Kenmore 41748102701 Front Load Washer that keeps shutting off during the wash cycle. hwere would i find a drain filter that i suspect is the reason it keeps shutting off?
  • michelle neuber Aug 31, 2010
    ok .. this might seem naive but am i taking off the rear access panel to do this or am i somewhow getting to things fron the front. please give me a little more detailes
  • Washing Mach... Master
  • 17,130 Answers
Look from the begining check water flowing into the drum when the program starts. If flow is less into the drum check inlet valve clean if clogged.make sure thepower plugs are tight and all connections to the control board ,motor,water lever sensor.now check on the drainhose to which is fitted the drain pump. Remove and check for dirt in the inlet side of the pump were the filter is fitted.Make sure there is no dirt from the drum to the drain hose.Now fix back and start the program.if you notice aprogram shut down during wash cycle check if the water level pressure sensor is faulty.if not,there can be loose connection in the program controller or a possible fault in it.
Repeat the wash process and test at the time of shutting down.
The voltage check of the motor must be taken to confirm if the motor drive is stopped. If so even a malfunction in the motor drive is possible
Posted on Aug 31, 2010
  • Donald DCruz
    Donald DCruz Aug 31, 2010
    You will need to look from the bottom So if you can raise up the washer there is access as to test you cannot lay it sideways.
    So use a spacer and jack up and look from the bottom., we need to see the real problem from our inferences.
I have a Kenmore HE 2plus front load washer and during any wash cycle the drum won't spin and at end of cycle displays F01
Front-loading washer Kenmore HE2 plus - spinning not ...
www.shopyourway.com > Manage My Life > Questions
My Kenmore HE2 plus washer has problems with spin funciton. almost all of the ... or twins size blanket, it just won't spin, even with extra spin cycle only. ... Check to see if the washer will spin without any clothes at all in the basket. ... My HE2 will wash a very small load. ... Any bigger loads The drum will try and turn but wont.
Front Load Washer Won't Drain or Spin Video: Washing ...
? 1:54
https://www.youtube.com/watch?v=wlMoT9rgvAg
Jun 1, 2012 - Uploaded by searspartsdirect
... won't drain or spin. For more front load washing machineinformation and repai. ... If the cycle has completed and water is still left in the machine select "Drain and Spin" to remove anywater remaining in the washer. This can be caused .... I have aKenmore HE2 plus front load washer. I can't seem to get it ...
Kenmore HE2 Plus 3.6 cu. ft. Front-Load Super Capacity ...
www.kenmore.com > Laundry > Washers > Front-load Washers
KenmoreFront-Load Super Capacity Washing Machine (4753) .... super wet, and to spin the empty drum after each load to hear if anything was caught in that gap. .... 1st of all: You cannot use any other detergent than HE rated detergent - PERIOD. ... will create too many suds and clog up the machine, and the clothes won't be clean.
Jan 15, 2016 | Kenmore Washing Machines
Kenmore he2 plus stops during wash cycle
What is the maximum capacity (laundry weight load) of your washer? And how much weight do you consider a large load, that you are placing in the washer?
Dec 31, 2013 | Kenmore HE2 Plus Front Load Washer
My kenmore 3.5 front load does not drain during the final rinse and spin cycle. It does clear all of the soap and water during wash.
Check for foreign objects in drain pump or if not defective pump. Accessible from bottom front panel, two screws holding it in place
Jun 05, 2011 | Kenmore 44102 Front Load Washer
I have a Kenmore 80 series top load washer. It will not drain during spin cycle. If I run it through a second spin cycle it will usually drain. Any ideas
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Sep 18, 2010 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Washer keeps saying SUD checked my detergent... it's HE safe?? have even tried no detergent at all but washer keeps saying sud
Remove the bottom front panel. Clean out the drain filter located in the front center.
Replace the drain filter.Run a cycle with all COLD water.
Apr 18, 2010 | Kenmore 43142 Front Load Washer
I have Kenmore front load washer(don't have the model # yet)...during the normal wash cycle..at the end of it it does not spin, the diplay show E20. What seems like the problem??
2 Beeps/E20--Error: Water dosen't drain. Cause: Drain is kinked or household clog. Correct.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jan 25, 2010 | Kenmore Elite 45986 Front Load Washer
*&^% screws!!!
F2 = Long Drain. Most common cause is something (or lots of things) stuck in the drain pump. There are screws at the bottom of the front panel that can be removed to check it out. If the screws look like stars they are Torx head screws, get driver from most home centers.
Go here for Kenmore HE3 washer parts:
http://www.repairclinic.com/Kenmore-Washing-Machine-Parts
www.RepairClinic.com
Feb 03, 2009 | Kenmore Elite 45986 Front Load Washer
Brand new kenmore HE2 front load washer - keeps filling
Either your pressure switch is bad, or the air line that connects to the presuure switch has come loose. The pressure switch is located on the right-hand side rear of the washer with the top cover removed. It is a brown colored, disk shaped, device with an electrical connection and an air hose connection. Sometimes this hose comes loose in shipping, or the electrical connection may be loose. Without it, the washer will continue to fill and will NOT shut off. Now...if you just purchased this unit, DO NOT do anything that will void the manufacturer's warranty. It may be an inconvenience, but I would recommend you get the appliance repairman to come in and take a look at it. That way...you won't be held liable if something were to break. This is, however, usually a simple problem and not considered major. I hope this reassures you some. Post back with comments if you have any further questions/concerns.
Nov 11, 2007 | Kenmore 46462 Front Load Washer
Washing Machines Logo
251 people viewed this question
Top Washing Machines Experts
