Question about Refrigerators
How can i force ref. to go into defrost mode - Refrigerators
    President:
  • 670 Answers
Not all refrigerators can be put into defrost mode. If you have an older refrig with a defrost timer, you can turn the cam until it clicks and that should start the defrost. Some of the newer machines have a self diagnostic mode that you can set to do defrost. If you can find the wires to the defrost heater, you could jump that and to put it into defrost.
Posted on Aug 31, 2010
Just finished defrosting because of a damaged seal. Fridge wont get cold. It got cold before defrosting.
Your info of what make appliance you have is not in your ?
please give more info on product all ref. have a defrost system built in and depending.on your model # We can tell you what to look for
older model have a timer that make ref defrost every 8 to 12 hours
it maybe your problem if it is a older model .
give us more detail on what ref. was doing b4 you defrosted
you may have a bad by metal defrost stat located in line with defrost heater this is tied or clipped on evap coil
if no fans are running look at timer or defrost computer board if newer ref. model.
more detail we can give if you supply us with model number
appliance tech 40 gmail com
Jun 29, 2015 | Refrigerators
Where is the defrost switch on 106.53592300
Not sure there is a manual defrost switch. Look at the link below for defrost switches for your model. On some refrigerators, if you set the temperature switch to off and unplug then plug in the refrigerator it will force the defrost mode; then unplugging and plugging again will reset the mode.
Oct 20, 2014 | Kenmore 57029 Side by Side Refrigerator
Is my defrost timer or control board defective
that would seem to indicate that the defrost timer is bad yes? the fan is blowing right?
Sep 08, 2014 | Whirlpool Refrigerators
HOW DO YOU PUT REFRIG IN DEFROST MODE WHEN IT HAS ELECTRONIC DEFROST CONTROLLER
You didnt give the make of the ref.; But your solution is here for most all
The newest defrost feature in modern fridges is the electronic adaptive defrost control board. *Maytag has one version, see picture...to put this adaptive defrost style of fridge into defrost, short with a small screwdriver between L1 and test on the adaptive defrost board, wait 3 seconds and you should hear a "click" noise from the relay and the fridge will shut off and go through a defrost cycle. A close up common way *this* version of the Maytag/JennAir control is wired.
Amana also has a version of adaptive defrost, see info sheet for some help on the Amana version. Press refrigerator light switch five times in six seconds to initiate defrost cycle. Pressing five more times within six seconds will cancel defrost and go straight into the run mode. Similar operation on both bottom mount and SxS refrigerators. After the defrost terminator/thermostat opens, six minutes of dwell time occurs before the compressor and condenser fan motor will operate. After defrost terminator/thermostat open, 10 minutes of dwell time occurs before the evaporator fan motor will operate.
Frigidaire has also jumped into the market with an adaptive defrost board. The fresh food section light switch and light bulb must work. To initiate a defrost cycle, open the door and push the light switch in and out 5 times within 6 seconds. The compressor and fans should shut off and the defrost heater should come on. Open the door and push the light switch in and out 5 times within 6 seconds to remove the refrigerator from the defrost mode and back into a cooling mode.
Frigidaire - referance model FSC23F7DSB3
This product comes equipped with an Adaptive Defrost Control (ADC). To activate manual defrost, press and hold the Freezer temperature UP (WARMER) key while pressing the Fresh Food temperature DOWN (COLDER) key 5 times within 6 seconds. A ?¿½d?¿½ in the freezer temperature window and ?¿½F?¿½ in the refrigerator temperature window will display when the heater is activated. To deactivate manual defrost, press and hold Freezer temperature UP (WARMER) key while pressing the Fresh Food temperature DOWN (COLDER) key 5 times within 6 seconds. ?¿½d?¿½ and ?¿½F?¿½ will be displayed until the defrost cycle is complete. (approx. 8 minutes)
For some Whirlpool refrigerators - some Kenmore refrigerators are made by Whirlpool ( 106.######## )
The refrigerator/freezer defrost system can be checked by manually initiating a defrost cycle. There
are two methods of initiating the ADC Test Mode.
First Test Method:
1. Turn the thermostat off for 15 seconds.
2. Turn the thermostat on for 5 seconds.
3. Turn the thermostat off for 15 seconds.
4. Turn the thermostat on for 5 seconds.
5. Turn the thermostat off for 15 seconds.
6. Turn the thermostat on for 5 seconds.
7. Turn the thermostat off.
In 3 to 8 seconds the ADC should turn on the defrost heater (with the bimetal closed). NOTE: The test mode will terminate when the bimetal opens. If the refrigerator/freezer is already in defrost, Test Mode can be terminated by unplugging the refrigerator/freezer from the wall outlet and waiting 30 seconds before plugging it back in. The refrigerator/freezer should immediately go into cooling mode if the thermostat is closed.
If this first test procedure fails to make the ADC initiate a defrost cycle, try the following procedure to make the ADC begin the Test Mode.
Second Test Method:
1. Disconnect the refrigerator/freezer from the wall outlet for at least 30 seconds.
2. Turn the thermostat off.
3. Reconnect power to the refrigerator/freezer.
Within 3 to 8 seconds the ADC should turn on the defrost heater (with the bimetal close). If the unit fails to go into the defrost mode during this test, the problem may not be with the ADC. A defective bimetal may be the cause of the failure. The ADC will only go into a test mode if the bimetal
is closed. If the ADC senses an open bimetal it will return to the cooling mode within 3 to 8 seconds.
HELPFUL HINT: Upon entering the Test Mode, the relay mounted on the ADC board should turn off the compressor and turn on the defrost heater. Listen for the relay to click.
?¿½ If the relay clicks one time when entering the Test Mode, check for continuity in the defrost heater.
?¿½ If the relay clicks two times, check for an open bimetal.
Maytag S-S Refrigerator MSD2756GEW forcing defrost cycle
I replaced my defrost heater two weeks ago, but the frost built back up on the evaporator coils. Replaced the adaptive defrost board with new ( Maytag p/n 6100598 8 ) board. Want to force a defrost cycle to see the heater work, so I shorted the L1 pin to adjacent pin (now called DOOR instead of TEST) for three seconds and nothing happens. Compressor keeps running, fans still going etc. Tried pressing the door switches 5 times in 6 seconds and that doesn't work either. Any hints on how to get the defrost cycle to initiate?
This might help, a copy:
The issue is that some 12002104 ADC boards have been shipped in the 61005988 ADC board box. Do not reorder the board, the 12002104 board will function the same in place of the 61005988, but you must use the forced defrost method for the 12002104. Jumping "L-1" and "door" will not initiate the forced defrost function.
To Initiate Forced Defrost Cycle:
Cycle cold control on and off three times in six seconds. The cold control needs to be left in the closed (call for cooling) position for the defrost system to energize on all platforms. It is not enough to cycle the cold control knob, the contacts must actually open and close (open doors for a period of time if necessary to force the control to call for cooling). In most cases, you can hear the contacts open and close if they are doing so.
To Terminate Forced Defrost Cycle:
Disconnect power for five seconds.
You were right. I cycled the cooling controls three times and it went into a defrost cycle. Thanks.
Aug 08, 2011 | Refrigerators
Alarm on freezer keeps gooing off
low on gas or defrost mode failure....if the element become frozen then the air will not circulate around freezer compartment properly....check the defrost element or timer.
Jul 20, 2010 | Whirlpool Freezers
My samsung ref rt30mass ref compartment is not working properly even with adjustments made from its temperature however the freezer is working properly
The defrost thermostat is not working and the evaporator compartment is blocked with ice. That will stop cold air from entering into the fresh food compartment.
Move your food to another refrigerator, then unplug and open the Samsung refrigerator for 24 hours and allow the ice to melt.
Then remove the freezer panel inside and locate and replace the little plastic tube like part that is zip tied to the expansion tubing. It should have 2 brown wires coming out of the plastic sealed tube/ thermostat part. Write down your model number and go to Samsung's website or searspartsdirect and buy a new thermostat.
I believe the operating range for said thermostat is 20 C to -5 C. you'll most probably have to cut the wires and splice in the new thermostat. You can also use a generic thermostat with the same or nearly the same ratings of 20/-5 C temp.
All the thermostatic switch does is control the defrost heating element that melts the ice off the evaporator every 10 to 12 hour cycle via the defrost timers switch located at the bottom rear of the refrigerator. You can turn the clock counter clock wise until the first loud click to force the machine into defrost as well. Although if the defrost heating element, thermistor, THERMOSTAT, or defrost timer switch has malfunctioned there will not be a defrost cycle and ice will form inside the ducting and evaporator compartment and block the cold air circulation and the fresh food compartment will not cool and the freezer section will barely freeze water.
May 19, 2010 | Refrigerators
Freezer Noises from Refridgerator
You are hearing the defrost mode. Your unit is set up on a timer system which means that every 8 to 10 hours it sends the unit into a defrost mode. In this mode an actual heater, much like the one in your oven, is actuated to defrost the coil that has built up frost. The crackling is the heat causing the frost to melt much like when you pull ice out of the ref and it starts to crackle and pop as it heats up. The hissing is the frost water dripping onto the heating element. You have nothing to worry about. It is working as it should. And if you are wondering where all that water goes...well it goes to a drain pan on the bottom of the ref which is evaporated by the fan that blows across it and the heat that comes from the compressor and hot gas lines.
Apr 01, 2009 | Magic Chef Refrigerators
Freezer ices up fresh food side warms up
Put it into "Forced Defrost Mode". Directions in plastic bag on bottom refrig. Remove grill at bottom to find the bag. Follow directions for "Forced Defrost Mode". Works for me. But.... I've had to perform the procedure several times over the last eighteen months.
Jul 25, 2008 | Refrigerators
Hotpoint soultion
If defrost timer is clockworks type, manually force timer into run mode using flat blade screwdriver. If forcing works, replace defrost timer ($25.00 approx).
Jul 21, 2008 | Hotpoint HSS25GFP Side by Side...
Kitchenaid refrigerator not working
it would not be likely to stuck in defrost mode but my guess would be the compressor is not running. overheated or the condenser is full of dirt. as you said , you can hear fan running, is it inside the ref or outside?..or both?..if that is the case, then it is on freezing mode because the fans would not run on defrost mode..i hope i was able to help..
Jul 05, 2008 | True T-49 Side by Side Refrigerator...
Refrigerators Logo
292 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
