenser in the door? this is a wirlpool side by side with a filter.
If the filter is more than 6 months old it needs to be changed.It could be stopped up.
The overall water pressure is controlled by the pressure from the incoming water supply line. If you have good pressure at other faucets you may have a restriction in the water line hookup or the water valve where your supply line connects on the rear of the refrigerator.
Jan 24, 2010 | Whirlpool ED5VHGXM Side by Side...
Never hooked up one green line running bottom to top with plastic nuts . one valve at bottom looks like a tire valve stem. is this the inlet water line hookup
Do not hook water to the "tire valve stem"! That is probably a freon access valve. Hooking water to that will ruin the refrigeration system.
Oct 31, 2009 | Freezers
Water Supply
The ice maker hookups are typically located at the bottom of the reverse side of the ref.
You'll want to have enough slack in your supply line so you can roll the machine forward to clean, and service the machine while still leaving the water supply attached. So if you leave enough extra tubing on your supply line, you'll be ready for where ever it's located on the unit.
If you don't have water to the ref's location, you can purchase a complete icemaker hookup kit with a saddle self-tapping valve, copper or plastic supply line and the necessary fittings. This is typically tapped in to the cold water supply under the sink or on a cold water supply line under the house. If you run it thru cabinets or flooring, I recommend using the copper supply line.
K
Jun 15, 2009 | Maytag MSD2454G Side by Side Refrigerator
Difference in waterline hookup between old and new icemakers
this is so often the case with some of the larger companeys. there are only two types of connections for these water lines. 1st is a compression fitting 1/4 inch 2nd is a push lock style also 1/4 inch. Both styles can be purchased at any large hardware store. they should be with pipe supplies. Hope this helps and good luck.
May 07, 2009 | Kenmore 18.3 cu. ft. Top Freezer...
Water hookup lines
you can buy a copper instalation kit from lowes which i reccomend as mice can chew through the plastic and the plastic lines are safe but no one gets out of this world alive global warming scares me more
Jul 10, 2008 | Kenmore 18.3 cu. ft. Top Freezer...
Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System Logo
47 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
