Question about Garden
How do you ck a light bulb in flash light to see if it works
  • 2,100 Answers
Take out the bulb and give it a close look at the filaments, if you see them broken or disconnected, it is no good, if it looks good, hook a little battery to it, any voltage should do, most are 1 1/2v anyway, tape a piece of wire on the positive, set the side of the bulb on the bottom or neg, and touch the wire to the bottom of the bulb. It should light, if not, it is shot, Get a new one. Hope this helps.
Posted on Sep 08, 2010
1989 ford ranger running lights dont work headlamps work fine brakelights work fine How do i replace the switch?
you need to ck to see if you are getting 12 volts to the lights themselves first before you change parts , could have bad wire or fuse ck them first
Mar 19, 2014 | Vehicle Parts & Accessories
Bright lights work low beams don't2005 excursion
ck for power to bulbs ck fuses ck switch
Jul 29, 2012 | 2005 Ford Excursion 4x4
My wipers dont work and my right signal light flashes fast and my rear wiper dont work. some kind of sensor problem but not sure where that sensor is
ck fuses for wipers and rear wiper, the signal flashes fast most likely because theres a bulb out, turn on the hazard lights and see which bulb is out.
Jul 05, 2010 | 2001 Chevrolet Blazer
Brake lights do not work
On fords i know that may be a REAR BRAKE LIGHT SWITCH i think it is located under dash by brake pedal or on brake pedal arm
May 03, 2010 | 2000 Ford F350 Super Duty Super Cab
1998 Jeep Wrangler Sport tail lights don't work. Stop lamps, turn signals, reverse lamps all work. Everything seems to work except the tail lights.
if the bulbs are good, the only thing left is the headlight switch, or wires. black/yellow wires from the switch all the way back to bulbs. ck power to the bulbs first. if no power, then ck power at switch.
Oct 21, 2009 | 1998 Jeep Wrangler
Put in new bulb but still no flashing for right turn signal in 2005 chevy malibu. Bulb lights up but does not flash.
ck the rear bulbs as well - tail lamps on this year are known to fill up with water and rust out the sockets
Oct 18, 2009 | 2005 Chevrolet Malibu Maxx
I installed a new bulb. what do i do to get the TV back on? the bulb indication light keeps flashing
If you have replaced bulb and TV still will not come on you have other problems. CK Fans make sure they are running, also you could have bad blaster board.
Aug 08, 2009 | Hitachi Televison & Video
Indicators dont flash
yes. The flasher works by the load imposed. Ck your brake/turn signal bulbs.
Jun 12, 2009 | 2008 Suzuki GSX-R 600
Front driver side turn signal light doesn't flash.replaced bulb,replaced socket,all other lights work on emergency flasher,except front driver side.rear driver side turn signal light works,but flashes...
replace flasher......usually located in fuse block area...listen in this area....select passenger side ...then select driver side...you can hear flasher clicking...you have seperate flashers for each...FLASHERS are small cubes plugged into fuse block....probable bad driverside flasher
May 09, 2009 | 1998 Buick Century
Oven will not light
ck your light bulb . and ck with meter see if you geting any voltidge
Feb 05, 2008 | Amana AGR5735QDS Gas Kitchen Range
Garden Logo
11 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
